Everything posted by markc
+1 on the above. Everything (almost) is possible, just depends how much money and Big Stick you are willing to throw at it.
Contact glassandstainless.com. they will point you in the right direction
Some (many new build sites) will say trusses between gable walls do not need diagonal bracing, but i have always put it in regardless
Whats going on top of the trusses? you may not need (permanent) diagonal bracing.
Beam not installed to spec, should I be worried ?
markc replied to Loz's topic in RSJs, Lintels & Steelwork
+1 to @PeterW reply. the beam would behave perfectly well with a point support at the very ends. As the loads are very low (no structure or floors above) then the padstones/bearing are also very lightly loaded. -
We had exactly the same while building Lowry Centre in Manchester, big odd shaped panes and one of our guys was spotted throwing sparks at the glass .... nightmare!
Demolish barn to add extension to main dwelling
markc replied to freeze's topic in Planning Permission
Good morning and welcome to the forum, im going to say you will not get permission to do this, but its always worth a try -
Pack wherever the plate could/would deform under load. I.E under bearing / connection points,
1870 Victorian Rear extension and full renovation DIY
markc replied to TomK's topic in Introduce Yourself
Good afternoon and welcome, looks like an interesting project. -
Effective ventilation wanted please in 1970s bungalow
markc replied to jimbobamboom's topic in Ventilation
Letting cold air in forces the stale air into the house, install an extractor in their room, pulls warm air from the house and ejects the hot stale air.- 9 replies
- ventilation
- piv
(and 3 more)
Core filling retaining wall - pour heights
markc replied to Moonshine's topic in General Structural Issues
That should be a pretty tough wall, as above give the mortar time to go off and bring the level up slowly and evenly - assume you are using a pump so work your way around and bring level up approx 1 foot at a time, this means you can be less harsh with the poking. -
Difficult one as there are a lot of variables, number and type of ties, mortar mix etc. but i would be working on around 1m per pour with unsupported walls -
ADVICE on Connecting static caravan to house supply
markc replied to Dave_madl's topic in Electrics - Other
What supply will you be connecting it to? direct in CU? what size breaker/Fuse on supply? -
Porcelain & Chicken Poo
markc replied to canalsiderenovation's topic in Landscaping, Decking & Patios
Shouldn't affect porcelain as they will be glazed -
Porcelain tile, manufacturer tolerance
markc replied to Russell griffiths's topic in Building Materials
Agree with Nick -
Power alarm as a spur from whatever circuit your fridge/freezer is on, then if power fails to the fridge the alarm will let you know.
Airtightness membrane for Tony Tray.
markc replied to crispy_wafer's topic in General Self Build & DIY Discussion
Parge coat is a great way to have a go or start to learn plastering, can be brushed or roller but quicker and more fun to use a float -
Very little heat goes down through the legs of a wood burner, i would say it broke due to load rather than heat. when someone left a pile of clothes on my bathroom floor the porcelain tile heated up so much (electric UFH) it curved up at the edges but still didnt break
Very old uneven wall under the plasterboard so i inserted a plywood `plug` to give the screw shanks something to bear on otherwise the screws would have bent and torn down through the PB
It wont clog up, give it a go. Secret is to hold the grinder steady (no need to squeeze it or fear it) and let it glide through the material at its own pace. Takes a bit of getting used to but you will wonder how you ever got on without one.
@zoothorn yes diamond blades are flat, they will not sit in the middle guard and thats ok .
20kgs is very light as rads go, i have one in my kitchen that weights around 80kgs full and it is hanging on 4no 10 screws. plate gauge really doesnt matter as you are nowhere near the capacity of steel in shear.
Attaching New Outside Waste Gully to Rodding Point
markc replied to Sigster's topic in Introduce Yourself
i reckon that is a surface water rodding point, still seems an odd location tho -
Partitions: Timbers studs Vs Metal C studs
markc replied to MortarThePoint's topic in General Construction Issues
With pozi joists the top and bottom cord are deep enough to accommodate decent length screws so you shouldn't break through into the voids
