Hi welcome, we are in Cirencester. We brought and renovated 2 houses to try and get what we wanted. Now on our second new build ( if we get permission) look at older stuff usually better sized rooms than the new shite, and larger plots
Design for Racks for Spray Painting Skirtings
Russell griffiths replied to Ferdinand's topic in Decorating
Sounds perfect. But maybe your over thinking. Why do you need to spray it all at once. 32 lengths is a lot, I normally only have enough room to do dozen pieces at once, if using acrylic paint I find by the time I've got a coat on, the first ones are nearly dry enough to put on a second coat or move them and start another load. -
So I seem to have done a complete about turn and moved away from timber frame to icf, so re,doing a lot of research. First question icf are available in different insulation widths anything from 50mm to 150mm with obviously different u values, but also you can have a thinner standard block and add additional sheet eps to the outside to increase overall thickness. So the question is what would be the difference between using a thicker block in the first place as opposed to a thinner one and adding additional sheets to the outside? I'm trying to come up with a benefit of adding the extra and all I can think of is bridging all the block joins with a larger sheet May in someway prevent heat loss. Any thoughts. @Stones
pro's & cons of different ICF systems
Russell griffiths replied to mvincentd's topic in Insulated Concrete Formwork (ICF)
I was going to read all @najem-icf posts to see the reason but I was being lazy so just asked the question. No disrespect was intended, but from reading this thread it does read like build with icf because everything else is shit. By the way I intend using icf, but have previously built timberframe,and I'm also a bricklayer, but won't be building using brick or block. Work that out. -
can you tell us why your user name is @najem-icf -
Why do you have to cut the insulation? Just buy it in brick tie spacing size. The small sheets should be sized at the same spacing as the ties. I'm out of synch with the current spacing but you used to put a row of ties in then your solid insulation then another row of ties. Most ties fit with a stainless ring shank nail, but I see no reason you can't screw them.
I assume you mean this stuff https://www.permagard.co.uk/stainless-steel-helical-spiral-bar-3-metre?gclid=Cj0KCQjw0ejNBRCYARIsACEBhDM0NP8lWl6ogOx0ixgLWua25136-J0ovgBODu1VOfv5d3kspzP2kDYaAgxiEALw_wcB if so you are going to do well to hammer foot long lengths of that through OSB, even with a pilot hole i reckon they will bend more often than not it comes with an instillation tool which is basically a piece of tube with a capped end for thumping with your hammer.
Can you not make your own ties? You can buy the helicoil in 3m lengths and just chop it up.
Rendering and airtightness
Russell griffiths replied to ToughButterCup's topic in Plastering & Rendering
Ok so I'm confused ? Not hard as I'm a bit of a thicko. If your blocks are core filled and your posi joists don't penetrate into the wall how and where are you going to get air loss. Is is it normal practice to air seal icf or is it just the type you have used. -
Phone him. Better to look a bit silly on the phone than him turn up and you will look a right plum.
"Softening" a rendered monolith
Russell griffiths replied to gravelld's topic in New House & Self Build Design
https://www.houzz.co.uk/photos/504212/swedish-exterior-traditional-exterior-new-york how wild do you want to go I get a lot of inspiration from this site. -
Steel (Acro) Props - Needle or Strong Boy?
Russell griffiths replied to LeanTwo's topic in General Construction Issues
The original idea behind the strong boy was you could work from one side whereas with a needle you have to go to both sides of the wall, if access is not a problem needles all the time, if you don't want to destroy the internal area to the room above then strong boys. -
Some good points there about icf I hadn't considered.
Who's icf system is that @jamiehamy
So again fwiw if you tile your main flat area first , last flat tile will overhang your flat area and extend into your fall area (is this correct) if so with a 2% fall let's say you have made your flat area 100 mm larger than it needs to be your flat tile will project onto your slope area by 100mm the bed under this tile for arguments sake is 5mm when sat down firm so you will have a strip of tile 100mm wide with a bed joint 5mm thick + 2%. This is ABSOLUTELY negligible just screed up to the flat area you have laid now.
If you are a bit concerned in doing the hand screed thing do as @bassanclan said and mount your angle temporarily, fill area and rough out your shape then pull out the angle iron and fill the thin strip and finish trowelling. Having just read the last couple of pages and looking at pics, that is a 3 hour job including all the mixing and carrying in doors. No problem son for a man of your caliber can I ask what is the outside ring off angle for are you not using the other previously laid area as your level area, surely this sloping slab has to blend in join up with that one doesn't it ? If this is the case you already have a datum point all around to work off. JFDI
Ok so in my very humble opinion you are making this far harder than it needs to be. I cant chat long as I'm sitting on my hotel bed waiting for the misses to get ready so I can go out and get wasted. In yhe vid he has a centre drain, yours is at the end, work out your preferred fall to this drain and set it down (I think you have already done this) mix up a load of screed, if you want to modify it you can add a bonding agent to it or even some 10 mm stone, mix up all you need in one go don't be fu###ing about you will be very busy in a minute chuck it all in and compact very well, use timber or a level to scrape to desired height DO NOT WORRY IF FINISH IS NOT PERFECT. you are trying to get correct fall not a surface good enough to varnish, when you are happy you have youralls you can then go over it and give it a good polish up fill in all the voids, if you want shiny use a steel trowelled finish if you want a bit of grip buff it up with a plastic float. Hurry up I'm of for a pint and a boogie, I expect it finished by Sunday night. Chop chop. While ive been slowly typing you have replied. Take your auto cad and print it out chuck all you mix in like I said refer to your drawings and scribe into the top of the mix your two long fall lines use a straight edge and edge of trowel, you will end up with a screed mix that has a 4 section triangle thing if viewed from above. Check your measurements 324 times ( I put that bit in for you ) look at it a couple more times and adjust if needed, polish up and fill in any little low spots and shave of any high ones. Open a can and drink to my good health.
I can't be bothered to read all the previous posts but why are you trying to form this with a concrete mix, i have formed dozens of shower and wet room floors all to falls and we use a screed mix,slightly wetter than you would screed a whole house just form the falls using a spirit level and a few bits of 2x2 cut to the required lengths chuck all your mix in and level with the existing floor area. Scape down your fall heading to the drain just keep dragging your level over it checking you have the fall you want, trowel up to a good finish ready for your tanking. I will try to find you a vid as I have very few pics of work I have previously done. All wet rooms in oz are like this you will struggle to even buy a shower tray.
Are you doing your slab yourself ?
Any reason you are not using icf, this is what I would do light weight to move about easy to add the reo, many approved systems for waterproofing. The time you buy all that ply just to form it up then you take the formers down and you still need to insulate the walls your left with. I would be interested to know @Triassic why you are not doing icf.
Wall Hung Toilet Weight Limit
Russell griffiths replied to Triassic's topic in Bathrooms, Ensuites & Wetrooms
@Onoff mate you took the words out of my mouth. -
Back to Wall Pan on Wonky Wall
Russell griffiths replied to Grosey's topic in Bathrooms, Ensuites & Wetrooms
Ha ha, I typed out a big reply earlier telling you to either take the wall down or level the floor but you must fix that as there's a cock up there for sure. I deleted it before posting as I sometimes get accused of being a bit quick to point out negatives shows I was right glad you fixed it looking at that gap would have driven me mad. -
We brought a ceramic double sink, it had a dish in the surface that mounted on the wall, out by15mm give it a good check, and then check the wall floor junction something is way out. -
How to terminate soil pipes prior to concrete pour
Russell griffiths replied to Pete's topic in Waste & Sewerage
Sort of the same as peterw said but we wrapped our pipe with 100mm foam and taped up this left a void around the pipe about 20 mm in diameter, big enough to either put a coupling on or push a pan connection on. Fill any remaining void around pipe.
