How is having a rainwater tank solving the problem of where your roofwater goes? Do you have to provide a solution for bc we have had had to do a full flood risk and rain water analysis, and they wouldn't except a rainwater tank as any form of mitigating measure. The reason being what happens if your tanks are full and it rains? It goes straight out of the overflow and into your drain field. So why not just put it in there in the first place. Unless you really want to flush your toilets with it it seamed like a crock to me when we did our assessment.
Hello again - work has finally started
Russell griffiths replied to AliG's topic in Introduce Yourself
Love the house. What is it with bloody tradesmen. Why are those windows not fully masked up. I wouldnot consider working near them without full masking or an indemnity from any damage caused. Sorry rant over. -
Help me identify this, please
Russell griffiths replied to ToughButterCup's topic in Bathrooms, Ensuites & Wetrooms
Can we all look at that pic again. Is it just me or does the reducer from the grey 22 to the white 15 not look like it is pushed fully home. @recoveringacademic have you actually got any water drips or just on the valve that floor looks very stained for a small weep. -
How to match grouting?
Russell griffiths replied to TheMitchells's topic in General Construction Issues
You basically need to experiment. Chances are they used local materials look at the mortar and work out how gritty it is so go to the local merchant and buy a couple of bags of different sand one soft one a bit sharper and see what cement they sell get a bag of ivory cement as well as a bag of lime. Go home and make up half a dozen very small mixes use a coffee cup as a gauge so 5-1 sand and cement 5-1 sand ivory cement 5-1 plus 1 of lime its going to be very trial and error until you get a close match after you have done a couple you will get an eye for weather it's a bit grey or to creamy. Only way I know to do it to be honest. Let them dry indoors so you reach finish colour quickly. -
I have a feeling this is something that has been done this way for years. Pattern to inside so outside flat so it stays cleaner, that's what I was told many years ago.
Go and get a piece from wicks you can get it in single sheets there, if you can't find the profile you need run another shape(angle facia) through your table saw until you have the profile you need, this is only a mock up so a bit of fettling may be needed until you get what you want. Have you thought of a completely contrasting colour maybe in grey, anthracite? How about getting a coloured flashing folded. What about a cement board and acrilic render, or eps and mesh and render. I wonder if the upvc will look a bit sterile and add a massive amount of white.
You think rebuilding with stone is dear. Wait until you try and tie the new building into the old one. Knock it all down and rebuild it replicating the deep windows and inner stone skin. I knocked down 3/4 of a house and rebuilt it, total pain should have flattened it and started again. Can you get the neigbours involved so you can both have a new place.
Hi @Ian can you give us some more information on your findings, I'm looking at this roof system also, is it only the gutter your not happy with or the whole system. Cheers.
Plant room location
Russell griffiths replied to Russell griffiths's topic in New House & Self Build Design
Thanks all. -
Evening, having a re,design due to our planning officer ? Ive just re jiggled the location of our plant room, and think I've may have made things hard for myself. Should i I try to have the room situated on an outside wall? will the pipes for the ashp be easier to route from out side to inside straight through the wall rather than ducts in the floor. What about the ducting for heat recovery system, better on an outside wall. Still plenty of time to jig things about. Cheers.
I have noticed this on many projects and believe people building there own place underestimate the need to have materials ready weeks in advance if only to take dimensions of or have a quick look at how it's meant to go. On our last place I had a garage full of toilets, taps and all manner of fittings. I found I needed to know what toilets we where having to determine the offsets from the wall for the drain runs, so they probably sat in that garage for at least 4 months. As a contractor nothing bugs me more than standing discussing the location of something that the client should have thought about weeks ago. This I believe is what @Grosey means by removing risk and hassle from your tradesmen, then you will get better prices. I have a neighbour i Work for who is a nice enough chap, but he messes about and we flit from one task to the next whenever I work for him I add £20 per day so it softens my annoyance factor a bit.
Well done son looks cracking. ??
Materials and approval
Russell griffiths replied to Russell griffiths's topic in Building Regulations
So what do I actually look up to see what certification a roof sheet needs. And if I buy sheets over here will anybody actually want to see where these sheets came from. -
So 533+533+5 what about the gap at the hinge side even with nicely rebated hinges they don't close tight to the lining there is still a couple of mill clearance i would think it may be a bit more like 2+533+3+533+2 but as I said I would not try to get it this accurate with out the doors.
So why do you need your linings in to board up. There is no reason to put linings in first. We board over the door openings and chop the doors out so you use a full sheet covering the head of the door this prevents cracking at the door corners and is the correct way of doing it but very rarely seen as it's easier to just board up to an opening and put a piece in above the door. If you are keen to get the linings in then why not. Do it like below. so I presume your having architrave? if so than fit your linings temporarily couple of screws in each. Board up to them. Then when you get your doors you can pack your linings to get perfect gaps all around. The architrave will cover the gaps. If your not having achitrave and having a fancy trim on the edge of your boarding you will need your doors, trying to guess how big they are will lead to uneven gaps.
Hope this is in the right place. So im thinking of importing some of the materials for my build. I will add bits as I think of them,what I would like to know is what type of approval do I need so I can use them, I don't mean planning approval, I mean do they have to have BBA to be used. The first item I'm thinking of is roofing sheets we have planned on having a raised seam metal roof, what does a metal sheet have to comply with to be used and how can I find out information on this. Confused as usual with the over complicated way things are done in our country. Cheers russ.
Self Levelling Compound as finished floor ..?
Russell griffiths replied to PeterW's topic in General Flooring
I had a levelling compound on my garage floor for years without any covering, it stood up well to the jack but not so well to axle stands. Mine was only 3-6 mm thick as I wanted a very flat floor to work on. I did paint it in the end. If i was doing it again I would put an epoxy over it. Maybe if you get a cream colour epoxy it will look similar to the tiles. -
I personally would go for the full topography survey, you may be surprised that there not that dear. Why. Because you will use it a load more than you think you can send it electronically to anybody who needs it you will need one if you need a flood risk assessment you can give it to the surveyor to mark out the location for the new house you can give it to the Groundworks guys to set out drains etc etc ours cost £600 but our site mapped was aprox 400m by 100m and consisted of aprox 1200plotted points it would be the first thing I would do if buying another piece of land.
Water supply - temporary and permanent
Russell griffiths replied to Weebles's topic in General Self Build & DIY Discussion
It can go up through the slab, but will need putting in a duct to enable it to be replaced if the need arises. I would run it around the house and only under the slab at the point it needs to enter the building. You will probably bring it up in your plant room or whatever room you are having all your water and mechanical wizardry in. -
Window orientation
So more by luck than judgment, I'm planning on having a fairly large 750mm roof overhang over the windows and also the roof under the windows is only 15 degrees so easy to walk on. -
P5 Structural deck approval & building control
Russell griffiths replied to bissoejosh's topic in Timber Frame
I have seen the flooring continued under the second story many times it seams to be a detail added for extra bracing within the frame. So they are using the floor sheets as a sort of lateral brace and a spreader tie. -
Window orientation
https://pin.it/bpLBAgE This is the sort of thing I'm thinking of, they are indeed called celestory windows you clever bloke @PeterW -
Window orientation
Pic added if you look at the sloping roof I can spin this 180degrees so it can either slope north to south or south to north so putting that strip of skinny windows in either the north face or south face. Any thoughts appreciated. -
Window orientation
https://www.houzz.co.uk/photo/65633706-siga-house-contemporary-exterior-cincinnati -
Ok so due to our planning officer?We are having a bit of a re design. So I will try to explain but I haven't got any drawings done yet so can't upload any but might be able to find an example on the web. We are having some high level windows installed in a wall just below a vaulted ceiling. Now I can turn this roof 180 degrees with out it effecting much. I am concerned with high level windows that allowing light in that we want, will also allow solar gain and lead to overheating in the summer. These windows can either face due SOUTH or due NORTH they will be aprox 4.5m long and 750 high. I will try and find some pics.
