Russell griffiths
    65
  1. Local repairs, then a good heavy lining paper then some minor filling and then paint.
  2. You may need to look overseas America or Australia, look at pool fencing. Bunnings warehouse.
  3. @IanR is that a snap together type sheet or does it need the seam tools to form the seam. And whose is it. Cheers russ.
  4. I have just found a few but my rafter length is to long at just over 8 metres.
  5. Hi can anybody point me at some products suitable for roof pitch of 15 degrees. I have my own ideas just looking for suggestions. Thanks.
  6. Oh I'm not happy hearing that. Bugger. I will have to have a think.
  7. Can I ask what problems you had with tata im thinking of using them but haven't made any contact yet.
  8. Oh misread are you a conversion rather than new build.
  9. Is the bigger issue working out why you are not building up to be out of the flood risk? If you thought you where going to be. If like us I have had to spend a fortune on a fra so would want to know the right answers.
  10. Can you imagine this in stainless, I fired them out of the coil nailer, but any near the end I pre drilled and banged in with the estwing. I suppose if you need to pre drill a few screws might be better. On my last place I priced to do it in screws and it was £500 dearer than nails. Have you much to do or just the dormers.
  11. If you shutter it on the floor and pour it and then lift up. What is tying it to the walls below? Wont it just be a big triangle free standing on top of the other walls. I personally would build a dummy roof truss or a proper one if that's the sort of roof structure you want, and use this truss as a template to cut your blocks to.
  12. Does anybody do a pre hung door and lining without it being one of those over complicated adjustable things, just a door lining with hinges all routered and hinges routered into the door.
  13. Those prices are scary. Our last house had 16 doors including matching wardrobe doors. I cant comprehend what sort of budgets some people have.
  14. I too have used a coil nailer,stainless with a twisted shank, stays in place like a ring shank i will see if I have a couple about for a pic. Do you want a visible head or hidden.
  15. Why do I not see anybody using pipe cleaner before they glue a joint? I recently brought some in the plumbers merchant and when I asked for it the lad said that he had some out the back but they don't sell much and he didn't even know what it did. I used to glue up lots of pressure fittings and if you didn't clean properly they would blow apart. Nice roof btw.
  16. I would re locate that horse box, it looks perfectly positioned for a quick getaway.
  17. So if I have to put in an ashp to run my ufh, why do I need a sunamp? Why don't I run it all of a ashp.
  18. Ok so this is basically just to heat the hot water feeding taps and showers.
  19. We also have a larder in our house now and will put one in the new house. I was thinking about running our main water into the floor area of the larder, now our water supply is very cold as it enters the house, could I put a radiator on the wall of the larder and have it mains water fed so it is cold to the touch, would that keep the air temp down in there. How about a piece of 32mm copper running just above skirting height below any shelves, running around the room linked to the incoming main.
  20. Osmo oil, has anybody looked into the makeup of this product to see exactly what it is, to find if it can be brought under a different banner.
  21. Ok I will start, by asking some total noddy things as this is a part of my build I'm really struggling to work out. How the hell does this thing work what does it do? Where do I keep my water? Will it provide water for my ufh? How is it powered? What happens if it's not sunny? There you go some proper numpty questions there. Cheers. Russ.
  22. Our site is a sssi as well.
  23. Ok some good points here so I will try and fill in a bit more info. Our site is a third of an acre sitting amongst another eleven acres, all owned by us. We have kept the building plot very neat and tidy very short grass no scrub, the ecologist found nothing of any interest, but the rest of the site COULD provide habitat. we have a planning consultant dealing with our planning and she has told us that the local council have been applying lots of conditions with anything that gets approved. Her opinion is that we do a CEMP and submit it with our ecology report so we are already showing how we will deal with any ecology on site. Do you think the erection of a newt fence around the whole building plot could provide a lot of proof that we are doing our bit to mitigate any risk to the little wriggling things. Cheers russ.
  24. I cut mine with a diamond coated disc on a hand held grinder. Bear in mind good planning so all cut edges will either go into a corner, or hidden behind a socket.
