Russell griffiths
    65
  1. Wasn’t me?Guvnor.
  2. Oh good god. @JSHarris I was asked to remove the pic,??? that’s why I was trying to put it up with a link and not the actual pic. Ian will be after you now ?? honestly ian I did try and do the right thing, but I get easily led astray.
  3. Have been trying to post up the pic in a url link but my I pad just doesn’t like it. Oh well your all just have to imagine something a bit silly that tickled me. But I am easily amused.
  4. Evening. Does anybody know of a good design app that I can use for trying different materials and colours on the exterior of my house, I’ve recently used another app called architouch which I think is excellent for planning and layout, but I’m struggling to add external finishes apart from ones that are stored within the app which is a bit limited. Cheers.
  5. Tbh I thought the topic title would get you all looking. Flikr how do you do that then?
  6. I have just deleted it, I think it might have been offensive to some (sorry). To many years on site.
  7. Had to get some stickers made up after somebody thought it was ok to borrow me ammer. the hammer in question
  8. Looking at the size of your place I would expect at least that. Another job for @Nickfromwales
  9. As @nod said you really should have a cavity closer with a dpc under the coping. If the coping is made of any form of concrete/stone, it WILL let moisture through into your cavity.
  10. Just had a look while having a cuppa. Nudura do a custom cut radius block. Have a look at there intro vid showing all the different blocks they do.
  11. I think on the nudura you tube vids they cut the blocks into slices and glue back together to make the correct shape. If you make a ply wood template you could pre cut and glue using the template and carry over in one piece to place in the wall adding reo could be a challenge. Are you bays semi circular? Or segmented like a 50p we used to make a template / profile when doing curved brickwork. I think a similar thing would work.
  12. Is this temporary or permanent? i have found even with the black membrane you will get weeds they can grow from top down as well as from bottom up you will find you will get weeds from any form of seed spread be it the wind or birds or you wheeling the mower across the surface. Unless this is going to be the mutts nuts finished article I think I wouldn’t bother with the membrane. Get some roundup and give it a spray every now and again to keep the edges tidy.
  13. E bay.
  14. So they are screwed together, do they not have a ridge beam under them? This isn’t a detail I have seen before, has this been drawn up like this for you? Just spotted the big purlin built into the blockwork. Carry on ?
  15. I would say raise the wall plate as well. What is going on with those rafters in the second pic? do you intend bolting them together or something?
  16. get that wood burning stove back in. ???????
  17. Come on then, you supply the beer I’ll bring me hammer, once we rip it all out there’s no turning back im really good at making a mess and then running away???‍♂️
  18. Well done chap. ?
  19. Our first house was a bit crap like yours seems to be mr @Onoff and we used to get out of the bath and get into bed, the curtains used to flutter in the draft from the single glazed windows. I think the only way to tackle it is head on, smash bang wallop. Move bedrooms downstairs, and completely gut upstairs ceilings down window trims all off floors up strip all walls strip out the dormers a complete gut. Then rewire re plumb re insulate re board flooring back decorate. Then move back upstairs making a temp living room in a bedroom,and a small kitchenette go downstairs and gut that same as upstairs rip it all out you cant take any prisoners get in and smash it out i think if you go about this half a room at a time patching this and that I think you will struggle to get on top of it. Only my point of view obviously, please feel free to ignore everything I say or tell me to get knotted. As a side view it looks like you have a nice big garden and a rear access. Anychance of getting consent for a new build there. How about a little granny annex. Build the new one, move into that while you refurb the big one, then move back in and your left with a nice little rental at the bottom of the garden. Any chance. We have consent for a two bay garage with granny annex above went through planning without a blink of an eye.
  20. I watched a you tube vid and since brought a doctors stethoscope, I now need to work out a way to connect the stethoscope to a long metal spike to stab in the ground. Always seems to be a project to do in the garage.
  21. ive Been doing a bit of internet browsing and started to find 50mm pipe at better prices so will do a bit more leak hunting, tbh I didn’t know you could put a camera down a water main I thought it was only for drain surveys so I might be able to find one of the joints. These must be the first point to look for a leak or at least an ideal place to run a new section from. Thanks all.
  22. Where did it go?
  23. What you need is what we have done to our crappy house. Im a little bit frightened to say it. you need a wood burner, we have one in the boot room and keep it going 90% of the time from November onwards, the wife can dry a machine load of washing in under a couple of hours it super heats that end of the house which in turn helps the rest, we have solid concrete floors straight on the dirt with chipboard on battens on top, solid 9” block walls with pebbledash and chipboard on battens on the walls. Unless we have been away for a few days it is toasty, it may not be what you want long term, but it was the best £1000 I’ve spent on the place total transformation.
  24. We have a 50mm main that is fed from a metre via a 25mm pipe. Unsure how this all works, but it’s been like it 20 years with no problems.
  25. Any links to a reasonable pressure gauge? will I need one for testing ufh and other services in the new place? If this is the case should I get a better quality one? my incoming main is 50mm that reduces to 32mm which then has 20mm tees of it to feed various standpipes and our old cabin, will taking a reading at one of these 20mm pipes give a false reading should I go back to the 32mm to do the pressure test? Cheers.
