2nd floor ICF install - chicken and egg
Russell griffiths replied to BotusBuild's topic in General Construction Issues
Why not put the first floor joists in, place a a row of acrow props under the floor as dummy support in the place of the stud walls. Then build up Nudura and fit roof. Remove acro props, don’t allow anybody upstairs, pour floor screed and replace one or two acro props to take any sag out of floor, then build stud walls removing props as you go. -
You can buy cold galv spray in screwfix and toolstation. You will need to wirebrush it down and remove any dusty bits.
Corrugated Metal Roofing
Russell griffiths replied to Tom's Barn's topic in Roofing, Tiling & Slating
All the houses near me with metal roofs and roof lights have series of sheets cut to different sizes flashing around the window. -
Help - SWMBO doesn't like it?
Russell griffiths replied to Adsibob's topic in New House & Self Build Design
Grow a pair and tell her she’s wrong. -
ICF Braces / Supports
Russell griffiths replied to JDeluce's topic in Insulated Concrete Formwork (ICF)
I used Icf supplies, they will rent them to you. -
Suspended ceiling at openings
Russell griffiths replied to Pocster's topic in General Self Build & DIY Discussion
@nod you need to come back to this, he seriously needs your help. @pocster wait for nod, ignore all other stupid comments unless they involved mf metal ceiling stuff. Its like metal stud walling but for a ceiling. Hang on he will be back soon. -
They don’t overflow. Depends on your length of run and how many linear metres of run between outlets. Builds over here don’t have enough outlets. So gutters overflow building regs in other countries are an outlet every 6m, but here we just have them on ends of runs. Deepflow if you have a large area and not enough outlets.
I would get tubs, delivered fresh every 3-4 days, unless you have 10 brickies on site a silo will sit there for weeks before it’s used. But obviously phone up and look at quantities and find out how much they will use a day.
Which parts did you DIY?
Russell griffiths replied to BadgerBadger's topic in General Self Build & DIY Discussion
Only 3 things I have not done. Piling. Floor screed electrics. Apart from that ive done the lot. -
I’m not surprised your builder wants to use actis, it will save him thousands in labour cost. But it’s your house and your spec. Do you not have a drawing. 160mm of k7 is a good spec. If your worried about fitting then get a spec for the product and tell them that is the standard it needs fitting to, end of. Fit it correctly or f##k off. This insulation should have a layer underneath the rafters as well, to mitigate against cold spots through the joists. There is a product that expands to keep the insulation fitting tight. If your having a fight with the builder buy some of the GAPO TAPE to make his life easier. What is happening with a vapour control layer.
- 14 replies
- insulation
- pitched roof
(and 2 more)
It will cost a fortune to get right, but if that’s what you want. We are having a timber ceiling, it will be 3 times the cost of plasterboard and paint, but I like the look so it’s happening. Fireproof coating again.
If they did put them in, would this mess up your floor finish, as you would need to carry the joint up through the finished floor.
I’ve never Seen an expansion joint in a slab, not unless it is a funny shape with a skinny bit that will definitely crack where it joins the fat bit. Or if it was many hundreds of metres square. My last place had a ground floor slab of 340m without any expansion joints.
DPM under Beam and Block Floor
Russell griffiths replied to iMCaan's topic in Bricklaying, Blockwork & Mortar
No bed, it wouldn’t be strong enough to take the point load of the beams. Just roll out dpc and put beams on top. -
Prefabricated Chimney
Russell griffiths replied to Fallingditch's topic in Roofing, Tiling & Slating
You will still need scaffolding, a roofer and other bits, so the only element it does away with is a bricklayer and bricks, plus a pot, so what’s the cost of the fibreglass ones ? -
You are concentrating too much on one element. If you carry on like this you will miss something far more important. Better to get a house that works, the flow around the rooms, socket locations for the wall mounted tv, stuff like that, you need your eye on the whole project.
You want a liquid. There are two on the market I know of. BLOWER PROOF MEMBRANE and PASSIVE PURPLE. I have used both either spray or paint brush. The blower proof is thicker and has some fibres , it’s easy to paint on , but a bit expensive.
- 10 replies
- airtightness
- joists
(and 2 more)
SIPS or ICF
Russell griffiths replied to jimmy_stocks's topic in Energy Efficient & Sustainable Design Concepts
That shows that you need to clarify with the plant that you will be carrying out a slump test and will return anything that doesn’t come up to spec. -
ICF and Insulated Raft Junction
Russell griffiths replied to PaddyP's topic in Insulated Concrete Formwork (ICF)
Nudura do their own one, do you have a supplier over there. -
@PaddyP buy the correct product. Triton will be order in you won’t find many stockists. £175 for a big bucket. Buy the peel and stick from your icf supplier. Or buy peel n stick from a waterproofing company, must be compatible with eps. Dont use any bituminous based product. -
You cannot use any bitumen based product on eps or xps, it will just dissolve it. Must be waterbased. -
SIPS or ICF
That’s ok saying that, but they do their research over the internet with a few pictures. Nothing like being on a site and watching the troubles unfolding in front of you. And it wasn’t my place, so no financial loss to me, just horrified at the grief it caused to the builder and the financial loss to the home owner. -
SIPS or ICF
I would re think that a bit then, woodcrete is bloody heavy, hard to cut, the dust is horrendous. I could go on and on, but I would start sounding like a salesman for poly type icf. -
SIPS or ICF
Oh god, just don’t. -
Triton TT waterproofing membrane. Two coats painted on, from below ground to about a metre up. Just batten over it. Or use one of the peel and stick membranes, below ground to 300-400mm up. Stick the cement board directly on to either solution, and just batten down over the cement board.
