Row of concrete blocks on flat, row of marmx blocks then timber sole plate, all held in position by insulation and screed. What are you doing with your external walls to minimise thermal bridge. Do the same.
Just the structural wall through to the beam and block, the rest on top of the screed no screws needed, pu glue the sole plates down, you will not move them.
Haven’t got time to think about your whole question. But you need to ditch the 32mm idea and go 40mm if any length of run then go 50mm 32 is only any good for a tiny wash basin over a tiny distance.
Siberian larch vs sweet chestnut cladding
Russell griffiths replied to PeachyBeechy's topic in General Construction Issues
Have you looked at British larch, or western red cedar or Douglas fir. Depends if your looking at rustic finish or sharp clean edges. Ive recently seen British ash that looked good. -
@Onoff when fitting a piece of board use a spirit level instead of the board to keep it stiff and straight, you can see it’s level without having to keep checking it.
Grinder
There are companies that specifically look at faults in new builds. Look one up and get them to investigate. it’s a shame it’s getting warmer. Get a thermal imaging camera thing, crank the heating up and stand outside to see where it is escaping. or set up a home made air test, set a fan to suck air out of the room and stand in the room hunting for the cold draught.
Buy a new roll get some of the black dpm joining tape get some scissors and get on your hands and knees and patch it all up. fairly simple really. If it wasn’t important then why put it in in the first place.
Pea shingle or sharp sand between the drainage pipes
Russell griffiths replied to Porthole's topic in Waste & Sewerage
If he’s constantly cutting corners then this is you excuse to let him go. pea shingle for me. -
Try Icf supplies in Essex I know they are linked to the company somehow.
@Onofffo yourself a favour and change your foam. look at illbruck airtight foam for all sealing jobs, and soudal Instastick for fitting the reveal boards. totally different to the crap your using. you probably won’t need any other airtight strategy if you use this stuff. Icf supplies in Essex are a new distributor for the illbruck stuff.
Is installing guttering an easy job?
Russell griffiths replied to Thorfun's topic in Rainwater, Guttering & SuDS
I used guttercrest, all aluminium powder coated. When you look at it it looks expensive, but all the brackets are fitted to the gutter as standard, if you add up a section of another gutter it’s cheaper but then add a joiner and 4 brackets per 3 m length and the galv stuff was actually dearer. Easiest gutter I’ve fitted, no brackets, no fall required, but you will need a brain and a good idea how to use a drill and pop rivet gun. -
Does the safe zone apply for this, in which case you should run directly vertical from the light fitting in case of future drilling cockups.
Reynaers vs Lumis - Alu vs Alu-Clad...
Russell griffiths replied to Mulberry View's topic in Windows & Glazing
If it’s a new build not an extension then you want the best you can get. I would say those u values are poor, and are more what I would have in an extension to a poor house, not a new build to a high spec. don’t overthink this sight line mumbo jumbo. I spent ages making dummy frames to check all the mullions would line up, the windows we chose upstairs are a lot thinner than the door down stairs. Do we notice it ,nope not one bit. Was a waste of months of time worrying about how thin the frames where going to be. in the end we went with enormous fat ally clad, but they have a brilliant u value and terrific air tightness. I think it was the better choice. -
Are you thinking you are going to buy sand and aggregate separately then buy cement. just buy concrete ballest already mixed together and add cement and water. 5 ballest 1cement will be perfectly adequate for a footing mix. can you not just get a couple of metres of readymix.
What do you want it to do. Dpc you shouldn’t need anything, use a waterproof additive in your concrete and your good to go. I used it for something completely different, just to keep bc happy. don’t use black Jack for anything, it’s bitumen based and will melt your blocks.
Is an eaves support tray needed?
Russell griffiths replied to WWilts's topic in Roofing, Tiling & Slating
Don’t do it, they don’t grow on bloody trees you know. -
Btw you don’t have a screw missing in that bracket, you either use the centre hole or the two outer, not all three. -
How best to resolve old toilet soil pipe
Russell griffiths replied to Loz's topic in Waste & Sewerage
You do realise that you are not connecting to the white pipe. Pull the white pipe out and chuck it in a skip. Then you are back to the grey. Work out what you need from there. -
@Mr Blobby time to get a company used to dealing with low energy houses. I purposely changed my manifold to the Ivar as it had the lowest temperature mixing valve.
Are kitchen extractor designs all rubbish?
Russell griffiths replied to SimonD's topic in Kitchen & Household Appliances
Isn’t it 29x225.
