Dudda
    1
Everything posted by Dudda
  1. Dudda
    Venetian plaster? Its a waterproof plaster with marble dust mixed in which allows various colours. It's very tough and easy to clean. No joints, grout, plastic cover strips, etc. Looks sharp but not the cheapest option.
  2. In Ireland during the ceitic tiger we had a lot of poor quality built houses which are informing a lot of new regulations. You can get a factory certified 15mm plasterboard slab to perform. Its of a high quality produced in a controlled environment. If it's 12.5mm plasterboard and 3mm skim applied on site then who's going to certify that? How can you verify with certainty that it's 3mm and not 1mm everywhere? How can you be sure it was mixed correctly, the water wasn't contaminated or that the plasterboard surface was clean and dry before it was plastered? Yes you can get good plasterers and I'm sure yours were but we all know a lot of cowboy plasterers are around. Remember your house was a self build one off. In a large estate with 100 timber frame houses it's hard to oversee everything. It's all about quality and accountability.... or in reality who you can sue if something goes wrong.
  3. That build up would not now be allowed in Ireland. Just to clarify. Insulated plasterboard slabs (where insulation is fixed to the back of plasterboard in a factory) are not allowed anywhere in timber frame houses. The plasterboard has to be 15mm (12.5mm isn't good enough) and has to continue around all reveals. It has to be mechanically fixed and it doesn't matter what the insulation is. You can see in fig 2 it's wool (which is natural and non flammable) and fig 3 it's PIR which is flammable. These are new guidelines. In Ireland we don't have building inspectors like the UK and the architect has to sign off on the project. I've signed off on several houses in the past with only 12.5mm plasterboard in timber frame houses but won't with these new guidelines.
  4. If it's timber frame you really should be using 15mm and have to by law in Ireland. See attached guidance note recently issued to all architects in Ireland in relation to fire safety in timber frame houses. BCMS Information Note 1-2018 Guidance on Timber Frame Walls.pdf edit to clarify: published by the Building Standards, Department of Housing, Planning and Local Government in Ireland. Not relevant to building regulations in the UK but it would be good practice to follow the best guidelines in relation to fire.
  5. If your using the fibreglass insulation batts to keep the building breathable then you'll have to get special plasters or lime and everything else will have to be breathable. If you put a cement based render on the house that won't be breathable and all the effort to make the rest of the wall breathable will have been in vain. While timber frames are breathable, modern blockwork houses generally aren't breathable the way traditional stone buildings were.
  6. Mine is sitting at the bottom of the stairs for just over a week now. Good to read how you installed and where you put FCU, DP isolator, etc as I'm about to start the same as soon as it gets to where it's supposed to be.
  7. You've a few questions which ask more questions. First with the 100mm cavity that's only half filled you could look to fill the remaining 50mm with beads. This would be cheaper, easier and a lot less disruptive than drylining internally. Secondly what's the outside of the house like? Would you consider external insulation? You can then go 100 or 150mm insulation, it will reduce cold bridges, reduce internal condensation risk, give a new fresh look to the house and not reduce internal floor areas. You can continue to live in a house when external insulation is added. On the ground floor you plan on using a screed and 120mm of insulation. Is this on top of the existing concrete slab? What's there currently as adding this additional height will reduce your floor to ceiling height and potentially change all the door thresholds. Are the doors and windows high enough to accommodate this? On upper levels screed generally works better than spreader plates but it's heavier. The temperature is more controlled and slowly released with screed. You've to make sure the existing floor can support the weight of the screed. If you've only 50mm insulation in the cavity and go the internal insulation route with 50mm you'll probably need heating in the attic as you'll have a fairly high heat loss. It's not a super insulated house where the heat rises into the attic. If you fill the cavity and externally insulation with another 100 or more and have good airtightness you can look at not heating the attic.
  8. On top of the deck would be the vapour layer, then PIR, then the membrane.
  9. I think it's not a question of the mesh available it's more a question of the quality of the bricklayer. I can't imagine a bricklayer taking the time to put in the mesh well. You also can't check the quality of the installation as it's hidden in a cavity. Also mortar is heavy and any drops into the cavity will compress the foam insulation a lot. If it was a timber frame structure with block outer that's fine but I don't see a need to use mineral wool insulation batt in a blockwork cavity. I'd fill the cavity with beads as suggested above.
  10. I first used AliExpress about 6 years ago when I purchased a memory card when they were still expensive for a digital camera. Saved a load. It was $5 so wasn't a big deal if it didn't turn up. Worked great and have made loads of purchases since. Screwdriver drill bits, cables, pencils, digital thermometers and even a phone and phone covers. The phone is xiaomi which is a well known brand not available here. Still have it as my main phone two and a half years later. Only about $100 which is great when you consider the price of top end Samsung and iPhones here. This year I've bought loads of lights. I bought one spot light first to check it's quality, brightness, light colour and get the other half to approve it aesthetically. I then went and bought another 50 or so but in batches of 10-20. If you buy then in batches you'll sail right through customs as larger boxes and orders have more chance of getting stopped by customs. Delivery is long (2-3 weeks) so you can't be in a rush. If you get DHL or another courier it will get stopped by customs no matter what the package. I've since got kitchen island pendants, dining table pendant, wall lights and really happy with all I've purchased. I've to get more lights for the bedrooms and a large one for above the stairs. I've a few pages on aliexpress bookmarked and will be getting them over the next few weeks. Another thing I'm considering purchasing soon is replica designer furniture. Original certified replicas of classics can cost thousands while Chinese replicas can be got for a fraction of the price. I've a Eames DSW chair from Vitra that was several hundred and 4 replicas that cost $30 each. The real is better quality but not enough to justify the huge price difference. I'm looking at a designer coffee table, bedside lockers and a few other bits. Would happily recommend buying Chinese imports for a lot of stuff.
  11. Have this in my house. Have it on a standard immersion timer currently as it's not long in and still slowly raising the temperature of the slab. Haven't needed it much yet as the heating season is only starting. Plan to connect it to a thermostat on the wall in the soon somehow. How would I go about connecting this to a wall thermostat? I've a three core and earth and a cat-6 cable going to where I want the wall stat in the main living area. Want something simple and not overly complicated to go with the simple heating element.
  12. You still need an airtight layer which the vapour control barrier performs. Having that tight between the plasterboard and underside of the PIR will mean it will have thousands of holes in it from fixing the plasterboard making it useless. I wouldn't use 12x38mm timber counter battens. Timber is cheap in the grand scheme of things and the labor involved won't change. 12mm is very thin and will split from the fixings that go through it. Remember it has fixings that will be circa 150mm long if not more so probably 5 or 6mm diameter that go through the insulation into the rafters. Then additional fixings to secure the tiling battens. If the tiling battens are only fixed to the counter battens, which is usually the case, and not fixed back through the insulation into the rafters then you'll have the tiles supported on thin 12mm timber. First storm and the roof will come off.
  13. You need plasterboard then battens to form service cavity. It will need to be large battens (75-100mm) if you've MVHR or just about 35mm if only electrics and recessed ceiling lights. Then vapour control layer and the 180mm pir insulation inc rafters, counter-battens, tile battens, tiles, etc. The 38mm counter-batten is required to prevent water pooling behind the tile batten and allow ventilation so yes it's required. Very long screws to fix through the insulation.
  14. Is the cafe used for preparing food? It complying with environment and health regulations is far more important than colour. Don't know the UK regs but in Ireland you pretty much have to put down some none slip vinyl in the food prep area unless you get a very smooth finish on the concrete which still has a slip resistance. I can't imagine an 'old barn' wall would pass either and at the least would need a smooth plaster finish if not whiterock, tiling or other cleanable smooth surface. If you don't know the regs I'd contact the local food safety officer and see what they want for the kitchen / food prep area.
  15. I dealt with Joan Pisanek who was helpful. Obviously don't want to post contact details publicly but if you ring SunAmp and ask for the direct contact number or email that will work.
  16. For me they arranged international shipping. I presume the same would apply to France. Its a house refurbishment so don't have to comply with new energy regulations. Also as an architect I can sign off anything I want on my own house.
  17. Happy retirement. I join the SunAmp club when mine arrives tomorrow. Think it's the first in the Republic of Ireland.
  18. Worked on a theater and in the backstage area we wanted very durable dressing room worktops. No matter what manufactures tell you about easy to clean surfaces they're mostly designed for food based stuff like wine, coffee, sauces, etc. I gave samples of different products to the girls in our office and all products failed when attached with makeup. Ended up going with an industrial vinyl floor covering on the worktops.
  19. I encounter this question regularly (just out of a meeting this morning on this for a client who's mechanically fixing a Bauder membrane on the laps through the PIR into the WBP deck). One question asks loads of questions. What's the build up on top of the PIR? That's more important. If you've a roof membrane that's mechanically fixed then it will have to be fixed through the PIR to the structure below. What thickness is the OSB? If the structure it's fixing to is the OSB then will the pull out strength be enough? You'll get a stronger fixing from ply and you'll spend ages looking for the structure behing trying to fix back to that. What's the uplift and wind load? If the roof is sedium it's weight will hold it down. If the roof membrane is stuck to the PIR then the PIR needs to have a certain bonding strength. This is easy to achieve and certify by thermally broken fixings at xxx centers but how do you get that from foam? Who's going to certify how much foam you need and sign off on it?
  20. Some local authorities already have this in Ireland for a while already. Dun Laoghaire (an affluent area of south Dublin) brought in a passive house standard for all new builds. This was later modified to Passive house or Equivalent as not all buildings could meet the certified passive house standard due to site or other usage conditions. https://www.irishtimes.com/news/environment/new-buildings-in-dun-laoghaire-must-adopt-low-energy-standards-1.2103215
  21. Have a 5.5 meter long Internorm lift and slide. Did a lot of research at the time comparing quotes and very happy with it. I've installed it flush with a polished concrete floor. Yes it wasn't cheap but my issue was not many companies could do one 5.5 meters long without dividing it into smaller parts. At 3.8 meters you might have more luck. You can go for Internorm PVC with aluclad instead of the timber with aluclad and save a bit if that helps.
  22. It depends on the type of grass roof you want. You’ve three broad types. Lightweight which is about 1 or 2 inches of soil that contains sedum plants and mosses. This requires very little maintenance and isn’t suitable for regular access as the soil is so thin. The next is extensive green roofs which are deeper (about 3 to 7 inches) which allows you to plant grass and flowers and you can walk out onto. This needs a little more maintenance but not much. Then you’ve intensive which is anything bigger. This allows you to have a real garden with paving areas, grassed areas, shrubs, etc. The maintenance is like a regular garden cutting the grass and trimming shrubs if needed. The heavier the roof the more structure you need and the more expensive it gets. You’ll also need handrails and parapets for when people are using the roof. The lightweight sedum roofs are relatively cheap and can be on a timber frame structure. They come with their own build up of layers and are relatively easy. The key point is it’s all installed correctly as like any roof finding a leak later is difficult. Presuming you don’t need access and the lightweight is OK for you then it should be about the same price or not far off. They don’t need handrails as they don’t have regular access. The heavier grass roofs get very expensive. I’m not sure I’d trust the regular roofer down the road with a zinc roof. Slates sure but not zinc. The same is for a green roof but the layers and build up of a green roof are now relatively easy to lay and install. Environmentally and aesthetically the green roof I think is better and what I’d go with. If you’ve high bedroom windows that look out over a flat roof it’s nicer to look out over a grass roof than slates or zinc.
  23. Looks a lot better. Bedroom 2 & 3 are closer to rectandular (with small entrances) rather than the difficult L shaped previously and the Master Suite is still a considerable size. What's the small little room creating the third middle door between the bedrooms off the landing? Is it needed as you didn't previously have it? It's created a lot of doors in a row squashed together.
  24. It's not that they're cramped. It's just they're 'small' when compared to the master suite. Having one bedroom, dressing area and ensuite larger than the two next bedrooms is out of proportion for the house. You kinda have a problem as you've too much space in the master suite. Not sure what stage you're at. If it's still early design I'd swap the master suite to the left. If it's first fix just continue and try and resolve the ensuite.
  25. I've gone through through thousands. Opened up the screwfix excel sheet and filtered just wood screws just now to check for my own interest. This is just for my own house refurb over the past 18 months. Drylining internally with service cavity. New stud walls upstairs, etc. Haven't used nails. Size - Total purchased to date 16mm - 400 20mm - 400 30mm - 600 40mm - 800 50mm - 600 60mm - 700 70mm - 3500 80mm - 1600 100mm - 600 I've one or two full boxes of 40mm but everything else I've about half a box or none left. Buying a trade case like linked to above is a great start and just keep topping it up. Choice is great and for example if you have a a location and 50mm is just a tiny bit too short or long it's great having some 40 and 60mm to use. In general they've very cheap so I stock up on them all. I'm afraid to check how many drywall screws I've gone through. Also used a lot of concrete screws and special screws for timber floors not included above.
