Mr Punter
    27
  1. I have installed a pump station in the past. Although you can go for very expensive pumps, 2 pump systems, rail mount etc I think it is sometimes more practical to just have a fairly inexpensive single pump with chain plus a spare stored in the house. Don't bother with servicing. If the pump fails, swap it out.
  2. I guess if your bathroom does not have a window, turning off the MVHR would be a bad plan.
  3. A friend does these. He likes FAAC for the openers and Videx for the intercom. I have a Videx intercom on the front door and have had them fitted elsewhere, including gates. No issues.
  4. No. When you commence development, the planning consent is locked in. PD rights come into play when the scheme is complete.
  5. You don't have PD rights until the building is completed so if you carried the work out before it would not be PD. The LA may ask you to apply for a Certificate of Lawfulness or full planning consent, although they would probably not know unless a neighbour objected. There are different types of PD, so involving neighbour consultations and it is these that could be an issue. If you sell the property and have not got full consent on what has been built, the other side may kick up a fuss. If you have knowingly sold without planning consent and told the other side you have fully complied, you may be in breach of contract.
  6. Those slabs look like an osteopath's dream! I always go with advice from https://www.pavingexpert.com/
  7. The difficulty with a specialist product is having a reliable local supplier. This looks like a natural slate in special sizes and it could be a real pain if you run short of the odd clip or trim and find it takes 3 months and you need to order a pallet load.
  8. I have done a basement in ICF. We used Polarwall. You need to make sure your warranty company is OK with it. You must use type C internal drained cavity membrane and pump, as it is not possible to guarantee that the concrete is contiguous in the forms. The reinforcing and concrete thicknesses is the same as if you did normal shuttered RC walls. We used Easi Joist floor above and this was treated as "partially propped" for the structural calcs. We did timber frame above. The basement was the same footprint as the floors above plus a light well.
  9. Hi Helen I am also in Sussex. Have you got planning consent for a design you are happy with? Scandia Hus do fairly standard timber frame and can be quite expensive but worth keeping on the list for comparisons.
  10. I have some friends where you go up 12 steps to the front door. The steps are about a metre wide and have a landing half way with handrail either side, so you don't really notice. Having the wide flight on this project did it no favours.
  11. Why not build it and see what happens? Unless a neighbour decides to be tricky it will be OK. In reality you are not compromising anyone's health and safety. It is your land.
  12. You will need a warranty or Professional Consultant Certificate if you think you will sell or finance in the next 10 years. The PCC route is fairly cheap and can be done retrospectively if needed.
  13. I like the design. Have you looked at doing a blog on here?
  14. Within a metre it needs to be non-combustible, so the log cabin is out.
  15. I see MBC Timber Frame have a similar roof design: https://www.mbctimberframe.co.uk/passive-house/passive-roof/
  16. It does not matter if you are within 6 metres UNLESS your foundation / walls cut through the imaginary 45 degree line. Unlikely unless you are piling or within 3 metres of their building. Party Wall matters can be expensive and time consuming, so if you do not have to do it, don't.
  17. The membrane is heavy. Don't try to do it on your own. You need a fall on the roof of at least 1:60 so on your joists you could run firrings in one direction and then your battens at right angles to the firrings. If you go with the cold roof (which is far from ideal) you will need a very well installed vapour control layer under the joists to stop warm moist air condensing in the cellulose. Have a service cavity for light cables as well. The ventilation around the parapet is quite hard to achieve but changing the wall battens from horizontal to vertical would help.
  18. It is hard to see without seeing more of the plan or elevation. I think you will need to alter this or get refused planning. You could move this to the right, reduce the depth etc. Is that a door to the kitchen? Can it be glazed? You will probably need to move some pipework but it should not be a huge issue. What does your architect suggest?
  19. Nice. Who was the steel fabricator? I thought you had almost finished. What the hell are you building now?
  20. If you are not interested in ROI and cannot put a value on your consuming home grown energy it is difficult to give an answer. It probably depends how much money you have! Can you not get a bigger inverter now and add panels later or is that not how it works? If it were me I would buy the 8K as it is a small price to pay to feel smug and virtuous.
  21. Would it be terrible to move the kitchen window over 700mm or so and shift the whole thing along?
  22. You would not normally need insulation to a floor above a basement. Bear in mind that the basement design may need a certain floor type to help support the walls. You will need to be careful if you have a suspended floor in the other part of the house as it would normally be ventilated and therefore cannot connect to the basement part. As per @Bitpipe, a full basement saves quite a few issues.
  23. Make sure you paint the ceiling first.
  24. I am surprised it is so cheap. Is that supply only? Does it cover all materials? As it is only single storey it may be fairly easy to add panels later, when they may become cheaper / more efficient, so could you go for the 4K and allow for later add-on?
  25. https://www.bbc.co.uk/news/uk-england-london-54794723 I hope the insurance policy had a very large amount of cover as this could cost tens of millions. Property values in this street are £30,000 per metre! https://www.standard.co.uk/news/london/two-houses-collapse-basement-work-chelsea-b43428.html
