Mr Punter
    27
  1. Unless you are doing this as a business I don't see the point. You can easily keep a record of expenses. It may be worth getting someone to do your VAT reclaim.
  2. The services would be best in ducting and covered over with sand.
  3. 8mm deflection is good. They will often spec 12mm, which is the maximum for NHBC / mass produced cheap housing and can feel bouncy.
  4. If you have CAT5 you can add a proper access point(s) to give you wider wifi coverage without any lowering of signal / drop out / SSID name issues - just seamless wifi throughout.
  5. I have bought the sliding door wardrobes. They doors are made to measure. They run on a bottom rail. There is a ceiling track which is fairly deep and keeps the top of the doors in place. They can have soft close each end. They often come with a rail or shelf kit. This kind of thing https://www.slidewardrobesdirect.co.uk
  6. Unintended!
  7. Why not use both sides of the steels? Is downstairs completely open plan, so not even somewhere for a column or 2? For all this you are still left with joists over 4m long.
  8. You could be Scotland's answer to Nicholas Hoogstraten: https://www.dailymail.co.uk/news/article-6443949/40m-mansion-home-left-rot-33-years-friend-Robert-Mugabe-remains-dilapidated.html
  9. Great result. Hopefully you managed to progress the rest of the planning in the meantime and are primed and ready to go.
  10. Another vote for 1 then
  11. I would prefer 2 x shower rooms en suite and 1 shared bathroom with bath and shower. I think you could have a re-jig. Can any en-suites go back-to-back? May be simpler to plumb. What is the small internal room 2.7m without a door in the first one? If you got rid of it it may be a nice space for desk / sofa.
  12. Why not offer your neighbour £500 if he agrees to the work without a Party Wall Award? I have to do some works that fall under this and there are 4 neighbouring properties. I am tempted to offer the cash to them.
  13. Afraid so. He doesn't even need to object, just not agree or reply. If you can both use the same surveyor the fees can be less.
  14. They will still be counted as foundations and will not be treated differently. I know it will have no effect on your neighbour's property, but it is the law. Originally for tight knit housing in London it has been adopted for the whole of the UK. A nice earner for the surveyors. Get a price from them first.
  15. No real choice I am afraid. I don't know why people think it offers them any protection. I guess at least the job has been looked at by quasi professionals and an award produced. If you go ahead without a Party Wall Award or agreement from the Adjoining Owner he can opt to seek an injunction. It is fairly costly for him to do but if he succeeds you are stuffed. Judges take a dim view of Building Owners ignoring the Act. It doesn't really matter how deep his foundations are unless his are also piled. If you are piling within 6 metres you need to follow the Party Wall Act. As a P.S. In the past I have just gone ahead in the past at the risk of being injuncted. I guess they thought they had more to lose if they failed in court so they did not do it. Piling was done in a couple of days. We paid to decorate their living room, which was the other side of the house.
  16. A 4" grinder and a steady hand. Mark the square neatly and overlap the lines a bit. Cut one side up to the corners, then turn the tile over to complete the cuts.
  17. You can get attic trusses with EasyJoist bottom chords so you can run services through them. You cannot otherwise drill any part of them without written agreement from the designer.
  18. Agreed with @Temp. The simple exchange of letters will save you at least £1,000 in fees.
  19. If the ground is nice and solid it is an ideal way to do it, as long as you don't want to build any heavy partitions. For some reason on a new build they will insist on a concrete slab. It is not needed.
  20. He is using Hi Therm lintels.
  21. What is the budget? Insulation and airtightness/controlled ventilation will be key to better energy efficiency. Would you look at external wall insulation?
  22. +1 another vote for medium weight aggregate blocks 7N
  23. The £40 in N. Ireland could easily be £100+ in SE England. Resin works well as used by @Bitpipe and
  24. Also bear in mind that when these fail the tank full of sewage is not all that bad. Maybe I have poor sense of smell but lots of it will be water from showers, dishwasher, laundry. Obvs a fair mix of floaters but the contents are regularly pumped away.
