Mr Punter
    27
  1. I would have a chat to building control and if push comes to shove chop a 45 degree angle off the bottom corner of the offending joist.
  2. I use an architect who is very good at gaining planning consent. He is not interested in progressing the project any further, unless the clients wants this, as there are others out there who are better and cheaper for this.
  3. I have done some of these a few years back. We were only moving down one band and had a comparable or two so they didn't put up a fight.
  4. Yes. When the bungalow is demolished you can have it removed from the register. Your Council may deem when the new building should be completed, so they may start the new CT before actual completion.
  5. There is a LABC warranty scheme. Still expensive.
  6. Get a couple of other merchants to quote as well. Play one against the other. Free delivery too. And low charge for restocking should you wish to return anything, or you will end up with lots of bits and pieces you will never use (not that I ever have!)
  7. Is the water running off the parapet coping as well? There is not much wall above the window so the problem maybe stems from the roof.
  8. The simplest way to do this may be to obtain planning consent and sell the plot to others on the basis that they complete the project within an agreed time, then use some of the proceeds to do up the bungalow.
  9. Can you remove the trees that are causing an issue BEFORE you do your planning application? In my experience, the willows could cause major issues and would be better off removed.
  10. I don't think the CDM role of principal designer would have anything to do with this.
  11. It is fairly risk free to do type C. You lose a small amount of floor space as you have to build a metal stud wall inside the membrane. If you line it first with OSB you will not have issues fixing things to it. You need to form a sump and install pumps in it. I would not spend the extra money on waterproof concrete and external tanking if you have internal as well. Some on here @Bitpipe? have gone without the internal membrane and had it fully guaranteed.
  12. Yes, the CML cert is fine for most lenders. Get a price from the suggested builder and if it is OK see if you can meet with some of their customers before you decide.
  13. Looking at the plots nearby you could get another 4 on there.
  14. Second one looked a lot better.
  15. A shame about the architect. You can sometimes do well looking at your local planning website for new house developments to see who is successful with PP and if you like the style. The plot looks very generous for a single house. I guess you have looked into splitting it, which could help with the cost of the project?
  16. Maybe Uncle Nick tiled the showroom? If they don't work either way, take them back and get something else.
  17. Yes they do. The correct order.
  18. The tiles have double and single width stripes. They need to butt up to the same width stripes, then you know it is the correct way round.
  19. OK the showroom has laid the tiles correctly. You have not. Your top tile need rotating 180 deg. So does the bottom one.
  20. If it is asbestos it is usually fine if it not disturbed. If you need to work on it you can carefully remove a small sample and send it for testing. If you or anyone has already worked on it there is nothing to be done to mitigate this but unlikely to be harmful.
  21. Yes you can fit 22mm P5 chipboard flooring to the ground floor joists. Make sure all joists are sound and there is good airflow beneath.
  22. The one in the last picture is quite an achievement.
  23. It did not improve the image of architects. They did not make the ugly bit any better and in fact spent almost no time or money on it. Just added an unpleasant extension at strange angles. Given the £200k + and three years, it was woeful.
  24. The truss people sometimes offer treated timber as an option.
  25. I would just use brown plugs and 5mm screws. You will need to pilot a smaller hole through the strap, then bend out the way and go with the 6.5. I would not go any higher than I can reach without a hop up. It can be easy to displace the top block if it has no load above. The wind uplift is a bigger deal with lightweight flat roofs than pitched and tiled.
