Mr Punter
New build water calcs - I don't get it
Mr Punter replied to dysty42's topic in General Self Build & DIY Discussion
If you have a hundred 5l toilets and 1 person flushes once a day it is 5l per person per day. If you have one 5l toilet and 80 people flush once a day it is 5l per person per day. -
If you lay MOT first you will need to sacrifice a fair bit as it will be contaminated when you dig your trenches and even a bit when they install the piles.
If the piling rig is OK on your existing ground and that is confirmed by the contractor, do piling, then services then MOT / sand. Sometimes the bigger piling rigs need loads of ground preparation.
https://www.theguardian.com/environment/2020/sep/29/dual-flush-toilets-wasting-more-water-than-they-save -
I think it is accepted that these regs are a bit silly and not really what building regs are about (Health and Safety) which this bit has become self cert. I heard recently that the new WC cisterns can often use more water than their old counterparts because people are unaware when there is a leak of water from the cistern into the pan. -
Because a person will only use on loo at a time, so consumption is not altered by the number of loos, just their efficiency. They will take an average efficiency if there is more than one. -
See if they will accept a Professional Consultant Certificate.
I don't believe you need the calculator, just a written statement saying "I confirm that water consumption is calculated at less than 125 litres/person/day using fittings approach”. -
That looks a fair bit neater than the first one you did. Less adhesive in the grout gap. Can you promise not to use piss yellow grout this time? It that a very big l-shape to the left of the mirror or did you cheat?
25 years with the StormDry and it is non-hazardous and BBA approved.
+1 It is fairly pricey but works very well and is long lasting. It is not the quickest to apply but will leave the wall breathable but rainwater will form beads and run off. It goes quite a long way.
Cladding details
Mr Punter replied to Russell griffiths's topic in General Self Build & DIY Discussion
I have used the Hardie starter strip. It give the bottom board a kick provides ventilation and insect / rodent barrier. It comes in different sizes according to your batten size. https://www.squaredealupvcshop.co.uk/product/hardieplank-starter-strip-with-ventilation/ -
Permitted Development During Build
Mr Punter replied to MortarThePoint's topic in Planning Permission
The consented scheme needs to be completed before PD rights can be exercised. -
I hope this is not the same solicitor who advised you on the purchase? The seller specifically limiting your ability to connect drainage should have been very clearly communicated to you by your lawyer. That is what they get paid for. They have PI insurance for this sort of negligent blunder.
Did you choose HiTherm for the SAP friendly psi values? What insulation are you using? I am considering using some for a 150mm cavity with eps beads. Only a few in brickwork. The rest is rendered and I will use 2 x concrete ones.
I would go with the load table and option 3. I could not view the pdf.
+1 Send your lintel schedule to 2 or 3 suppliers well in advance. It is a big discount market and you can get really stiffed if you need one in a hurry.
You can step brickwork in and out by a fair amount without any structural issues. I have seen chimneys held up by corbelling 350mm. It is not considered be practice but it holds up. 50mm would not cause structural issues. The industry standard tolerances in construction are pretty lax. If the standard is +-30mm it could be 59mm out and still be acceptable. To be structurally unsound it would need to be out by a very large margin. You need to choose your battles here, because if the majority of your complaints can easily be countered you may just lose all of them.
I don't think that SAP is keen on air-to-air.
Ugly House to Lovely House New Series
Mr Punter replied to Ferdinand's topic in Property TV Programmes
I enjoyed the previous ones because the results were so bad and it was fun to slag off the architects in their collarless shirts. Last night was disappointing as the architects were not precious, listened to the client and the solution was near to budget. Where is the sport in that? -
Space heating in a properly built new house or flat is not tricky or energy hungry. Hot water and solar overheating can be bigger issues. Air tightness can be more significant than insulation.
You don't need to chop the joist, just shave a bit from the bottom so it is at 45 degrees.
You are going to be a busy boy. I suggest the extra Shredded Wheat is in order.
+1 Get the engineer back. I have done work on existing to engineer spec and had "issues" when removing what was thought to be a non-structural wall. Looks quite dry down there, which is good.
