Mr Punter
    27
  1. Sadly it will be gas combi boilers x 3 I think.
  2. I am afraid I will need to have gas to get the SAP to work.
  3. The one I fitted just has a high level alarm. The backup pump ones are for larger pump stations serving more than one property. They are very onerous with servicing and maintenance. Easier just to just buy a spare pump and change it if it breaks, or buy it after / if it breaks but you cannot use the downstairs WC for a few days.
  4. Front doors traditionally open inwards. Rather better for inviting guests in. Also means if a delivery is left in front of the door it can still be opened. Security should be the same whichever. I could not get into my house without a key.
  5. This could be condensation. Was there any furniture in front of this? Has the house had cavity wall insulation? Are the external levels at least 150mm lower than your floor and the DPC?
  6. I don't know the difference in levels. If it is more than 50mm, lay insulation thickness to suit, 22mm chipboard flooring and glue the parquet to the chipboard.
  7. Metal gates will be better for having far less wind resistance. Not good for privacy though.
  8. I never have any issues with the signal. I thought I may need 1 per floor, but the 2 I have cover 4 floors plus roof terrace.
  9. I have 2 of the Ubiquiti ac lites and they have been really reliable in a 4 storey house. I have one on level 1and level 3 and get seamless wifi everywhere. I understand the mesh things have come a long way of late but I bought one a while ago which was DOA.
  10. I have Makita 18v and a corded. I am not fond of the noise but handy for some things. Never use the corded now.
  11. It should be but it varies. Best bet is to ask the planners to confirm. I have known small demolition to count on a multimillion scheme, sometimes new site access, sometimes piling where they install 3 piles and bugger off for a few years.
  12. Roll out rafter tray
  13. It is still a flue in a void within the building envelope so it would need inspecting.
  14. It is worth bearing in mind that the roof does not normally require fire resistance.
  15. I have just fitted the cheapo plastic ones, although it was where the flue was boxed in normal MDF, so no fire rating needed.
  16. Why would that matter? They just need to be able to inspect the flue.
  17. Yep. It is sometimes a pain to do the calculation but your survey may also reference some existing points, like chamber covers in the road, which can help you when setting out to make sure your floor levels etc correspond to your plans.
  18. Metres above ordnance datum.
  19. If this is a full planning application and not class q permitted development I doubt it would make much difference what the current use is. I can't understand why you gave them a right of access as you clearly do not get on with them. If you object to their application you are unlikely to be popping over to borrow a cup of sugar anytime soon.
  20. If the other property has a right of access it will not normally be limited and it could be used to access any number of new dwellings.
  21. I have fitted a mini pump station in a basement. It is a tank that we semi recessed into the floor and contains a pump with a float switch. The outlet is large enough not to need a macerater. It is quiet when it operates. It was a bit like https://www.drainstore.com/pumping-stations-pumps/mini-micro-small-sewage-pumping-station-for-extensions-and-garden-rooms-190-litre-capacity/
  22. Leave some bricks out at the bottom and rake it clean? Not sure how practical this is though. On my current project we the upper floors are built off a wide steel plate so will need a cavity tray at the bottom.
  23. Do you favour beads or batts for the rest of the wall?
  24. The eps beads go down to 0.032 lambda which is the same as the best fibre batts. There is also little risk of gaps or missing pieces. I am not sure about price though. Someone @Brickie? mentioned that with a wide cavity it is easier to use batts as they support the wall ties which otherwise lose their balance and there may therefore be a temptation to just push the ties into the joints.
  25. If you are motivated and hard working you should do OK. Working for a smaller firm is probably nicer than a big contractor. I am always happy when I find someone who works hard, does a decent job and does not bitch and moan.
