Mr Punter
    27
  1. What is your budget? Are you looking for a fully finished doorset, or just doors? I have had a place with lots of 926 doors and they will work well for wheelchair access. It is apparently best if there is a nib of wall at least 200mm on the handle side of the door.
  2. They do all sorts of edge trims and drip profiles to finish this off at verges and eaves. You don't need loads of rubber overhang. I hope he is not claiming that it is finished.
  3. Lots of pre-cut firrings are set to this. 1:40 eats into a lot of sky on a flat roof if it is large.
  4. Your firrings should give you a 1 in 60 fall, so if the high point is in the middle of the 5.5m it will be about 100mm higher than the lowest points.
  5. Is this a current photo? Why not just do a proper warm roof? You may need a lower door and higher upstands for the rooflights.
  6. On a big roof you can get a lot of extra build up with the firrings.
  7. Looking at the drawings I cannot see any firrings to create the required fall on the roof.
  8. I would try to span the roof between your panels rather than on a beam. Could you then get rid of the goalposts and extra footings? Flitch beam is a good plan to span the top of the opening.
  9. He is prime suspect. He touched it last.
  10. These projected 300mm. Much more and you may need brackets or other support.
  11. Good for boxings, cladding (with a no-mar nose), battens and noggins on timber frame. You can fire them by pulling the nose back. Not encouraged on my sites. Beware of hitting knots in the wood and having your hand in the vicinity as the nails can twist and come out at right angles.
  12. Was suggested to me for stabilising a river wall. It was a similar cost to formwork in the end and the finish was not what I was after. I have seen it used for tunnels as well.
  13. I had not realised the OP had already had some of the roof done, so too late.
  14. Fit abutment ventilators to the perimeter.
  15. I would fully fill the joists with rigid insulation and foam it in tight. Polythene carefully under the bottom and up the sides of the insulated area, then plasterboard. No insulation on top. Cold deck.
  16. Timber frame with rigid insulation and OSB sheathing will work fine. The sides can carry most of the load.
  17. Even though this is a self-build forum I do appreciate your crusade against this developer. There may be other sites that are more suited to your goals but I am keen to be kept up to date with this issue. One of the primary reasons people opt to self build is that they cannot trust the housebashers.
  18. I have had similar in the past. We drained into an old well and used a pump with a float switch to pump up to a ditch. A few houses along the road had covered over the ditch for their driveway crossovers but I think they have cleared them out since.
  19. You may need to do something as a compromise as at the moment you are proposing piping all the surface water direct to the sewer with no attenuation. So a holding tank, a bit of ground infiltration, a few permeable surfaces, directing to a drainage ditch, will all help.
  20. The metal roof looks very good indeed. I am amazed you have the energy left for that punchbag!
  21. Because if everyone did it the sewer would be overwhelmed in a storm. Also the mix of product at a treatment works becomes very variable.
  22. Would it be easier to do the pads with a concrete mixer, chock up and bolt down the base plates so your goal post is nice and level, then pour the rest with readymix? Don't want to be messing with heavy bits of steel and finishing concrete on the same day.
  23. If it is a zipped seam the halters holding the roof panels should space them away from the substrate. If it is flat to the substrate you could maybe use a membrane like they do on some zinc roofs, where the membrane is covered in coarse plastic extrusions or dimples that support the panels and leave a gap for air and drainage.
  24. You are supposed to consider these options in order for surface water: On site via soakaway / permeable surfaces To a watercourse A surface water sewer A combined sewer In exceptional circumstances, a foul sewer
  25. Could you have a fairly flat attenuation tank at high level with a small discharge at the bottom to the sewer and a large sized discharge at the top, so the tank will have to be full before you discharge at full rate and the tank will empty over time?
