Mr Punter
I would want to extend the main if possible. I have a block of 8 converted flats and noticed the other day that they are all served by a single 15mm supply, teed off to 8 meters!
I assume the developer ltd co will go skint but I wonder where the house owners will stand? I would think the directors may face some personal liability. Did the architect have any say? Very odd that this was such a mammoth blunder. The conveyancing solicitor will normally want to see that all planning conditions and building regulations have been complied with before completion of the purchase.
If the wall is nice and dry the OSB should be fine. I would not bother with a vapour barrier as I am not sure what vapour flow you would want to stop. They are often used on the warm side of insulation to control warm moist internal air from condensing in the insulation or the structure but this is not what you have as it is an uninsulated party wall.
- 2 replies
- kitchen
- plastering
Yes radon barrier goes right over the slab. The green polythene is not a gas membrane. It looks like a separation layer to isolate the screed from the concrete so you have an unbonded screed.
That mesh is heavy duty. Space your mars bars and deck chairs at about 1200 and you will be OK. I hope you have a machine to lift the mesh in.
Funny that readymix concrete is not in the same position.
Planning refused: entrance deemed too grand!
Mr Punter replied to albion2021's topic in Planning Permission
Just do whatever you have to. Apply later for a revised entrance location and fight about that once you have your house agreed. -
That looks like a haven for rats. Unless the ground conditions dictate piled foundations, just do strip footings and raised beam and block.
You will need either to elevate the building or have a sacrificial floor, like parking etc. For 1m I would just elevate and where possible build up the surrounding ground levels. Only 4 courses of blocks so no biggie.
I would go with barb wire or stock fence and round wooden posts, 6m setback maybe with some rural mix hedgerow. The name of the game is to get consent and get the house built. -
60mm batten for render board
Mr Punter replied to Ryan Bazeley's topic in General Construction Issues
Best to use the same batten where the boards join. -
Flat roof considerations: Safety, Rain and Shine
Mr Punter replied to puntloos's topic in Flat Roofs
Kerb - upstand. Not curb - restriction. I think I must have come over all American. -
No issues doing this in 110mm. With bathrooms, you could bring up a stub stack with a dirgo instead of lots of separate connections. If possible I prefer to have the below ground outside the footprint so you could look at having a run on the right for the future bathroom and coming across the front to the main run.
That is how I refer to plumbers collectively too!
I would reduce the size of the rooflight as you will end up with lots of unwanted solar gain at the top of the house. I have had a Velux with a curb electrically operated in a stairwell and that worked well. You do not need to go outside to clean them as they flip round to give you access internally. They do electric blinds and external shutters as well. I think most of their electric stuff can be solar powered if you want to retrofit the functionality but have no run the power. Velux also do a flat roof rooflight without a curb but they don't seem quite as good. -
Cracks after roof replacement
Mr Punter replied to Jp21's topic in General Self Build & DIY Discussion
The mounting plate for the smoke alarm is still fixed to the ceiling. The crack near the door looks like it has been there for years and is harmless. The bay is not structural. -
New member problems with kitchen extension
Mr Punter replied to Bobby Dazzler's topic in Introduce Yourself
As others have said, you probably will not need a Party Wall award and the fees and time that would cost. A couple of trial holes down to the base of their foundations would be all your engineer and Building Control would need to establish that foundations at the same depth would be structurally acceptable. Regarding the access for inspection, not really an issue and this could be carried out at ground level or a small scaffold tower could be erected. As long as they have access it is up to them how to do the inspection. -
I have not been able to find 2400 x 600 TG4 ply or OSB thicker than 18mm. I was hoping to get it at 22mm.
You need the battens as you have to incorporate a drained and ventilated cavity.
Weather resistant cladding in coastal location
Mr Punter replied to Homer's topic in Introduce Yourself
These are often factory finished with paint apart from the ones that are concealed. -
Main bedroom suite layout design ideas
Mr Punter replied to Adam2's topic in New House & Self Build Design
Mainly plan A for me but it is a personal choice. Don't underestimate the space the MVHR can take up. You need to be able to access quite a large space on some to remove filters, heat exchanger etc. Give that they can make a bit of noise it may be better in the landing. UFH manifold can be quite warm, depending on setup and pipe runs. I don't like pocket doors much. They are fiddly to operate and fit and you are very limited to handles etc. Will you normally leave them open? I can imagine getting up to use the bathroom and running in to one of those. Another one against the island bed. May be better against the top wall. There would be plenty of space left that you could have a sitting area for coffee & papers or pre dinner drinks. -
Wow. Eight months for some minor amendments. A badly broken system.
Because it is structural you will need calcs for these. Best to contact a truss designer / manufacturer. 8m span is large. There are lots of online design / quote sites so you will get some idea of what you can do and what it might cost.
