Mr Punter
    27
  1. Yes the composite ones stay in place better.
  2. I would just use a couple of furfix / wall starters spaced 60mm apart for that bit. 5 minutes work.
  3. Where does the downpipe connect to internally? Can you not excavate to connect to the same pipe underground but have an external gutter and downpipe?
  4. Hope they had a load of retarder in the mortar...
  5. I like cooker hoods to have stainless steel grease filters that go in the dishwasher and are externally vented via min 150 dia ducting.
  6. Does not look like you will need to dig down too far - maybe a metre?
  7. The rule seems to be only mastic the outside. In this case, just run the mastic up 50mm vertically between the glass and the profile and any water in the profile should drain back out into the tray.
  8. You will not get a premium for eco stuff. Nobody looks at an epc. MVHR is just another thing to go wrong. Timber frame and brick or block outer leaf is acceptable to most. Sounds like you already have a tiled pitched roof. I am not sure if metal floor, Hardie cladding and renderboard is a great deal kinder to the environment.
  9. At least if you are the one who plasterboards the ceilings you will not struggle to find a joist.
  10. I would get rid of that arrangement and have an external gutter and downpipe.
  11. Raised platforms are often an issue if they overlook other private gardens. Had you repaired this in stages, you may have been OK. If they issue an enforcement notice you can appeal it.
  12. Which is why it also needs to be less than 0.002 x span, or are you saying 8mm is too strict for longer spans?
  13. That is why I like to specify a maximum deflection of 8mm or 0.002 x span (whichever is least).
  14. Tiles, adhesive and flooring. We either borrowed a pallet truck or used the one from the pallet delivery company. Any edge more than 15mm will stop it dead. It is a bit like pushing a car. I would not go for this to move a load of blocks 50m.
  15. Most of the regs have a section for conversion / change of use. Often it is do not make it worse. Mostly more lenient than new build. Best go for a full plans application, rather than a building notice.
  16. You will be fine if it is level or slightly down hill.
  17. Often 72 blocks in a pack.
  18. I am pleased to see people specifying 8mm max deflection. If you need to install rigid pipes or ducting through these, do it NOW. You could blow in thermal insulation - either fibre or polystyrene. If you do the latter you will not be able to have PVC cables in that zone.
  19. I have borrowed a hand pallet truck in the past. Lots of shops have them. Used it to move an annoyingly parked car that was blocking the way and the more standard pallets of materials. They weigh a fair amount and need a flat surface. As you know blocks don't always arrive on a pallet.
  20. Quite a few composite windows (like Velfac and Ideal Combi) have an external opening sash that is the same dimension as the internal fixed frame, so you need a reasonable gap to prevent the sash fouling on the brickwork or external cladding. I have seen Compriband in gaps of 20mm and it does not look bad.
  21. Sadly there is no easy answer. You could let the weeds grow and spray with a very strong glyphosate mix several times in the growing season. May take a few years. You could concrete the area, as the horsetail will not break through decent concrete.
  22. It just won't can't happen. I am doing some new flats and I will put in gas combis. No chance of ASHP and SAP will kill me with electric resistance heating and the flats would be more tricky to sell. The running boilers on hydrogen gas sounds like dreamworld too.
  23. Not worth it. Save the money. The ties will be the equivalent of 100mm x 100mm area and as they don't go from outside temp to heated space they will have almost no impact.
  24. The screed looks fine. Your flooring fitter may want to prime it before laying the Karndean / LVT.
  25. I don't understand the insulation unless this is going to be heated. Rendered blockwork is probably cheapest. You could add IWI later if it is needed but what do you propose for the floor? I think the roof would be the most important element to insulate if you want to prevent condensation dripping.
