Temp
    43
Everything posted by Temp
  1. Larger fans are quieter than small ones if the airflow is the same. I mean if the flow rate in m^3/hrs is the same. Its because the larger blades can turn slower and still achieve same airflow.
  2. The middle of the hedge or one side of it? According to the Guide to the Party Wall Act.. In general they are entitled to cut back a hedge to the boundary so it matters where the boundary is in relation to the hedge. Is it one side, the middle or the other side. If they cut it back further than the boundary they are potentially in the wrong. I don't believe they need planning permission for the fence as long as it is <2m above unaltered ground. It looks like your side is the unaltered side and they dug down on their side to build the house.
  3. The biggest problem is running out of energy... just paint it all magnolia and we'll worry about it later.
  4. If not too late.. http://www.screwpilebasesystems.co.uk/2-uncategorised?start=12 "As the screwpile does not require any earth removed during installation the need of a party wall act can be eliminated, as you are not undermining your neighbour’s foundation."
  5. If he has already sold the downstairs flat go knock on the door and ask if they had a survey done and was a lintel mentioned?
  6. Is it worth asking Building control if they have a record of work being done on the ground floor flat. It doesnt look as if there has been any movement.
  7. Some sources suggest that slow wifi devices will slow down the access point for other users. If that's true avoid wireless cams at the range limit.
  8. Signal strength really does affect bit rates. Download the keuwlsoft wifi analyser free from Play store and check signal strength. Anywhere above about -75dbm works well for us. I'm currently getting -60dbm upstairs through a concrete floor and about 40mbit. See what it says in remote rooms.
  9. If you have a wired network i would install wired WiF AP. Ive just purchased two second hand Draytek 902 for £30 each off ebay to replace old AP800s that were failing. If the neighbours are miles away the best three channels to use are 1,6&11 as these don't overlap. If they are close use a wifi scanner to see what's in use as there might not be enough spectrum for more wifi AP. PS I'm getting 38 to 44 Mbit over wifi to fast.com
  10. How long do you want? Length of angle iron?
  11. Really not looking good for Kingspan.. https://www.insidehousing.co.uk/home/home/kingspan-threatened-legal-action-against-nhbc-for-raising-concerns-over-non-compliant-insulation-68732 Selected extracts.. "Insulation manufacturer Kingspan threatened the country’s largest building control body with an injunction after it discovered issues with its flagship product and vowed to warn others about its faults, the Grenfell Tower Inquiry heard today." "The NHBC sought clarification from Kingspan on the product after discovering conflicting marketing material on the product relating to its suitability for use on buildings taller than 18m." "After waiting for months for confirmation of the product’s suitability, the NHBC said it would have to start warning projects on which K15 had been used that it was non-compliant. In response Kingspan instructed its lawyers to send a letter on 13 February 2015 to the NHBC saying it would seek a legal injunction under the Defamation Act 2013." --- Eventually on 1 May 2009 Kingspan K15 wrongly received certification for use on buildings taller than 18m from the Local Authority Building Control (LABC), which said it “could be considered a material of limited combustibility”. Ms Grange said: “Kingspan knew, didn’t it, all along that K15 was not a material of limited combustibility; on the contrary, it was a combustible insulation, wasn’t it?” Mr Meredith replied: “Yeah, definitely,” adding that the document was “very misleading”. --- Transcriptions from his meetings also said: “We were outed by a consultant who we then had to fabricate a story to that the product still said what it did [on] the tin… we were stretching the truth here and what we are going into [was] an area… where we cannot support the performance of the product.”
  12. The tie itself will probably have a 12(?) nails each end at most so no need for more than that between ply and wall plate. I'd use D4 or Titebond perhaps.
  13. Does the tennant normally have a wardrobe in that corner? Sometimes that can cause the wall to be colder due to stagnant air and condensation forms.
  14. +1 Goes to your planning officer or the planning department if you dont have an assigned officer.
  15. Thats a bit odd. Is the voltage lower at the farm compared to at work?
  16. I googled the Elson Coral E and found this which looks suspiciously like a recal notice. Perhaps worth asking them if its a free upgrade? Or finding out if its been done already? https://www.heatraesadia.com/elson/coral-e-maintenance-and-upgrade
  17. +1 The notches help improve the seal.
  18. +1 to what @ProDave and @TonyTare saying. As a check you can temporarily connect an incandescent bulb/pendant light in parallel with the LED if you have one. If that stops the flashing then add a class x capacitor in parallel. Any value from 0.047uF to 0.47uF usually works. Put a note about the capacitor in the CU.
  19. Some particle board has all sorts of stuff in it including bits of wire.
  20. Sorry but I agree. Its ambiguous but "ready to receive" would be by interpretation as well. No insulation mentioned?
  21. Put a mat under the wheels of the office chair.
  22. Are you sure the second quote for Redwood? You can find similar variation in price from the same store. It depends on quality/species of the wood. Redwood £2.17/m https://www.builderdepot.co.uk/25mm-x-125mm-softwood-tongue-groove-redwood-flooring-5in-x-1in Whitewood £1.36/m https://www.builderdepot.co.uk/22mm-x-150mm-softwood-tongue-groove-whitewood-flooring-6in-x-1in
  23. At last someone gives honest answers and explains how it was.. https://www.insidehousing.co.uk/home/home/grenfell-tower-inquiry-diary-week-19-and-that-was-intentional-deliberate-dishonest-68678
  24. +1 I'm sure it will work but BCO might have an issue with the posts bearing on floor screed if there is insulation under it. Would "decorative" oak beams and posts solve the issue without officially being structural?
  25. The CIL isn't mentioned but.. https://www.self-build.co.uk/question/split-deeds-with-one-planning-permission-for-two-houses/ "Selling off one plot would simply be a matter of splitting the ownership and creating a new set of deeds for both plots. In this situation the planning permission as it stands has the potential to get complicated and it may be advantageous to seek two new and separate planning permissions." Edit: I don't see how the planners can refuse if the application is for two houses identical to the ones already approved.
