Everything posted by ProDave
Rename the file .txt Upload it, with the instruction to rename it correctly (.xls?) before trying to open it.
To make a neat bead of sealant with no skill needed, buy some "corner tape" This is just two strips of masking tape, on a backing to space them, that when applied gives you two strips of masking tape either side of where you want the bead of sealant, nice and evenly spaced. Apply sealant, wipe to get a nice bead, and remove masking tape while still wet. Once perfect looking bead of sealant.
It was the builders suggestion, the ones that build my frame, to make the window openings over size and line them with rigid insulation to reduce any cold bridging. It really was simple, make the openings too big, fix 20mm Celotex strips around the sides then fit the windows. fill in any gap left with expanding foam. I later tidied up the packing detail to fit a continuous strip of ply packing, and countersunk the screws into the fixing plates Then the airtightness membrane wraps around and gets taped to the window frames
When I heard the cladding had failed the fire test I thought "No S**t Sherlock" There is talk of a corporate manslaughter charge if they can find enough evidence. I am sure the Wayback machine will some in handy for that. I expect a lot of computers will be confiscated and a lot of file undeleting going on.
'Nother newbie thinking of developing garden plot
ProDave replied to Dinosaur's topic in Introduce Yourself
Hi and welcome to the forum. It sounds like a great prospect. Remember you will at best have a garden half the size you have now. Will that still be ideal? and you have to find parking for the existing bungalow and the new house once the garage has gone. Only you will know how that will work. As well as planning, check the deeds of your house for any covenants that might stop you building (or might incur a cost to satisfy the covenant). Good luck -
We are just one one self build policy that covers the static van we are living in. If the time to starting build is not long why not just get a self build insurance a bit early?
That's interesting. So not all the "generic" cheap ones are the same. Mine has 100mm travel and the castings have not let me down and I have had plenty of things, vices etc bolted to them.
How do you get into your "entombed" mvhr unit to change the filters?
1st Site visit by Scottish Power to discuss burial of electricity wires
ProDave commented on Lucy Murray's blog entry in Lucy Murray
I will be interested to hear the price for that move. There is a potential plot here with a similar setup, except the H pole has a 100KVA transformer sat on it, The quote was in the order of £50K making the land worthless in effect. In this case there is no obvious place to move anything to. -
Air source heat pump or not?
ProDave replied to Simon Brooke's topic in Air Source Heat Pumps (ASHP)
At the other end of the price spectrum, I have just paid £455 including delivery for a 5Kw ASHP from ebay. I'll let you know in due course if it was a bargain or not.... -
In my case the bottom piece of standard PIR / PUR type insulation comfortably supported the weight of the windows until the fixing plates were screwed home.
Our windows were fitted in openings deliberately made 50mm bigger in both dimensions. The frame opening were first lined with 20mm PUR insulation and any remaining gap then filled with expanding foam.
Whole house water pressure boost
ProDave replied to iSelfBuild's topic in General Self Build & DIY Discussion
Ah I remember it now. That packages solution will work, until there's no pressure to refill the break tank. Did we discuss in that previous thread a break tank where Scottish Waters's suppl enters and a pump from there? -
2 sheets of 18mm OSB glued and screwed together?
Can't you just complain to Scottish Water? -
I would echo that. I did the "large" pipes in my system using some insulated semi flexible aluminium duct that my plumber friend had left over from his job.It turned out to be a pig of a job as I soon found what I thought was a solid aluminium duct was in fact a spiral wrap of a thin strip of duct, and unless you were very careful it started unwrapping the spiral. I would not use that by choice.
What are you most pleased about?
ProDave replied to ToughButterCup's topic in General Self Build & DIY Discussion
You two need to get a room. Ah yes, you are building it.......- 31 replies
- 2
- self build
- advantages
I would suggest something like this http://cpc.farnell.com/sip/01700/bench-pillar-drill-50mm-350w/dp/TL19178 It's what I call the "generic bench top pillar drill" sold under any number of different names from loads of suppliers, even been in Lidl before now. I have been using one for over 20 years, bought originally for about £50. 5 speeds via belt change. I'll bet you find one a lot cheaper than that on ebay.
Recommended Garden Shredders, Please
ProDave replied to Ferdinand's topic in Landscaping, Decking & Patios
That shows the difference in location, and knowing how to be responsible. It's rare for it to be dead still here for any length of time, and the population density is so low with so few houses around that having a bonfire need not be anti social. -
I am just please that I am still managing to progress our build, albeit very slowly, without selling the old one and without borrowing money. I never expected to get this far before the pot ran completely dry, and I even have a plan B to release some assets next March to get even further.- 31 replies
- self build
- advantages
Reducing The Potential for Error
ProDave replied to ToughButterCup's topic in Project & Site Management
It sounds to me like a perfectly square frame has been laid on a sloping slab. Of course the frame will be square, BUT is it upright, or all leaning over a few degrees because of the sloping slab? If it's leaning over then the window openings will appear "out of square" but again could be perfectly "square" but rotated a couple of degrees? Leveling the sloping slab sounds fine, but I would want to be sure the frame really is upright. -
Am I the only one reading this and thinking bonfire? That's what happens to our hedge trimmings. -
I too wonder just how you could get an ASHP up to £10K in price, I can only wonder that it must be on an RHI scheme and that includes the "MCS premium" I have long since realised that the only ones to benefit from the RHI scheme are the installers that can get away with charging a higher price, which a lot of customers accept because they will get it back in RHI payments. As already mentioned, a simple DIY install will cost a lot less. You can get 7KW ASHP's new on ebay under £1000, probably Chinese made so I am not saying they will be good (but they might be) -
Another cheap 12kW Kingspan Aeromax ASHP
ProDave replied to Stones's topic in Air Source Heat Pumps (ASHP)
6-12KW should be plenty. I am in no hurry. I won't be installing it for some time and cashflow is tight at the moment, so I would have bought this one at the right price, but if I have to pay anything approaching normal retail price, then it will have to wait. -
Well I didn't win this one. It went higher than I was prepared to pay for a unit with no guarantee and dubious past. Anyone here win it?
