dpmiller
Everything posted by dpmiller
better chance of it arriving in one piece if you collect from the local depot than expecting some courier to take care of it...
TRV v Lockshield & do I need Lockshield valves?
dpmiller replied to AChristie's topic in Central Heating (Radiators)
that's the valve at the "other" end of the radiator. It's used for isolating during repair, as well as setting the maximum flow- balancing- the system. -
RCBO for Mitsubishi Ecodan (11.2kW)
dpmiller replied to MortarThePoint's topic in Consumer Units, RCDs, MCBOs
It's the DC component that's the issue, not the actual currrent and that could well be RCD brand specific. The original incoming 100mA type-S I installed in our meter box was sensitive to our CE-iVT9, as soon as the inverter was energised (but before actually driving the compressor to any degree) it would trip out. -
if it's so easy why haven't you done it yourself?
those fixings have a degree of up-down adjustment and just clamp onto the round tubes, almost anything will fit...
we staggered ours. It meant taking a small slice off the side overlap joint and flashing of the "lower" panel, but the upper one covers it sufficiently and then the flashing roll was slid uo the back of it after tiling
Another 'Cool Energy' heatpumps thread
dpmiller replied to HughF's topic in Air Source Heat Pumps (ASHP)
what pump modulation are you seeing and what deltaT are you set to? -
they don't know you from Adam, why should they trust you? You're just another trade and your mate is in it with you. Or so they likely think...
a wee circulating fan? PIV?
yes, my calculator works too... But as we've got DHW temps for some of the time, heating flow is 40c ish, and we're in a damp cool dip, I think an average COP of 3.6 sounds a bit too good to be true.
- 367 replies
- ireland
- timber frame
A full year of consumption records, as of today. Total consumption by the ASHP is 3232kWh and just over half of this is during cheap rate. Jeremy's calculator came up with 11700kWh annual heat requrement for an average year but I'm guessing the actual requirement is a fair bit less as our flow temps would suggest a lower COP...
- 367 replies
- ireland
- timber frame
being on the wrong side of the small pond massively kills choice, very few GB suppliers will ship. Bathline, Beggs, PTS. Plus there are a few smaller more merchant-y guys too. VP Jebb in Belfast, Stevensons in Bangor, there's another small wholesaler in Kilroot. I deliberately aimed low and ended up dealing well with Beggs, although I wouldn't darken their door normally for plumbing bits...
your local motor factors might help with replacements as many stock trailer parts.
ASHP / Octopus Cozy - any experiences?
dpmiller replied to Paene Finitur's topic in Other Heating Systems
can you program a slightly higher flow and room temp during the E7 period, to charge the house up? Whilst there's a small efficiency loss running during the lowest ambient temps of the early morning you're still going to gain over running at the day rate. That's what we're doing, and solar gain reduces daytime losses so there's actually very little heating needed during the day and evening -
can your loft take the weight of either?
the clutch on that Hitachi will only be to stop it breaking your wrist, not for setting torques.
Any YIMBYs on here? Keir Starmer is.......
dpmiller replied to ToughButterCup's topic in Planning Permission
^ agreed. However spread of fire from an adjacent vehicle would be a different thing completely. EV batteries are darned-near hermetically sealed, generally have a heavy steel cladding, and most likely are full of cooling water. So getting an intact pack to light up will take a shedload of energy... -
a 2 foot long 6mm drill? Good luck keeping that straight and intact...
Of the retail options, Kilrock make good stuff and the brush-on gel is great for things like this
thanks all. Yes we thought all oak would've been too imposing (never mind the cost implications, lol) and we're well chuffed with the outcome. Just need to insert the last bit of stud wall under the stair now to make a cloak cupboard.
- 367 replies
- ireland
- timber frame
- 367 replies
- 6
- ireland
- timber frame
1 or 2 is speed...
think you need F-gas to buy bulk refrigerant now?
pallets.
