dpmiller
    4
Everything posted by dpmiller
  1. I was very happy with the terms we got from the small-ish TF co we dealt with. 30% deposit 10% on completion of design, to release structural drawings to BC balance on completion of erected structure with an offer from the Co to withhold an amount to cover any missing or snagged portions
  2. surely tho you'd need two pumps else the risk is the same?
  3. plenty of oil in the sump? In the tank?
  4. I've been doing a bit of searching. and gleaned that the diverter in this thread is indeed the same as the CoolEnergy one, and if anyone wants to deal direct with the chinaman you can have one from the manufacturer direct. I'll not post a link but you'll find it on Aliexpress from "Runhu" and it'll cost you about £140 including shipping and vat. photo of internals The fan is a bit bigger than the iBoost's by the looks of it, and the general build is so similar that I'd opine they could be the OEM for it too, lol
  5. supply and extract being *exactly* the same on boost certainly doesn't pass my sniff test. Airflow is a pain in the a*se to measure and set up...
  6. where does the lift plant go?
  7. check the status of your local exchange- some are already closed for new copper connections and FTTP is the *only* possibility.
  8. is the requirement for a treatment plant log book- and ongoing sampling- not a German/ mainland European thing?
  9. sounds like they've accidentally included hire, at those costs...
  10. aren't they the really sappy b*ggers that aren't recommended in a stove?
  11. it's up to the fabricator to remember to insert the steel sections with any profile, I fear.
  12. I'm using a 9kW ASHP on a smallish thermal store, so we don't have a massive amount of *stored* energy until there's plenty of PV diverted to it. Nevertheless, the tank never runs cold and the heat pump will cut in and recover seamlessly. Less than an hour will recover the tank.
  13. @crispy_wafer what size Solido is it? I've just checked our documentation and the 6-8PE is 150kg, needing a 180cm dig, it's got a lifting eye on top and no concrete required... best practice is to steadily fill with water as you backfill, to equalise the loading although the moulded tank can take full load either way unsupported
  14. not how it works. You made the assertion...
  15. certainly not the cheapest in the UK. Maybe the GB part of the UK? I passed two stations yesterday here both at the same 130.9...
  16. Our HP will happily switch itself from cooling to DHW if it needs to. Plus how long do you think you'll need to run it for to take a wee bit of extra heat out of the house?
  17. OT, but how much are diesel and unleaded at the mo with you?
  18. I'd love to see some actual data on that, if you have it?
  19. I'm guessing the spark meant compressor, not condenser.
  20. better not forget the locking collets on the JG fitting if it's going to be unseen...
