dpmiller
Everything posted by dpmiller
Anyone had first hand experience of Shower Power Boosters?
dpmiller replied to Del-inquent's topic in General Plumbing
I've used the same pump that's used on these, in a solar HW system. The pump is actually surprisingly powerful for the current involved. -
How to measure the remaining HW in an unvented cylinder
dpmiller replied to Adsibob's topic in Boilers & Hot Water Tanks
so does this mean that the short heating periods youve set might not even be fully satisfying the tank currently?... -
What model is this oil pump - have a guess
dpmiller replied to cwr's topic in Boilers & Hot Water Tanks
the mount and shaft *should* be universal but there are some outliers. Direction of rotation and pipe positions are the critical bit, some of the other options (position of the regulator etc) may not be so important for most applications... -
tell us what burner and boiler it is, and do you know the direction of rotation? or if you're stuck there's always https://www.bes.co.uk/universal-oil-pump-16393/ -
no they couldn't, no smart meters in NI
*think* isn't good enough, what's the number? Buildup?
Radiators not reaching flow temperature
dpmiller replied to Helene's topic in Air Source Heat Pumps (ASHP)
coz they fail often and drip gently. When working fine, you'll get a small volume of trapped air- at system pressure- above the internal float that'll hiss impressively when you slacken the schrader cap. -
The copper flexys are handy sometimes. Our chinese friends offer convoluted stainless tube (similar to the tracpipe or the flexy solar stuff) in short lengths with flat faced ends for a few quid a touch, they're quite nice too. Same is used inside UVCs as the HE coil this kinda thing: https://www.aliexpress.com/item/1005002680190702.html
https://www.ebay.co.uk/itm/155873410030 ?
still that's enough to upset the match as the illumination is quite oblique. Turning the sample 90degs would likely give a very different result. / with the automotive spectros, there are instructions from each paint manufacturer on what type/ grade of polish to clean the surface before reading, etc.
who does free returns...
- 1 reply
the spectros that are used for domestic matching are massively different to those used for cars etc. Was the sample board rollered or brush-painted? Much texture?
Should I be filling this before tiling?
dpmiller replied to Tom's topic in General Self Build & DIY Discussion
...and don't drill through the pipes when mounting it. -
so what was the tank temp and the setpoint?
- 15 replies
- cool energy
- ashp
@HughF what kind of changeover valve do you use?
- 15 replies
- cool energy
- ashp
you can generally leave the insert in-situ and push the new pipe in, over the insert.
snap!
- 15 replies
- cool energy
- ashp
possibly a mains spike that got through the rectifier? Both the fan and the main drive inverter are on the same bus so I'd guess that anything that disables the inverter crashes the fan module too.
- 15 replies
- cool energy
- ashp
Drying and re-insulating a 2.5 year old damp cavity wall
dpmiller replied to Adsibob's topic in Heat Insulation
might you be able to sneak a camera in to check the cavity tray over the window for gaps or holes too?- 44 replies
- damp
- cavity wall
CLS or general carcassing timber for studwork
dpmiller replied to BadgerBadger's topic in General Joinery
bit late to be calling him an "iddiot" now. Why didn't you query it? -
Void and Pantry and More
dpmiller replied to Mr Blobby's topic in Mechanical Ventilation with Heat Recovery (MVHR)
2. I put a supply in the pantry in the hope of keeping heat from the surrounding rooms at bay. It helps... a little.
