dpmiller
Everything posted by dpmiller
do these mixers have one or two knobs?
Where exactly in the UK are you? Difficult to cite the Regs if you don't know which version...
depends if the PRV/ safety group was fitted correctly.
that opener looks mightly small for it's location, if it *can* move that far over?
^ that's a rubber waste compression, not metal olive
have they moved then? They certainly used to be in a part of the UK...
Vaillant ashp (my battle with).
dpmiller replied to zoothorn's topic in Air Source Heat Pumps (ASHP)
"500 litre baffled water tank" eh? -
Angle Grinder - Wattage, Button/Trigger, and Recommendations?
dpmiller replied to Oxbow16's topic in Tools & Equipment
Have some experience with Parkside grinders and in general they're great with one exception- the new-ish brushless 20V one. Very little torque, the wheel just stalls under protection any time you force it. Keep the revs up and it's fine. Not recommended... -
Zoot, if you can't show us the heat-loss calculations that you *should* have in your possession and quote the model number of the indoor and outdoor units, then it is impossible to answer why the current system has no buffer. If you don't have the heatloss document (and btw no-one is expecting you to create or understand this, that's what you've got us for...) then *that* is surely something you can ask about as it was AFAIK a requirement of your Grant? -
Oh dear! Can the flue squeeze in here?
dpmiller replied to Jimbo37's topic in Stoves, Fires & Fireplaces
Give the nice folk at Schiedel NI a call, I think they do a Protect Box for this kinda thing and should be able to spec the whole system.- 25 replies
Kinda, I used the configurator that was available at the time then I bought mine from Plugin Solar. We had a scheme in mind, but when setting the trays out on the actual roof it became apparent that they were too tight to the valleys to flash and mount correctly and so we re-jigged to put two panels on a different face which then required purchasing a couple more bits of flashing. But the move actually suits us better in honesty as we retain production later into the evening now (but at the expense of peak output).
as this is only a tiny cottage with a few rads but high heatloss, should we not re thinking about the system's capacity during defrost, more than just heating power? -
Log burning 'Back Boiler' using a secondary HW tank
dpmiller replied to Rafiki's topic in Boilers & Hot Water Tanks
there are also boil-prevent thermovalves available if the boiler has suitable connnections. Some require a cooling coil inside the boiler, others are a double valve that injects mains cold water at the bottom and release hot flow at the top simultaneously. Our Bronpi stove was specced with one of these: https://woodmanstore.com/product/two-way-thermal-release-valve-regulus-dbv/- 1 reply
- log burner
- secondary hot water tank
Fully cover / grid for pedestal paving.
dpmiller replied to Conor's topic in Landscaping, Decking & Patios
drill it through but have one of these? https://www.celticwater.co.uk/leaf-catcher-downpipe-leaf-trap/ or https://www.celticwater.co.uk/leaf-separator-compact/ -
We were/ are in the same situation Ian- bordering the 1% and 5% lines. Local BC made no requirement so we chose to just go with membrane- if anything *does* rise and escape it'll get blown away
What is the level of radon risk locally- do you actually need a vent or is a barrier actually sufficient?
am I the only person that downloads and reads manuals while doing due diligence prior to purchase?
cheap mains (or vibration sensing) hour counter? Does it actually need to be logging or just a totaliser?
