dpmiller
    4
Everything posted by dpmiller
  1. https://www.ebay.co.uk/itm/Willis-Jacket-Complete-External-Immersion-Heater-Prewired-fully-assembled/202416631247?epid=1588852290&hash=item2f20f8adcf:g:wAgAAOSwfEJeHIev even had MIs...
  2. tanks stats/ pipe stats/ motorised valves?
  3. also worth noting that some (ours anyway) are a soldered-up sealed unit so not much chance of a leak. Oh and the fitting at the top is a standard one so the pipe won't slide on in...
  4. Our Turkington has a SS secondary HE and I don't believe there are any limits on the return temp.
  5. Dunno, they show it modulating 1.5 to 10kW, how else would you do that other than inverter?
  6. Now that *is* an interesting looking piece of kit. Intersting also that they're using the Heatstream TS tank... edit scrub that. RED *are* Harlequin?
  7. but other than poorly-set defrost parameters, is the COP of the average ASHP ever going to approach 1 never mind dip below it?
  8. if the shoe fits...
  9. I didn't see it answered already but... does a Laddomat have to be at the bottom of the circuit or not? The MIs for the 21-60 say yes, the 11-30 don't comment. But the larger one is fixed-orientation whereas the 11-30 can be fitted any shape..
  10. not nationally, just GB.
  11. In some of the newer plants, the pump doesn't run full time I believe. Certainly the air outputs are rested for periods. I'll hopefully be able to confirm this in the next couple of weeks with our Solido Smart.
  12. PB is a lot springier/ more flexible.
  13. Carrying on. More pipes, more cables, more plasterboard. Howdens stock door linings for CLS-sized studwork so gave them a try and have to say, pleasantly surprised with the quality and service. Got a door to go with, to square things up easily. Had a plasterer down to price some bits and bobs. Waiting for another crew to offer costings now. Plan is, to get the ensuite skimmed out so we can get a working bathroom and get shot of the portaloo. I won't miss the rental going out every month... Which leaves today. Loos don't work without drains, and we'd never got a final scheme together for the BCO. And based on the limited height we have between the current level, the FFL and the FGL I didn't want any nasty surprises re. pipe cover etc. So, called in to request a visit just to thrash out what works and suits. BCO arrives, makes approving noises about progress, doesn't care to look at any internal drainage and agrees to all the points of my (minimal) scheme. I asked if there's anything else he wants to see or check on before I start covering the GF ceilings and...no. Just a look at the safety glass in the french doors. So we're clear to complete the surface water drainage with no inspection required and he just wants a call to pop out and view the foul pipework once bedded. Onwards!
  14. ^ Dave's option FTW then.
  15. Irfanview can work with a locked pdf using it's paint tools.
  16. In our house, I do most of the cooking and neither of us are much for entertaining. Plus, we're moving from having a convenience store 400m away to somwhere a *bit* more isolated so shopping habits will change a bit. Still haven't decided on an island yet although if there is one it'll be more a visual cue and somewhee for breakfast I think. Kitchen is a broad U at one end of the open-plan room. Fridgefreezer (small daily freezer) on left, sink and dishwasher centre below the window, rangecooker in right-hand corner. Utility will have a sink, the washing machine and a large freezer. Walk-in larder off it for bulk storage.
  17. I've got a Walabot, I must try it on the screed for a laugh...
  18. You could always just send it in and wait for the list of questions?
  19. yes, I've seen'em. More of an issue with 222s I thought. Can't see me needing them for anything other than lighting circuits tho so I'll happily risk an amp passing through. /now the ones that come with cheapo lights, that look like chokblocks with release buttons on? Purest kelp. Wire isn't caged within the terminal so you're reliant on the plastic to keep the pring pressure up. Naff.
  20. got a kit of chinesium clone 221s and they're very good.
  21. Never come across this before https://www.greentherm.ie/product/greentherm-300-litre-combined-cylinder/ 300l-sized mild steel TS but with an internal 80l stainless vessel for DHW. Had a yarn with one of the fellas from Greentherm yesterday, querying recovery, losses etc but he didn't have much info. How would the flow and recovery of this compare to a conventional TS with a coil? 80l stored at constant temp vs a DHW coil... What happens when you're drawing off? Sure there'll be 80l but (noting that CW is fed to the bottom of the DHW vessel) can the stored body reheat the DHW in real time?
  22. funny I had a chat a while back with someone at CoolEnergy.... I asked if they had plans for a smaller inverter and the response was pretty much it's pointless as there's no real efficiency difference. Umm?
  23. I think a number of different controllers have been used over the years,perhaps a quick call to ESP would get you the info you require?
  24. just for confirmation yes, the only thing to see the Megger was the Compressor. another angle- before getting a fridge man to pull a vacuum to dry off the system might it be worth heating the compressor housing (hairdryer or heatgun) and retry startup with it hot?
