dpmiller
    4
Everything posted by dpmiller
  1. BCO made his visit today. Foul drains all good, free to carry on!
  2. Quinn Lite 7N
  3. our whole TF sits on a course of thermal blocks.
  4. Our clay ridges interlock and are holed for screw fixing. No plastic spacers needed, just the roll-out breatheable strip. these, although there are likely other similar types http://www.ridgetiles.com/
  5. yep.
  6. Relatively busy couple of weeks. Had the groundworks guys in for a few days and so the foul drains are ready for inspection tomorrow. Half of the rainwater drainage is done too, and a trench cut to drop the mains water pipe into. With the overnight rain it's looking more like a navigation... Had some skimming done so amongst other things the hotpress is ready to receive some pipework. And this: just the door to hang now. A touch more civilised than a site loo, yes?
  7. gonna be someone elses' chinesium surely?
  8. the inner layer is white on all of 'em...
  9. each will have a spec for the maximum screw length. Looks like the DS50 does 55mm, dunno about the Parkside.
  10. @TerryE which post are the photos in please?
  11. you need a way to force the flow out of the floor loops and into the willis...
  12. Yep. I was able to mod my manifold to get flow out into the Willis, but only because a. it had a bypass and b. said bypass pointed at the return of the Willis. And I have the Willis underneath the manifold so have the chance of convective flow anyway. You'll need a pump... unless... where does the braided hose at the far right go? Tee into that and connect to the bottom of the Willis, and go from the top of the heater to the supply into the manifold. Cap the return. Sme of your flow will be diverted through the heater and the mixer will then sup heated water.
  13. Because mains electric is Alternating Current. The V (dash dash) is Direct current, you'd use that around a car or to test batteries etc.
  14. Just the 600.
  15. It's V (squiggle) 600 you need, round to the right.
  16. Where is the pump going??
  17. and the meter is set to VAC, not DC correct?
  18. I think they're seperate. Looking at the menu for the non-inverter controller it does seem to have two temperatures but the timer programming bit doesn't allude to DHW and CH schedules.
  19. looks like it's using it's own programmer to do the flow temps based on times?
  20. no reason you couldn't use a poured thin screed over the timber deck either. Our FF is 50mm hemihydrate over caberdek , on 254 pozis @ 400ctrs, with a span of 4.7m. It's impressively stiff and quiet.
  21. Yes, the motors are known to fail and are replaceable. Hopefully your plumber also does electric. Not all do...
  22. the valve works when it gets a supply of electrical power. You haven't yet confirmed that this is happening. Once you do this than you can confirm that either the valve (it's motor on top) has failed, or instead part of the control circuitry upstream (UFH wiring centre/ stats/ timeswitch/ ASHP controller even maybe)
  23. only niggle is that those stats have a pretty wide hysteresis so a "too-low" setting may let it run for a bit and then just... stop.
  24. tried hitting it a whack?
