dpmiller
    4
Everything posted by dpmiller
  1. Your BCO might have his own thoughts depending on local conditions. Ours was happy with 300mm cover
  2. ^wot Dave says. If both machines are "clean" - and your router will have some kind of firewall too, yes?- what risk do you expect?
  3. if you're not on an open network and both machines are already clean what's your concern? /can you not just pull the HDD and slave it into the W10 box either directly or on USB?
  4. why is the membrane on the INSIDE of the panels?
  5. guessing you don't have the full manual, some don't seem to have all the menu stuff. This is for my High Flow but the menu should be the same. kinetic_sentinel_manual_1.pdf
  6. I know I've said this before, but you can mix and match (and switch between normal and grid faceplates) with Hager Sollysta too.
  7. why are the arrows pointing the wrong way on the cold flexy?
  8. ordered a similar-looking item from PSW to appraise and as pretty as it is, it seems like more hassle than it's worth by the time you deal with mounting it in the limited depth of a service void
  9. Given up on mainstream european and refuse to give Miele their markup. Five year warranty on Samsung...
  10. round these parts, thin cement board is the norm for developer soffits. https://www.roofingsuperstore.co.uk/product/non-asbestos-undercloaking-strips-1200-x150-pack-of-10.html https://www.samuelkirk.co.uk/non-asbestos-soffit-strip-2400-x-200-x-6mm-15271-p.asp https://www.resistant.co.uk/products/multi-pro/
  11. Is the house block/block or timberframe?
  12. Thing with the buttons looks like a NVR, is there a contactor hidden somewhere?
  13. Yep. I was in a rush/ couldn't risk a wait for Direct Chinesium so got the RS Pro equivalent. https://uk.rs-online.com/web/p/inverter-drives/1223411/
  14. VFDs are so cheap and handy now. Had to get one in a rush for a farmer customer recently and just ordered a basic ownbrand one off RS.(Potato packing conveyor) Less than a quarter of the size of the original one, and up and running in no time.
  15. Clive, I'll PM you the SE's notes for our conversion- don't want to put them online in case of copyright issues
  16. yep, we had coax systems still in use until maybe 5 years ago- car paint systems aren't always upgraded too often.
  17. Isolate the slab in the pantry and have it uninsulated to ground, or loop the mans water feed through it.
  18. but it's energised the whole time it's actuated... in saying that, there could be a bit of PTC involved
  19. Local BCO doesn't even require *normal* rest bends never mind extended. Bog-standard 90 at the base, round these parts...
  20. ...unless there's a draught or a big magnet...
  21. doesn't the aluminium in barrier pipe make it detectable?
  22. Howdens are offering this from selected branches now too
  23. I had an SE design something similar for the attic in our current house. Sistered joists and rafters, plus plywood gussets at the ridge. That let me remove the central ^.
  24. socket set plus PZ3 bit, nice long ratchet for loadsa torques?
