dpmiller
    4
Everything posted by dpmiller
  1. 500W panels are very non-standard. Guessing this is a fancy branded odd-sized panel too? 270-300W panels are like £100 ea...
  2. so I've never really been able to work out, what's the difference between these Evo saws and a bog-standard sliding chop?
  3. Available flow rate wrt restriction @ different fan speed settings.
  4. behind plasterboard would it need any?..
  5. what temperature of Sunamp, and what is the COP of the ASHP at that temperature?
  6. Libel is a defamatory unjust statement? Can't see that here. How is anyone's reputation hurt? [shrugs]
  7. nothing halogen for sure... how temporary? portable or fixed?
  8. our TF Co. used a combination of Express anchors and Hilti nails.
  9. Cill for ornaments? Lighting recess?
  10. Sounds like the hot water circuit might be gravity, how many pipes go to the multifuel? Or is the system "pumping over", with the pump forcing water out of the vent pipe and back into the F&E tank? Are there any other pumps, like beside the oil boiler? You might try as a first go, closing the valves on the hot radiators to force the flow to the others. Once you've flow to all than you can worry about balance...
  11. Didn't like the zinc/butyl stuff, but Leadax is superb stuff, very nice to work with...
  12. I've just realised that the saw I was thinking of has a welded arbor, Clive, can you send hours over too?
  13. and yet still we don't know where and how much insulation will be (was?) fitted. Have you now decided that this poured slab is the finished floor? Why? So regardless of what bricks and blocks are currently in place, your FFL can be ANYWHERE between where it is now and maybe 400mm higher. We don't know. You don't know. Your builder does. Is he correct? You don't know, we don't know.
  14. 1. please use whole words. 2. explain what the steps between old and new will be like. thanks!
  15. I checked our filters after about four months.. . Intake on the left. Loads of tiny tiny flies, and I fear the brown tint is caused by the amount of slurry dispensed locally. Loads of horses nearby too. The exhaust side is all concrete dist off the (unsealed) subfloor.
  16. Mine'll go on a standard arbour so yes, spindle size critical.
  17. ...closer to home Dave, I've a carbide crust holesaw in the car, and it's somewhere between 35 and 40m IIRC. I'll check it in the morning...
  18. ^ big splatter shield, but what size is the actual LCD panel?
  19. ^ same as @Thedreamer here.
  20. Our door and window firm recommended upgrading the opening from the architect's 950mm to 1000mm, They apparently always recommend this rather than anything narrower where possible, to ensure an acceptable clear opening.
  21. Local mortgage consultant did the rounds for us and put us smoothly into a remortgage deal with Virgin, and again last month into another 2-yr deal. Again with Virgin, and no hoops to jump through. Didn't really look into the selfbuild side of things too closely but you could do worse than give NiMortgages a call.
  22. Good way to burn out a mains drill that, Clive.
  23. can't see servicing being an issue really. CO2 is Everywhere. Pubs, fire extinguishers etc. Just needs a new set of gauges...
  24. @MatthewB1993 we were in a similar position. We bought the land outright off savings, and remortgaged the current spot for enough to (hopefully) get us habitable. We'll then sell and then regroup for completion. That's the plan anyway...
  25. location would be useful? Many of the Irish and NI companies will travel to GB to erect, even.
