dpmiller
    4
Everything posted by dpmiller
  1. Looks more like uncrushed stuff as-dugout.. As Declan said, tell us where you are. There certainly isn't any shortage of trades round these parts.
  2. Most car bodyshops will also do interior bits like this, and there are plenty of guys doing kitchen door respray/ refurbs.
  3. no, you just leave the "IN" disconnected from L and then your dry contacts are "IN " and the next terminal. S! and S2 are remote switches, 240V in as triggers.
  4. I don't care what shape it is, it's still the same tech- an edge-lit panel.
  5. to the OP are you looking for focussed pools of light or diffuse light from above? If the latter, then the slim LED panels fit within the PB layer, but you'll need a bit of space above (slack membrane between joists) for the clips and driver.
  6. Probably not as fire-rated means sealed in the event of fire, so often with vents and intumescent material
  7. Dunno if the picture is accurate for the BPC item, mine don't have louvres and have a 10mm or so wire grid.
  8. nope, normall isolators have an arrow on as the seal is only perfect in one direction.
  9. or pipeslice the one directly beneath the isolator and stick a straight coupler on.
  10. I had great price and service from Plug-in Solar, I think they're a reseller for Midsummer, and didn't have any issue with delivering to NI.
  11. that was lucky.
  12. drill the welds out, new bearing, a few MIG spots, done. /except it's probably some wierd Imperial size that'll cost as much as a new pulley...
  13. Is there another pump for the towel rads or are they just opposite the ASHP tappings on the LLH?
  14. https://www.screwfix.com/p/hafele-keku-fixings-m4-x-48mm-10-pack/8663t
  15. do it with a back entry gully and it's then rodable and you've somewhere for your outside tap to leak into as well...
  16. anybody near you work on commercial vehicles or trailers? Common for flooring in them...
  17. or a wee 12v lightbulb if you've got one kicking around...
  18. what's the point of the pocket door between Bed4 and the spiral stair? Surely the handrail will preclude acces to the stair...
  19. Voltage drop is the problem. You'll probably be alright with trimmers as they don't use too much juice. But a chainsaw takes a bit more, and don't even think about anything with an induction motor (power washer, compressor) as they really dont like the supply being low.
  20. Hire a petrol one?
  21. @nod £20 m2 for *what* precisely?
  22. Because the tool *is* brand new, don't assume the steel is a good fit or lubricated...
  23. LBS Snowdon slate-effect clay tiles
  24. Ring Cardy Timber in Carrowdore, they specialise in dealing with fancy live-edged stuff and might be able to advise or assist.
  25. Surely roadside fibre cabinets only apply to FTTC, plain old ADSL *is* copper pair back to the exchange... In our case the exchange would be about 8km, but the Cabinet isn't much better as it's at the far end of the nearby village, so still about 4km of copper.
