dpmiller
Everything posted by dpmiller
Smoke problem from neighbours
dpmiller replied to Savage87's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Yes, lower combustion temp = more particulate. It would be intersting to see the proportion of the current parc that is still older (Furo 3 or 4) diesels, DPFs have been around for a long time now.... -
...which you can't. In diesels, EGR reduces NOx but at the expense of particulates. Hence the DeNOx and AdBlue which scrubs the NOx from a clean burning engine vs the older tech which lowered combustion temps to reduce NOx... -
I'd be fairly sure that having the supply fan off or waay too low might unbalance things, but air will still be drawn through the supply. /this is something I haven't yet tested with our system. I can bring the house to a reasonable pressure or vacuum just by running one fan at max and the other at the minimum, I must try sealing one of themain ducts completely and re-trying... -
I've installed a flue system that does indeed bring the supply air down from the roof https://www.schiedel.com/uk/products/ceramic-system-chimneys/swift-air/
Modern Agricultural Barn conversion. Anybody done one?
dpmiller replied to Roger440's topic in Barn Conversions
Try camping in Glentrool forest. Midge central... -
if there isn't another bell push at (say) the back door, then there is a transformer somewhere powering it.
Yep, Leyland is PPG too. For reference, I've been associated with the automotive paint trade for almost thirty years now (weighing/mixing IT support) and have also been subbed into retail mixing in Homebase etc. Somewhere 2007-ish as I recall (you can research the complexities if you're bored) the coatings industry was reshuffled before and after European monopolies issues. ICI decorative (Dulux) went to Akzo ICI automotive (Nexa) went to PPG Crown went from Akzo, through a management buyout, to being owned by Hempel. And if you think that's complex, look at the history of Axalta...
Isn't Dulux Akzo Nobel now? PPG retained ICI Nexa in the Automotive sector, but Dulux went away... Johnstones is the PPG architectural brand.
nasty stuff, tissue fixative/ embalming fluid/ carcinogen.
- 28 replies
Can't be sure as it was part of our windows contract. But full list in their Doorbuilder (two years ago), including two etched sidelights and a bit of frippery on the glass panel, was £1300 plus vat.
/say howmuch??
competition? or lack thereof?
Apeer is good, we have one. Plenty of resellers in NI...
put the printer under the body dryer in the bathroom?
...just found our invoice. £100/ hr, but at the end of the day (including fees for mapping and some additional printing and stuff) less than two grand total.
yep, kinda like @Russell griffiths IIRC. Can't put my finger on the invoice just at the moment.
Our guy discounted heavily off his standard rate as there was loads of waiting time and not so much doing.
Why is so much plumbing stuff such utter rubbish?
dpmiller replied to ProDave's topic in Boilers & Hot Water Tanks
earths all good, anode (if so fitted) in good nick? -
water alone won't rust it- where's the air coming from, or is there something galvanic going on? -
did you not have the pipes full and pressurised when the slab was poured?
how does that make it noisiertho? The same compressors are used in fridges and freezers...
why would a freezer be noisier than a fridge?
windscreen fitters use'em too.
why would the ASHP need to control the immersion? Are you concerned about legionella?
