dpmiller
    4
Everything posted by dpmiller
  1. Yes, they'll quote by height with whatever base starters or lintels, pots etc. Check the price between Isokern and Swift, too.
  2. Scheidel quote including the rockwool insulation, the actual blocks and pipes, adhesive etc. It's really plugandplay (especially if you're rendering the blocks directly, we built a skin of standard blocks around the system blocks) even if the blocks are *heavy*...
  3. is the upper strip wrapped around the floor cassette as a TonyTray perhaps?
  4. I went with ceramic https://www.schiedel.com/uk/products/ceramic-system-chimneys/swift-air/ which also neatly looks after supply air too. A complete system inc the outer blocks etc was around the money the OP mentioned.
  5. V-tac's "grill fitting" strips are superb if you want something more "linear". Light and plasticy, but great light output, run cool, and cheap! https://v-tac.eu/led-products-results-page/led-fixtures-1/?custom_f_145[0]=3134302d313630206c6d2f57&custom_f_145[1]=3131302d313330206c6d2f57
  6. why not just an ordinary laminate worktop?
  7. perhaps the "little boy" (condescending much?) was uncomfortable with accepting the liability for agreeing to something that isn't in the MIs?
  8. Polarwall will supply XPS...
  9. Since when was a PV diverter £500?
  10. Nice part of the country, sir.
  11. Hiya, whereabouts are you?
  12. the chap that did ours was a wee bit more including the BReg drawings.
  13. what's their ballpark cost for a house design?
  14. the "middle bit" at the back of the pump is the inlet.
  15. Is that maybe a back inlet gully with the grating removed? In which case it *should* be trapped, as long as the rodding insert hasn't been removed from it...
  16. static vans are often by the sea tho, so salty air. Is the OP on the coast or inland?
  17. we were in the same boat, mobilising someone else to do the contestable would likely have been more than the cost of their actual works.
  18. Eeek!!! Are those uninsulated terminals facing upwards?
  19. DECT cordless and a repeater?
  20. who is the "them"?
  21. Sounds like it's a split system?
  22. Are there not flexi-hoses connecting the outside unit to it's pipes?
  23. Depends on the duct lengths. Fans tend to make positive pressure more easily than vacuum, so restriction is seen more on the extract side.
  24. ABC cable Dave I think, Aerial Bundled Cable.
