Everything posted by markc
Wrong bucket on the digger, anytime digging around pipes and services use a bucket without teeth and you can feel everything. You only need teeth in bulk digging or rocky ground
Wet vac.
What do you want to achieve? Are you looking to move the drive? Wanting to know how to go about getting services moved? Drainage? Sight lines? Etc. if you can give us a bit more info and ideas, plus a photo or two I’m sure there will be more input from others.
Hi, look for someone who does bespoke kitchens or bedrooms, your build will be pretty straightforward for them. Joiner covers a multitude of trades/skills from first fix framing to laminate flooring.
Widening Fireplace to have more room around log burner
markc replied to Whitefusion's topic in Stoves, Fires & Fireplaces
1350 outside is never going to give you 1100 inside.- 27 replies
- fire
- structural engineer
(and 2 more)
I would always put a DPM between blinding layer and insulation
Baltic birch is the dogs whatsits of ply, but I would never paint it, decent hardwood ply for painting. MDF is my go-to for custom cabinets if they are to be painted. I would say that’s a 1500-£2k item as a stand alone but bespoke size.
Search dust extractor ducting, tough stuff
The climate conference …. Let’s burn thousands of tons of fuel to meet up, live it up and discuss getting others to burn less fuel. ?
I can’t see a problem with doing that, you will need to lock the angled bend in place with concrete to stop it trying to work itself down and out.
Once plaster starts to crumble and come away from the wall easily it’s time to remove it. ppl get them skimmed over but they sound hollow if bumped and often fall off anyway.
Our QS has a trade intelligence index after years of experience. To quote, she said: 'Renderers are the most stupid, plumbers not far behind, electricians show a spark of intelligence.' There must be more to the league table and I wonder what the trades think of QS's? i reckon you should find a new QS, this one must be on Meds or some kind of power trip
Nice job, well done. Yes it may have taken you a while but you will have learned stuff that can be utilised elsewhere.
Ahh, I never use hi res for pics so never have a file size problem.
Click to choose files at bottom of box then select pics from your library
Semi dry mortar forced in will not shrink, wet grout poured in under a column does shrink away and allow rocking if it’s not a non shrink. for domestic and average commercial buildings the base plate sizes do not require poring grout. We used to have some columns with 2m diameter bases and portals with 1200x800 bases and often ended up with a grout thickness of 15-30mm so liquid was needed even when vibrating the plate
Hi, this comes up many times, loads of tiles and sheets contain asbestos but the likelihood of this kind of exposure causing any harm is very low. loose fibrous asbestosis a different story. Search previous threads for similar content for re assurance
Annoying noise in my bedroom
markc replied to MarcoP87's topic in General Self Build & DIY Discussion
@MarcoP87, I’m sure your question is serious and I’m sure there will be some constructive suggestions along shortly, for now … enjoy the innuendos -
@pocster looking forward to your suggestions squire ? p.s. it won’t open or play for me. -
Insulated Raft Slab Foundations - Finished Flooring
markc replied to TBlew's topic in General Self Build & DIY Discussion
You can use concrete blocks or weighted timber battens to fix bracing to if you don’t want to drill the floor -
I would never use 9mm OSB on walls or roof, it’s just too flimsy and drum like, no need for 18 as that’s overkilll and too much hard work. you don’t need to double headers and footers unless specified but it does make the install a lot easier especially when working alone … put a single footer and header in first, make the wall to suit and then rock it up into place and align, nail through! Much easier than singles.
Looks so much better, and happy to help
That looks pretty awesome, good on him ??
Great advice, we all get complacent at times. Tall windows inside is when an A frame style ladder comes in, self supporting and cannot slip! … you can reach too far and get them to fall over tho ….
