Everything posted by markc
After 7 years ; moving in ….
markc replied to Pocster's topic in General Self Build & DIY Discussion
Well done, really happy for you -
Hi, couple of points: definitely doesn’t look like MDF. have you used the caulk to form a fillet at the corners as you would silicon sealer? what primer did you use? was it bare wood or previously painted? the paint looks very thick, primers are designed to get hold of the surface so thick applications can affect anything underneath.
Got to agree, the reason I would clean out the loose from underneath and stabilise the soil with concrete or similar. I used the term underpinning loosely to try and describe what I was thinking.
Type of fixing depends what the wall is made of, as above concrete screws are fantastic into solid concrete or sound brick. sink brackets are fine onto plaster but if dot and dab plasterboard then you need to cutout the plasterboard and add a timber. screws and fixings can be too thick if they are close together.
Hi, is it that the builders haven’t a clue what to do or they don’t understand what you are asking for? an extension is everyday stuff to most builders. do you have any drawings and or photos so we can better understand the problem and scale etc.
Mica has led to apparent defects in building blocks
markc replied to Gus Potter's topic in Brick & Block
I haven’t seen or heard of anything, then again most of the new builds are cracking and falling apart without defective materials -
Wacker plate or walk around on it or use a thumper ( never known real name, heavy block with a long handle). often surprising how far it will compact … you are really just knocking the air pockets out of it
Blinding should be compacted or it will compress when loaded
BCO won’t look twice. Get on with the step down and at the same time beef up the foundation stone. (You are just looking to stop soil erosion).
Lot of civil engineering going into the Patio
I would use the same stuff in the gaps too. regarding the cornerstone, concrete underpinning would be the best description … but don’t let the term scare you.
Larch cladding... will it come down. Place your bets..
markc replied to SuperJohnG's topic in Building Materials
Got to agree, COVID gave suppliers an excuse to put prices up so they will not be coming back down to pre COVID levels, but there are good discounts to be had now supplies are pretty much back to normal, shipping costs are a pain with container shortage and inflated fuel prices. USA is still buying up much of the European supplies following the fires and increase in demand for timber. -
Same dry mix you used for the bed, push it around into the gaps and pack it down. didn’t notice the corner stone before, would have been easier before the slabs but I would now clear away some of the mud and part way under the stone, (going around the side too), bit of shuttering and drop some concrete in, poke it well to make sure it goes right into the void and tight under the exposed corner stone …basically stabilise it to prevent rain washing stuff away. so much easier in my head than to explain.
180 is fine (no pun intended) I have just done a load of solid oak worktops and used 80 grit on a belt sander to take the shear off and then a quick once over with 120. allow the oil to soak in, buff over by hand and fantastic finish hardest part to learn is that tickling the timber while sanding makes the bits show up more, be brave and give it a good overall sand so the oil soaks in evenly
Yes you will be fine
- 9 replies
- ceiling ties
- first floor joists
As above, sand the pencil marks first then keeping the dust on the sand (glass) paper do the grease marks, the dust rubs into the grease and helps draw it out of the grain
If this is only a temporary measure (taking the walkout) then as long as you don’t load the joists from above they don’t need anything as they are technically in tension with only self weight causing deflection.
- 9 replies
- ceiling ties
Loads of details but after reading this last night and again just now, I still cannot get the picture in my head of what you are doing or wanting to know. a sketch or two? And or specific questions? I’m sure this is why no one has responded yet.
- 9 replies
- ceiling ties
We have loads of tree surgeon customers and several of them have wood chip burners …. All hate them, only upside is the free fuel but they say that’s not worth the hassle.
Heat gun or blow torch (care needed not to pop the surface)
What's the right tool for cutting corner alu profile?
markc replied to Dreadnaught's topic in General Construction Issues
At 1mm thick it’s a hacksaw or cutting disk, tinsnipsb would distort the profile and chip the powder coat. I would use an ultra thin cutting disk .. masking tape where you want to cut, mark the line and then straight through nice and clean, tape protects the coating- 11 replies
- cedral lap
- cladding
(and 2 more)
The insulation will be fine, just keep your hot and cold runs away from each other, I have never understood why some people run them close together
Options for stepped flashing mortar removal.
markc replied to epsilonGreedy's topic in Tools & Equipment
Taking out the bulk with a diamond disk is the fastest and easiest, the raking bit you show is great for cleaning out the ends and verticals
