markc
    22
Everything posted by markc
  1. markc
    Lathe
    Could be separate pull-in and run windings? But then there would be a spare aux contact to cut the pull-in circuit. plus not usual on smaller machines, even old ones
  2. All sound advice. And if you wish to reassure yourself - take a broken block out from below and you won’t worry about them falling again.
  3. Yes it is possible for you and pretty straight forward. It doesn’t need took pretty with straight joints. Good clean up, scraping or pressure washer so you can see what you are dealing with, then cut away the bad stuff and replace
  4. Fabricated and fitted loads of them in the past. Nothing mystical about them just needs a bit of thought and a few measurements. there is a previous thread with examples and sketches etc. But can’t remember the name of it.
  5. You can get away with almost zero fall as long as the valley/gutter is large enough to handle the amount of water without overflowing. steeper gradients get rid of the water faster and therefore require less volume
  6. +1 on what @Digger1 said. Save money by getting good deals, less waste and saving unproductive labour.
  7. Also be wary of cheap flexi’s and tight radii. The pan in my garage (fitted by previous owner) is too close for a decent flexi bend and I can only get the corcertina type in … last a couple of years and then split. The armadillo type flexis are much tougher but larger bend radii.
  8. Agree with all of the above, there is no magical gadget that will crawl around the cavity doing what the brickies should have done in the first place,they either didn’t bother or didn’t understand what and how insulation works. why is taking down not an option? It is the easiest and cheapest solution.
  9. Definitely, I’ve stopped using my cast iron pans and now got some cheapie frying pans from Amazon, much easier and less cringe when putting them down
  10. First thing to ask yourself - is it penetrating damp or damp trying to get out? removing render can be laborious, expensive and end up with a horrible looking brick that looks like it’s be hit by a 1000 pigeon Sh1ts. sand blasting cleans it up well but then the brickwork can stilllook bad if it’s spalled and crumbling. also render that is loose and cracking allows water behind and then it’s trapped.
  11. Very little noise transmitted through a wall tie, if you want to improve then use a longer tie and place at an angle, not as strong but does allow each wall skin to flex without directly pushing the other skin. No idea how much low level noise will transmit in a domestic wall but in Stadia etc. The sound pressure has a big impact on the structure
  12. Makita impact driver is awesome, I’m still using Dewalt drills but as they wear out I will be switching over to Makita, I also love my Makita 165mm circ saw … brilliant for flooring and trimming doors
  13. Hmmm, really not sure, maybe @nod can help
  14. Sounds like they could be rust spots but to reoccurs there must be assitional moisture, any chance of a small leak above?
  15. You missed Tension Control Bolts (TCB’s) and oh the pain of HSFG’s with indicating washers ?
  16. Absolutely! I had one run a red light, straight into the side of me and then start ranting about drivers not looking out for bikes
  17. Oh look kids, another Curtious cyclist. … ?
  18. From many years of building steel structures, marine and railway engineering, the washer always goes under the part you will turn (additional washer if other side is covering a slot. bolts always go upwards - if a nut should happen to come off the bolt will drop out and be noticeable. never heard of lubricating nylocs as they are made to be used once.
  19. No personal experience but any system is only as good as what is underneath it, can you give any more details of make up to give us an idea of what you are doing and wanting to achieve.
  20. What is in the garage? What do you use it for? Machine tools etc.? if nothing special the just get a garage consumer unit with a breaker for lighting and one for sockets
  21. Bit of cash to a couple of locals to give you a hand, crane seems excessive
  22. For small erecting jobs (staircases etc) in difficult spaces we used to hire a Roustabout, telescopic mast on 4 casters with a hand winch and wire rope, hand powered mobile crane that could be transported in a van
  23. Would love to know how that meter gives CO2 emmisions
  24. Built-in fridges/freezers and pretty much any appliance is all about the install when it comes to noise. Recently installed a neff unit and it was really noisy, loosened a couple of the screws that were making the side panel act like a drum and then made even quieter with a block of timber stuck behind the kick board to stop that resonating … after that couldn’t hear it at all.
  25. My smart meter took around 2 months after install to finally communicate
