markc
    22
Everything posted by markc
  1. But you need a phone line first, did you ask for a phone line or a broadband line?
  2. Looking great, well done
  3. You speak to BT, if they mention broadband provider say you don’t have one because you don’t have a phone line. they then arrange with openreach
  4. Buy or hire a sound meter and go around your house and garden etc. You will be astonished what readings you get. we make regular sound level checks on machines we sell and the results are often baffling. before overthinking and over scrutinising manufacturer figures, get a feel for sound pressure levels
  5. Think the inside of Barbarella's spaceship., now that brings back memories … or should I say teenage dreams
  6. The ground pressure of an excavator is very low. A layer of sand/soil/hardcore over the top will prevent the tracks catching hold … just tell the driver about it so he knows to be careful when turning. axle weights of delivery vehicles are more likely to cause damage
  7. Get a new well fitting door made or get a decent joiner to sort the existing door. some things are better not replaced with new.
  8. £2771.00 per square is on the high side but anyone quoting at the moment is/can exaggerate their prices because they don’t need the work. Plus extensions can be messy and problematic.
  9. aluminium or cast your own in dyed concrete
  10. Is it actually bent or wasn’t straight when treads/plates were bolted in? Bolt holes are oversize to allow lining and levelling of steel prior to tightening up. loosen the bolts and then have a go at levering into alignment, then tighten up.
  11. In that case car body filler
  12. Good wood glue and add sawdust, far better than any tub or tube stuff
  13. Slow speed and lots of weight behind the drill. ohh and interesting big hole you have there sir, you should build a house in it
  14. Just for the Sh1ts and giggles! if the earth warms up we won’t need insulation and will burn less fuel to keep warm ? how many climate protestors turn their heating off and wear more clothes? Throw away their phones and electrical devices? And walk or cycle everywhere? the more humanity progresses the softer we get, the more we find fault with everything and the more we go backwards. answer to climate change ….. cull half the population … and allow the protestors to volunteer first.
  15. Ahh yes Rosin is definitely not good for plastic. that’s why you should never put one of those car air freshener things onto your dash or centre consul …. The plastic or vanilla gets eaten away. Luckily mastics and sealers are rarely rated on their fresh mountain odour ?
  16. I can see trowel mastic being a problem but that has a very specific use. when you think about it, most cars have panels and trim bonded with mastic, and mastic is also used for sealing rainwater goods etc. a quick check of the particular data sheet should avert your fears
  17. I’ve never heard this and can’t imagine why it would or could be true
  18. Can’t be sure but I reckon it’s course sand. there are loads of different sands but they can be broken down into 3 basic categories soft sand - fine often red in colour and used for mortar. course sand, similar to soft but larger grains, often used in smooth rendering etc. grit or sharp sand - ideal for concrete and textured render. for your project I wouldn’t worry about it. Use what you have.
  19. For herringbone the floor needs to be flat. The glue will be vertically nothing so allow 1mm at most to account for minor humps and dips
  20. A lot of H&S is definitely over the top! recent job, working on a scaffold with a platform height of 18inches the guys had to wear full body harnesses and remain clipped on at all times, but in the office they can stand on a chair to pin posters up. yes the chair is higher than the scaffold tower fitted with handrails and toe boards etc.
  21. At the end of the day that is not a lot of movement in 60 years. absolutely, my daughter moved into a new house 4 years ago (luckily renting) hers and many others on the estate have gaps you can fit your fingers into. The builder says it’s just normal settling! I don’t think many of the new houses will still be standing in 60 years.
  22. Nope, my reply is within the quote from you, not easy to spot I agree
  23. Good morning and welcome, if life isn’t scary then you are not pushing yourself. a wealth of knowledge on here by searching past topics and posts, failing that ask away.
