Everything posted by markc
Agreed, short short laths and no way to fix the tiles, relying on gravity and a bit of gobbo to prevent wind getting under them. You could add clips to hold ‘clamp’ tiles to each other but still only self weight holding them down
Depends on your shower head and how people use it. I like an overhead rain shower, my GF tends to use the handheld but leaving it in the holder and pointing the spray so that it hits the opposite wall. 1000mm is a decent size glass screen and shouldn’t be any problem
Roof level vent - 1810 single storey house
markc replied to tvrulesme's topic in Roofing, Tiling & Slating
Sounds plausible and if the ground has been raised, when you dig out you may find there are bottom vents that are also covered. -
I reckon the internals have been blocked up. Just opening up these will help to clear damp but really needs air to flow rather than just draughts. where is the damp? Generally or at the bottom of walls? -
Did anyone else pop in? 2-1/2 hour drive for us and stayed about 45 minutes. after all the fuss reminding visitors COVID Passes or recent LFT was required we were very disappointed that they asked for nothing. Small displays packed close together and no distancing. I wasn’t expecting Ideal Home Ex, but this was very disappointing.
Precast Concrete Stairs or metal?
markc replied to CalvinHobbes's topic in General Construction Issues
A well build wooden stair does not move or squeak, metal does not have to ring if designed well with vibration damping (small welds in strategic places to pre stress the members). precast concrete is bulky and ugly but a bespoke cast-in situ stair can be really cool and slender/interesting. -
I’ve just fitted a Wren kitchen that was delivered earlier than expected.
Certainly looks similar to knotweed but I’m no expert, getting rid of it is a time consuming and labour intensive process. cheapest and easiest is to go around and inject glyphosate into each stem (repeat every couple of weeks), spray the smaller shoots. Dig a barrier trench to prevent further spreading but make sure this is far enough away that the root things haven’t already gone further than the trench.
The agreements look like they were quickly thrown together trying to look official while not making any allowance or liability for anything going wrong etc.
I can see no reason for this beam to be continuous as the loads inside will be far higher than the balcony so it would be better to thermally break the beam inside and construct the cantilever separately (but connected). in the past we have done beams with plastic flange and web plates to make a continuous beam but electrically isolated.
Can’t offer any info but it does make you wonder about off grid homes, there has to be some deviation route for single dwellings
Hybrid Off Grid Energy Feasibility
markc replied to Curtis's topic in General Alternative Energy Issues
At 30k over the lifetime of the property I would say it’s money we’ll spent. if it was a temporary supply then a combined diesel, battery, solar and wind set up would be feasible and economical(ish). I was at a trade show last week and some of the new generator/battery power modules look really good -
Sewage treatment plant, in bad ground
markc replied to Russell griffiths's topic in General Self Build & DIY Discussion
the tank popped up like a U boat. ???? Just spit my tea out -
Good morning and welcome, a search of past post will answer most questions. Failing that, ask away and I’m sure you will get your answer … and probably a few odd ones.
Difficult to say without seeing it, but I really doubt you are getting an on-site weld repair for £70, I reckon it will be chemical metal (maybe) but more likely a bit of mastic
I’m guessing the “weld” will be sealer or at best lead sealed
Cast iron can be welded but it’s not easy and I doubt anyone would attempt to repair a gutter in situ. can you post a pic of the problem
Got to agree with the above, gabions (still trying to auto correct) are intended in place of cast in situ walls/abutments or sheet piling etc. if the bank is well established then the root systems will hold it
I like your ingenuity … we need more people with a can-do attitude.
@saveasteading good point, I didn’t consider the potential floor defection … I’m used to commercial construction. upper channel sounds good or even shanked screws in clearance holes in the top plate.
No specific way better than the other here, screeders would prefer you to stick it on top leaving them with a big open area to go at, you could also put in on top of celotex and use the screed to hold it in place or you could go down to slab but it’s always nicer to know the insulation is unbroken. If you go onto insulation then use double sole plate so the top of it sits proud of screed to fix bottom of PB and Skirts to.and the added piece of mind of better load distribution.
One on top of another with staggered joints, but on a 100mm slab there really is no need. hanging cabinets on one side your most important loads are rotational wanting to pull the top of the wall over so make sure the header is screwed through into the joists above.
A stud wall does not impose much load, if you want to be doubly sure then double the sole plate, this will distribute the load across the length of the wall. no slab work required … unless it’s about an inch thick which I hope not.
Gabion not gaboon. Stupid auto correct ?
