tonyshouse
Everything posted by tonyshouse
Thin insulation is very expensive, cheaper to drop the substructure 100mm and use an extra 100mm of insulation. aerogel and VIP’s are mega expensive, unaffordablly so
Need to be very careful that the whole floor is properly air sealed, most chalet bungalows and loft conversions have bad draughts under the floor, cooling the ceiling below and the floor above , with UFH a huge amount of heat could be lost unnecessarily
I would leave it a year then do it, too much drying out and settling down to get it all perfect til then
Henley box
I would do new foundations while you are at it, horrid if you were to bet differential settlement, extremely likely
Bungalow Conversion - Brickwork/Cavity Insulation
tonyshouse replied to richo106's topic in Brick & Block
Other ideas, maximise insulation while you have the chance. Hundreds not tens of millimetres -
Won’t help sadly
I would put slithers every so often between them known as sticks to allow air to circulate, raise off floor and leave for a couple of months if in a heated space, longer if I heated and clamped and weighted but allow air to circulate with them restrained nicely, five clamps
Take it down!
Ram in strong dry mix if decent gap and flaunch edges i would not use tile adhesive
Cross section description for block build?
tonyshouse replied to CalvinHobbes's topic in Brick & Block
305mm wide cavity 3x100mm batts, they don’t like sliding over each other, crumple, roll up or leave gaps at the corners. the brickies put some in which I had to remove and re do as folded! I banned them did every bit myself. -
I tried that but it proved more of a problem, I did slightly compress the blocks of sheets together to avoid that problem -
Real world passive house heating demand figures?
tonyshouse replied to Smallholder's topic in Boffin's Corner
PH is based on average outdoor temperatures in your location over a year to calculate the heating demand, different every day and summed up over a year ————- re my interseasonal store:- No but it is contributing, winter starts mid December and ends at the end of Feb when the sun starts warming the house up again anyway downward heat losses are greatly reduced , basement 19C this year at end of Feb, I do use some heat from a small heat pump down there now though as have family staying and they are not as hardy as me, 19C is ok with no draughts, but when inactive I need a proper woolly jumper. -
Insulation thicknesses need to thought in terms of hundreds of millimetres , two or three, one barely cuts the ice.
I am on 42kWh/m2/a all in , heating is almost never needed, -3C need 60W, -6C 300W I think I am probably OSB about 7kWh/m2/a for heating but I have difficulty separating getting out HW demand -
Blauberg vs Boulder
tonyshouse replied to Bosi's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Sorry no -
Insulating original external wall
tonyshouse replied to jayc89's topic in House Extensions & Conservatories
I sometimes recommend the first 600mm should be insulated. Better plan would be EWI -
Best to support the weight of the window on outside skin masonry, I used steel dowels in the reveal mortar beds to carry the weight and then fixes styles in my case to the back of the outside skin. Nothing has moved, I made my own cavity closers from pir or eps
Connecting timber lintel to brickwork wall
tonyshouse replied to SillyBilly's topic in Floor Structures
Cut a pocket
