tonyshouse
Everything posted by tonyshouse
Loft height is 2.0m at the centre
tonyshouse replied to Maggie's topic in Lofts, Dormers & Loft Conversions
We have done jobs where we dropped the first floor ceiling height a bit, need clever engineer and more difficult to find additional height. regs require 2m at top of stairs can relax to 1.9 but floor joists will need to be 200mm and ridge beam could need to be 250 overall move house is my advice -
Loft Hatch recommendations for bungalow please?
tonyshouse replied to patp's topic in Lofts, Dormers & Loft Conversions
Double loft hatch for me, fully sealed on both, insulated to same standard as ceiling say 4 or 500mm quilt same u value for hatch arrangement more likely using some sheet insulation top loft hatch can flap upwards, mine has a bespoke counterbalance system -
Definitely do NOT use dot and dab
Aerated blocks crack far too easily, move around and are naff in comparison to medium density blocks. No cracks is normal with them.
Sealant for joists in blockwork
tonyshouse replied to SuperPav's topic in General Construction Issues
tonytray is 100% and permanent , not only the joist ends that leak but the blocks themselves, any cracks and those can develop later, joinsbetween blocks, bed joints and joists can shrink and move too. -
Verge with no undercloaks or dry verge systems for me, I like 45 degree cuts to the bottom outside edges of slates. No water should be able to track into structure
Block and beam cut block edge question
tonyshouse replied to ollieD's topic in General Construction Issues
I think thin mortar bed on slips under edge blocks. Don’t forget dpc -
Should be OK
Thanks ! 10mm in for a porch , I often use 100mm lead
Cost comparison of standard tarmac vs block paving
tonyshouse replied to Moonshine's topic in Driveways
Also consider maintenance- tarmac often zero, block paving a nightmare for weeds, printed concrete near impossible to repair -
Garage conversion into utility room
tonyshouse replied to Abeer khan's topic in General Construction Issues
Always on the warm side of the insulation- 1 reply
UFH Just ground or both floors or all radiators
tonyshouse replied to NewToAllOfThis's topic in Underfloor Heating
Insulate better then design heating if still needed i did once consult on ufh for existing flat over garage, did ufh above an insulated and soundproofed ceiling from underneath, everyone said it wouldn’t work but it did brilliantly -
I hate blinding, I live vb in floors
Plus plenty more on heating bills for evermore if dot and dabbing and literal cold feet too
Do we need a Party Wall Agreement
tonyshouse replied to Becks1974's topic in Party Wall & Property Legal Issues
Not advice but I would ignore other neighbour - lots of people don’t even know about PWA -
Slightly taller wooden skirting, some stick carpet on with a nice trim on top as an alternative
Very hot soapy water for me
Wrong! DPC can be flush or poking out
Mechanical fixing for me I built a peg (150mm long steel dowel into the reveal 50mm poking out to sit the window on ) for wide windows a centre support from structure below. Window reveals fixed in my case to ro the structure I hate the idea of combining insulation with structure, a mistake in my book
Damp internal blockwork on chimney
tonyshouse replied to James94's topic in Roofing, Tiling & Slating
I would like to see a lead saddle under the ridge tile that abuts the brickwork. -
For me comfort was more important than payback. I like your levels of insulation and wish others would do similar. energy is only ever going to get more expensive and so payback calculations will go out the window and lots including the regulators will regret that they didn’t go further with hindsight.
If you are worried you can paint it with “blackjack” to 75mm below dpc making contact with it. Then simply overlap the dpm on that plenty of people don’t?
Ideas for a large corner window
tonyshouse replied to Blynchy's topic in New House & Self Build Design
Simple and cheapest will be a post at the corner. Otherwise an expensive skyhook agree about overheating, that can be ugly, building physics model will likely suggest reducing west facing glass and shading to south glazing -
Should be OK, they have been there a good long time which proves that they are ok. Need SE to do calcs and a soil survey for them to work with.
