Gus Potter
Everything posted by Gus Potter
@MJNewton Thank you MJ for your initial post and the follow up. It is a great informative thread. A great demonstration of how a pragmatic approach, working together with suppliers / contractors / the technical advisors can lead to a good outcome without having to resort to stripping things out and all the grief that can bring. Thanks again. To add a bit of food for thought... Often you hear bad reports about flat roofs, like all things in life bad news travels faster than good in general.The contractor /suppliers / installers / roofers are the first to get it in the neck when you start to see ponding / puddles on the roof. If you are thinking about a flat roof then you need to take quite a few steps back to prepare the structure in advance.. this needs forward planning! To explain I'll use the following example. You build an extension out the back of your house. Much of the below also applies to new build. The roof timbers / joists.. could be metal and often span from the new front wall of the extension back to the line of your existing rear elevation. You often want to open up the rear wall of the house to give a more of an open plan feel. You need say a steel beam / big concrete lintel to make a wider opening to access the new extension. This beam often rests on the old walls each side and adds point loads where before the load was spread more evenly. These point loads travel down the walls and often adds a bit more load locally to the founds that have sat there quite happily without moving. This extra load often causes some extra local settlement unless say the house is on solid rock. Your new beam / lintel bends a bit in the middle. Near the ends of the extension the rafters are supported on a good length of wall, maybe the side /gable walls of the extension.. but half way along the existing rear elevation you have a found that is settling and a have beam that is bending. Thus you already have a dip that causes water to pond. Steel beams bend under their initial load say from brickwork / floors / roofs above.. then they bend a bit more if you have say snow on the roof. But often they go back up a bit once the snow melts. But timber is a bit different. Timber (concrete to a lesser extent) suffers from what is called creep, it's a natural material. You can see good example of this if you go into an old pub with exposed beams.. observe the sag / creep. BS 5268 for example recommends a deflection limit of 0.003 x the roof joist span for some applications. So a 4000mm span can deflect 0.003 x 4000 = 12mm! But with modern flat roof membranes you can already see trouble ahead. What happens is that the poor builder puts everthing in flat and level and a few weeks / months later it is no longer flat, the steel has deflected, the timber is creeping and the founds are settling locally. You then see ponding on the roof and start asking questions. If you look at each element in isolation it is often not much in terms of settlement / deflection.. but when you add all the movement together you can soon see how the flat roof now has low spots in it. In summary make sure your SE or structural designer knows that you are going for a modern " true flat roof" early on and this can avoid later issues.
- 59 replies
- flat roof fall
- firring
(and 2 more)
There are often two mind sets.. 1/ To look at the wild life as a problem that interferes with your financial gain 2/ To accept that you are interfering with the habitat and make a serious effort to provide an alternative (during the build) and enhanced habitat once you have had your way.. development wise. If you are inclined towards point two then you can look at providing a "temporary habitat".. enhanced feeding, stacking cut foliage, even pallets to encourage insects, to provide shelter, natural food for young birds and a safe space for birds and so on to dive into if a predator is about etc. A building site does not have to be barren. Calvin you seem a point 2 type.. you have time now to act on the alternaitve habitat, supplementary feeding and so on. Take this approach and you will enhance the wildlife and not have to worry about the chimney. Then when you finish your project you can enjoy not just your new house but all the wildlife that has been turning up during the build.. what more could you ask for? Have to say ten out of ten to you for posting about this.
Keep it simple stupid. Have designed some houses with the plant rooms in the attic and it works fine. I would recommend that for future proofing you design the plant room in the attic so it can carry some good point loads from say a couple of really heavy cylinders.. say 500 litres each plus the self weight of the tanks. That is about 1.3 -1.5 tonnes working load. A lot of the stuff you see on BH is actually cutting edge stuff.. ASHP etc, the theory is explained in depth by the some members.. To do this easily (furure proofing) you can use steel beams or just position your load bearing walls.. easier to do. Also work your way down and put the manifolds in say the towel cupboard, laundry room if a big house.. you have good crisp bed sheets and so on, even put the manifolds in the bathrooms.. makes them super cosy! It's a luxery but let's just enjoy a bit of that! To afford you future flexibility separate the floors into zones. Put a manifold on each floor supplied by pipework of a decent bore. It won't cost you that much extra but you may well be glad later if this is your forever home. Yes, we have a wide range of heating controls available at the moment, smart controls and so on but who knows what will be available in the future. Best to run some good large bore pipes from the attic to the floors to give a plenty flow at a low pump head. In the future you can restrict the flow if need be but much more difficult to increase if the bore of the pipes is too small layout is restrictive. The laws of hydraulics won't change. I
Radian. To get the best response can you do a sketch, take a photo and upload? Give as much info as you can.. if in doubt about how much info to provide just chuck it all in!
Yes it's a dilemma as to a fair charge, Architects / SE's and so on get a bit of a slagging on BH but it's social media! I've been a member of BH for a couple of years (I think) maybe a bit less so very much a newcomer when compared with the mods. Also, there are some past icons such as Jeremy Harris, still plenty folk that really know their stuff contributing and most importantly new members that are coming on board with new ideas as building technology is developing.. The new members, for me, keeps the site refreshed and the "old folk" on their toes! Another attraction for me is the humour that members come up with.. it's a great site for sharing ideas having fun with like minded folk and exploring ideas. I post stuff about the SE side and the odd bit about the gorund but I learn a lot here and enjoy reading about what folk are doing and so on. It's a good friendly site. Ok punloos.. your into electronics and systems.. but you have a brain and common sense. That is the key. Just ask your questions on BH, don't worry about asking a daft one, BH is not a knowledge test! Often I think that folk worry about getting trolled, using their own name. Some folk crop up here on BH that clearly are professional developers asking for free advice, some are trying to play the planning system.. but on the whole I think many are just honest in their intention.. yes if you are in detailed negotiations to buy a plot then remain anonymous but after that.. ? In summary just keep asking the questions, best to ask rather than build it and wish later you had not asked the question! Oh and have you had a Greggs Steak bake yet! I know the guy who was part of the development team on the steak bake..So THERE! my claim to fame
@LSB It's good to ask questions, that is what BH is about.. sharing views and knowledge. I learn loads here and enjoy reading the posts on ASHP etc and stuff that is just interesting. From time to time I may be wrong..but better to ask questions now rather than after something is built. LSB. An experienced SE, Building Contractor, serial BH self builder will often just look at beam/ rafter sizes and form of structure and go..that looks a "bit tight" lets have a closer look at that. I can see that your 150 x 47 rafters are tightly sized.. based on the one page of calcs you have posted. Getting "it tight is ok".. that is economic design. I use my own name here on BH. I'm not criticizing your SE but I am highlighting that the rafter choice should be justified in your calcs, particularly in terms of your deflection limits and whether the rest of the roof covering and internal linings are compatible with those limits. It's important to recognise that if you have say a steel cladding over a timber joisted roof then while the timbers may be strong enough to carry the loads they may bend (deflect) so much that it over stresses the fixings on the cladding. The cladding supplier will specify what the maximum deflection of the underlying roof is to be. Exceed this and you void your cladding warranty. Sometimes on an lean to extension at a 4.0 m span rafter it's easier to specify a 195 x 45 rafter.. this gives you plenty depth to insulate the roof, run the services and ventilate either by an air gap of by way of a membrane, sarking and almost full depth insulation between the rafters.. much food for thought!
Welcome @un355 You'll find a lot of great info here. If you have never built a house for yourself before then I used to say pre covid that with an Architect, some support, a good builder who will hold you hand a bit and a fair wind you could save some 10% - maybe 15% tops if you do a lot of the admin type of stuff yourself, research deeply and not pay too much for the plot. Admin would include things like; sorting out the services, making the phone calls etc. Now, with the current fluctuations I would reduce that to say 5 - 10% to be on the safe side. That is based on building a like for like house you can buy off the shelf. However, it depends on how you measure affordability. With a self build, even on a limited budget you can get a house that is "bespoke" just for you. Also, building your own home is something special.. it's your own castle and relatively few folk do this in the UK. You get that quite satisfaction, sense of achievement from self building and that has value.
@jfb I have a similar issue that I'll need to face up to this year when I come to do the roof. It may be worth looking on the net as there are some reclamaition yards that provide a reclaimed matching service.
@puntloos"Can you rephrase that last sentence?" Hi puntloos... of course! On reflection I should have chosen a different form of wording, but enthusiasm took over! BH has a great range of members, from folk that are just starting out to serial self builders, professional Contractors, Architects, SE's and other real specialists that really know their subject inside and out. One common trait many have on BH (whether just starting out on you first DIY project or not) is that we spend a lot of time just thinking. I had a recent discussion with a highly experienced Architect (40+ years experience) where we mulled over how much time you "charge for" and how much "brain time" time you really spend on a project. Some folk on BH will for example be sitting having say lunch, a Greggs bakers experience, putting the bins out.. just day to day stuff and presto.. into your head crops up an idea about your build / DIY project, how you solve a problem. This applies to almost everyone including those who make a living from design and construction. This thinking time often does not appear on any invoice / balance / spread sheet. Things can become counter productive when there is a lack of clarity, understanding between the design team and / or the contractor. Most commonly this is precipitated by a lack of effective communication. If you are say a novice self builder then you learn as you go. At some point you may become frustrated that things are not to your absolute satisfaction as you have been learning plenty..and this can start to eat away at you.. thus counter productive or words to that effect?
EW is ΣW (Sigma W) which is the sum of the all the factored load (W is the loads from the ULS column) on the beam. Thus ΣW = sum of total ULS load =0.46 + 0.45 = 0.91 kN/m (kilo Newtons per metre run) * 4.0m (beam length) = 3.64 kN (kilo Newtons) = the factored design load applied to each beam. Zyy Req... Z is called the section modulus and the yy indicates about which axis of the beam the value of Z applies to. The British Standards and Eurocodes use a different axis of notation. Your SE is using the Eurocode here. The letters "req" are short for required. The SE is working out what value of Z (a geometric property) the beam needs to have as a minimum to carry the load. To calculate the Zyy required we use the formula Z req = maximum bending moment / maximum design stress allowed in the timber. The bending moment is shown as m = 1.8 kNm and the design stress is 14.8 N/mm^ (Newtons per mm squared). We need to make the units compatible so to convert kNm (Kilo Newton metres) to Nmm (Newton millimtres) we multiply by 10^6 as below. Thus Zyy req = 1.8 * 10^6 / 14.8 = 121621 mm^3 = 121.6 x 10^3 mm^3 this is the minimum value of Zyy required to carry the load. Next the SE is checking to see if a 150 x 47 timber has a Zyy value greater than the required minimum. Zyy for the proposed timber is calculated by the formula b*d^2 / 6. Beam width = b = 47mm, Beam depth = d =150mm thus Zyy = 47 *150 *150/6 = 176250 mm^3 = ~ 176.3 x 10^3 mm^3 (millimetres cubed) > 121.6 x 10^3 required thus OK. The Iyy is called the second moment of area (units mm^4 ) and you'll probably see this on the next page when the SE checks the deflection.
Lots of great views expressed here. For me the test to apply to your design team is this... Ask them where they see the risk to you in the design. That could be on the Architectural side.. say bespoke materials price fluctuations.., the SE.. where is the risk.. is it in the ground or some where else, the folk that are maybe providing services to the plot. Where they are confident that say the doors, windows, roof will perform in the long term and where they are less sure about long term performance. It might sound a bit odd but a good professional will explain to their Client where the risks lie, inform them and let them make their decision. They will also explain / outline how they are going to save you a fair bit of money that will mitigate their fee maybe make it cost neutral!.. but they won't tell you how until you sign on the line. It 's a case of seeing if they are open on honest about the whole design. You too need to accept that if you want something special you'll probably need to take more risk if you want to keep the cost down. In summary just have an open and honest conversation. If you don't hit it off then find someone else, even if their fee is a little higher, in the grand scheme of things a good designer can save you thousands sometime tens of thousands on a self build. Also remember that designers love working with engaged Clients who communicate with them too! often you'll find that they don't bill you for every hour they work and that when you look at it in the round your shopping about has been fine up till now to enable you to get a feel for the cost but has now become counter productive in the relationship?
Thanks, appreciate your help. Brain fade.. can now see how it shifts the dew point outwards. ta for the heads up.
It's interesting how this is panning out with the pricing and erection of kits. I've been mucking about with this as a contractor and a designer for a good thirty years in Scotland where we embraced TF a bit earlier than down South. Some of the Scottish TF companies have sold out to the big outfits, some truss manufactures also. What I can say is that it is worth a look at getting your local builder / joiner to price to stick build the kit and buy in the trusses. And / or spend a bit more earlier and get your SE to do you a traditional kit with the roof you want, if you need a bit of steel then it's relatively cheep for your local SE / Builder to sort this out for you. Even 30 years ago it was hard to compare like with like from TF suppliers, now the waters are further muddied. Really unless you are a developer / or have a lot of technical knowledge you have no chance at getting like for like costs from the TF folk on a one off build. What you do need to know is what could you build based on stick built with you supplying the insulation and so on, how long will it take and then make the call on what suits you. Then you have a real base line. I often do the panel drawings for the local builders and spec easliy sourced stuff (truss clips / hangers) and rough out the truss design with the key dimensions to make the roof bracing work. You'll need to pay up front for this but I have found that it is often an economical way of doing it in the long run. It can also work for some folk on the cost plan where you don't need to stump up a big deposit for the kit up front.. you buy the timber.. belongs to you then you pay as you go as it gets erected. Also on the "soft side" many self builders change their mind as they go.. stick building can offer more flexibilty to "just change your mind" without the financial penalty.
Good thread this and learning all the time. I have an ex council house two story terrace with cavity brick wall.. which has a howling draft in the cavity. Was contemplating EWI. Problem is that the inner leaf of brickwork holds up the roof and first floor... and at ground floor level there is a 4" x 3.4" inch timber wall plate build into the load bearing brickwork, all be it it is pitch pine. In other words someone thought it would be a great idea to put in a bit of wood instead of a bed of mortar in the inner leaf which is carrying all the load from the house above! So not keen to fill the cavity as the timber could rot and the house settle. @House man check you don't have the same dillema as I before progressing.
Advice needed before I tackle the installers!
Gus Potter replied to MattB67's topic in Air Source Heat Pumps (ASHP)
@MattB67 Glad you got it sorted! I'm old sckoooool but the old plumbing / hydraulic rules still apply even with modern unvented sytems./ ASHP etc. It looks great having all the pipes level and well clipped, nice to see on an electrical system but on plumbing no. We know we need to get the air out so lets run the pipes on a slope so we can get the air to a place we can easily vent it. Don't do your smaller bore (any pipes if you can) pipes so air, debris can get trapped.. no funny U bends just under the rads say.. run them so that the metal gunk gets picked up by the magnetic filter. Make it easy to flush out the stuff that the magnetic filter won't catch.. it basic stuff and good workmanship. If you are using under floor software to design your loops make sure you check you bend radius is compatible with the pipe you are using! And when you are installing pay particular attentions to the bend radius or you are inviting trouble. Worry less about the pipe spacing as if you choke a loop you will have much more to worry about! If you take care of the basics you'll save yourself a lot of grief later and get the best out of your tecky controls. Take care of the basics and this will allow you to get value out of your high tech controls. For me I would go for the simplest design that you can that is easily maintained by your local heating Enginner. Save your money.. and spend it on insulation or making your house just a great home.. buy some furniture, pots pans etc. -
Temp..Yes good /great summary. @LSB Is there another page or two of calcs relating to the roof? I have deduced that the calcs are based on Eurocode 3 rather than BS 5268. I did this by comparing the SLS (serviceability limit state) to the ULS (ultimate limit state) ratio. Your calcs give a ratio of 1.35 and 1.5 for SLS and ULS respectively and that correlates with the Euro Code safety factors. The BS code is different.. I'll leave the explanation out for brevity. Before making any further comment it would be good to see all the calcs relating to the rafters and the cladding on top. A 6" x 2" rafter spanning 4.0m invites interest even at 400mm centres then you have the insulation.. closer centre rafters the more bridging effect.. sometimes the lightest structural members can be counter productive? I can see an alpha factor... 16.0mm Assuming this is some kind of deflection limit then BS 5268 recommends a limit of span *0.003 = 12.0mm but the Eurocodes allow for the limits to be agreed to some extent between the Client and Engineer... they cut you a bit more slack.. allow you to innovate. I'm interested to see the if the rest of the calcs take into account the deflection limits set by the metal cladding provider and the internal lining provider.. say Gyproc? While the roof may not collapse it may bend so much that it tears the cladding fixings and causes cracking in the ceiling. If you are going to stretch the deflection limits as an SE you should be pointing this out to your Client and let them decide what level of risk they want to take on. Have you got a good builder who has said.. mmm, these rafters look a bit small?
Sorry for the OT post but maybe you have a rebate you can work with. When you have old solid walls it's a challenge. Your starting point here is look at how the wall is constructed. In the late 1600's the weighted sash and case window caught on for houses but this was high end stuff at the time. Have seen some steadings that have sash and case but the steadings were subsiduary to the main house so some Lairds were not that keen to share the luxury with their "workforce". There are steadings ( folk lived in part of them) and buildings for housing animals (barns / byres ). Sometimes you just have no rebate especially if the wall is 14" instead of 20" thick. The key here is that to fit a sash and case window they created a good rebate behind the rybats and lintel. The rybat is the stone up the sides of the window often looks like a key effect from the outside. Now with modern windows (even a sash and case window) you have space here to be innovative. Modern sash and case look alike windows are often fitted with spiral balances instead of pulleys and weights leaving you room to play with to get some insulation behind the window frame and up to / against the rebate. You do need some discrete fixings which act as a thermal bridge but.. you can't have all the cake..
Welcome Ruth. Great place to build. You'll get plenty help and friendly advice on BH. All the best with the project.
Foul Treatment Plant advice - choosing the right one!
Gus Potter replied to Dale Hesketh's topic in Introduce Yourself
Speced this tank on a new build job about 2 years ago. No adverse reports so far. https://www.wte-ltd.co.uk/pureflo_sewage_plant.html It's a bio digester, no underground moving parts. Key drivers were; 1/ 4 bed house with substancial principle living space but Client is abroad for a number of months only a cleaner in from time to time. 2/ When Client is back only two of them living in the house but from time to time have full occupancy with guests, two dishwashers running etc. 3/ That it has a CE approval which ties in with the regs and design codes in Scotland. In summary was looking for a tank that would work based on variable flows and loads. Much like a holiday home. In reality how they perform is based on how you look after them. Some folk that take a holiday let take their own bleach and chuck it down the bog! some put other items that don't bode well for anything "sewage". In an ideal world for the self builder who is using the house on an irregular basis / or with variable flows and nutrient loads then some extra control over the air blower would be helpful. Maybe like the app you have on your phone for controlling the heating. A few days before you go away you turn down the blower so that you keep plenty live culture ticking over with the odd boost to clear the pipes. Then a couple of days before you come home you crank it up a bit so its all ready to receive your homecoming gifts. Hopefully someone will make this technology readily available. -
Have you been "at rest" after your days away or doing something else? Apparently the human body "at rest" produces around 0.1 kWh but this can increase significantly when active. I'll stand corrected of course.
Onoff. The steel fabrication is done outside. All you are doing is making up some bespoke truss shoes out of 10 / 12mm flat bar.. well within your skill set.
Got to the age where you dabble in all sorts, realised there are folk that have forgotton more than you know, hence enjoy being on build hub, every day is a school day here for me. Keep up with the research Zak.
- 38 replies
- selfbuild
- experimental
(and 5 more)
Yes the raft with a void is an option not least as it provides a service space under the floor. Have done some jobs this way. On the technical side if you find a ground bearing raft is loading up the ground just a little too much then the weight of muck you dig out to create a void reduces the loading on the soil and bingo! it all works out.
- 38 replies
- selfbuild
- experimental
(and 5 more)
Hi Zak S. Yes that looks pretty soft right enough at certain depths. Looking at the cores the ones to the right seem to be from the surface, the left ones in the photo from greater depth? The shallower cores look like there is maybe a stiffer crust with soft clay below and that the bungalow founds are using this crust to spread the load out before it reaches the softer clays... The folk that designed the founds for the bungalow may have taken advantage of this crust. I would still expore the raft first. If the water table is high and not likely to drop then the soft clay can't shrink as it will always be submerged. It also can't go anywhere.. it is confined at depth. Once you go down a bit the pressures in the ground from a raft are often found to be very modest so even a soft clay can carry a surprising amount of load with acceptable settlement.
- 38 replies
- selfbuild
- experimental
(and 5 more)
