Everything posted by JohnMo
BWT AC002200 Combi Care, or Combi mate. both work the same way AquaDial Combi-Care works by introducing a very small amount of food grade polyphosphate into the water feed, sequestering the calcium in the water and preventing it from forming scale on the heat exchanger. Offers protection from both limescale and corrosion Suitable for whole house and single appliance protection Flow rates up to 54 litres per minute Easy change cartridge Cartridges have a 12 month life Can be used in soft water areas as a corrosion inhibitor Width: 120mm, Length: 215mm Max Flow Rate: 0.9 l/s
That what our EPC said we should be using around 5.5kWh.
Most inverters are configured to limit or zero export. You need a G100 compliant inverter.
Have you read the manual? You should be able to set the DHW production to reheat mode, schedule mode and a combination to the two. It looks like you are in reheat mode continually, so you throwing heat almost constantly to the cylinder. You would be better heating the tank once per day to a temperature that is acceptable to your usage.
They go on to the incoming cold water, and kitchen supply normally bypasses, so you decent drinking water. Alternative are something like a combi saver. This stops scale forming and would normally go on the cold supply to a combi boiler or UVC.
I have seen 15 degs as flow temp for ufh, and there will be a 4 to 7 return temp drop, based on your flow rates. Just looked at the dreams ASHP and the default setting is 12 degs. Don't think you want it too cool otherwise you get condensation issues.
The structural calcs are normal for window to door conversation, even if the same size, the calculations would say if what's there is ok or has to be replaced. Structural engineers are usually registered to perform their own calcs and issue a certificate, which planning is happy with and gives a warranty discount. Not sure a bi fold door would add stability! If you've done this through an architect he should have know you needed structural input.
Best ASHP manufacturer/model for new passive house
JohnMo replied to markharro's topic in Air Source Heat Pumps (ASHP)
There is plenty of info on this site with reference Willis heaters, it would be best to look around and have a good read. I find the easiest way to find stuff is search through google. https://www.google.co.uk/search?q=buildhub+willis+heater+site:forum.buildhub.org.uk&sxsrf=ALiCzsZxamojBzYQRLlAn3-Hb_saXJJJJg:1654722699811&sa=X&ved=2ahUKEwiF9uS14p74AhWVolwKHe94AiwQrQIoBHoECAkQBQ&biw=1253&bih=608&dpr=1 -
Did you have the mains water switched off?
Cylinder coil or heat exchanger leaking? It should be the only place where the heat pump fluids and DHW have an interaction.
One thing to always bear in mind with heat loss calculations is the worst OAT is only for hours or maybe a day or two, maybe 5 to 7 days a year. All the rest of the time the heat demand is lower. Have attached MCS manual, that will start you in the correct direction on sizing ASHP and buffers etc. 1. Read manual attached 2. Two situations, you and wife, you wife and others. Could you operate two cylinders, bring the second online when you have guests? Save continuous heat loss etc. 3. 2 X 250 to 300l 4? 5 maybe not 6 internal or external blinds 7 LG or Mitsubishi seem quite good from what I heard 8 could work You don't mention ventilation system? Heat-Pump-Guide.pdf
Hello No idea what you are asking, you may need to provide some more details.
Think you have answered your own question
Do we even have a standard protocol for car charging?
Responding to the pod cast linked to by Rishard. To answer your question, I am not saying that. The podcast, stated MVHR used 6% less energy to heat the properties, when compared to demand based ventilation (due to heat recovery). So the heating system heat input only. But MVHR used 5x the energy (electricity) to power the ventilation system (running the ventilation fans, controls etc) compared to demand based ventilation.
We got our as-built EPC
JohnMo replied to Conor's topic in Energy Efficient & Sustainable Design Concepts
We also managed an A, but was suggested I install a wind turbine at an estimate cost of £15 to 25k to give an A104. No! Loads more solar would be better. -
So the comparison is between demand control ventilation and MVHR within 149 passivhaus buildings. Heating, MVHR used 6% less energy to heat the properties on average than demand based ventilation. But MVHR used 5x the energy to power the ventilation system. For the same standard of air quality in the properties. A similar outcome in this other report also. Atamate_SDAR+Paper+2019+(1).pdf
Have a read https://www.thomasarmstrongconcreteblocks.co.uk/mortar-mix.html
I just measured internal walls and added 5%. Worst case you some leftovers or you need an additional sheet or two. Ended up with a mountain of offcuts and no full sheets left.
Are you adding external insulation. Fleece adds nothing to the U value. Have you specified what roof buildup you require, or are you hoping the contractor will supply what he thinks you need? Typically you should be adding 150 to 200mm exterior insulation, to give a good performance roof.
Go on the Aps store, Google or apple and download CDM wizard. Fill in all the steps and you then have a fully compliant risk evaluation. As principal contractor, anyone on site reports to you, you manage who is on site and when, a single build they should not be tripping over themselves. My build was a single trade and me on site, other than the loads I did myself and then it was me with various helpers as needed. Can I be the domestic client and principal contractor ? Yes or client your wife. Will I still need to notify HSE of a project (F10?) ? Don't believe you do, I didn't. Will I still require a construction phase plan? CDM wizard Will I have to produce RA & MS for every activity? CDM wizard Will I have to submit RAMS to someone ? No but needs to be available, CDM wizard.
General advice for refurb project on large property
JohnMo replied to Jimlad's topic in Other Heating Systems
All the stuff mentioned above, also look at how you operate the heating. Big thick walls take a lot of energy to heat up, if you operate the heating in short bursts all the energy goes into heating the building fabric. You may be better turning the CH flow temperature down and run the boiler for long periods, stabilise the building temperature, with a small setback at night.
