Everything posted by JohnMo
Also some areas, like the whole of Scotland do not add Flouride Other area it come with normal ground water naturally added. Do they add Flouride in your area for certain? Bear in mind, the rain water you are collecting, is the same water that has just washed your roof clean, of bird crap, dead insects and pollution that has settled on your roof. It also has none of the natural mineral salts, so these may need to to added to your diet artificially.
The models Nick recommended or a Lowara Ecocirc Pro - same as I have. Inbuilt timer and thermostat. Set it to time periods you want hot water, i.e. when you get up until you go to work, when you get home until when you go to bed. It automatically circulates enough to get loop to the temp you set it at then maintains that temp. You're trying to invent a wheel that already made and available off the shelf.
We were £2000 for install, that included slate hearth and full stainless double wall flue, trims etc.
I have one these, you would dramatically decrease the open area of the intake grill, the resistance at the intake could jump up. To compensate your fan speed would have to increase - more noise etc. The ductstore ones in the link have a much larger surface area, so get around this to some extent, but not completely.
But as I said above it has to be installed with unventilated air gaps either side of the insulation, as to get the thermal conductivity advertised it relies on low emissivity of the reflective coating.
Here are two photos of mine. J tube above footings, lintel in block work. We have a reinforced slab and the j tube is cast into position. The white box houses our meter. Once the insulation and UFH pipes were in, a further 100mm of concrete cast over again.
The Fluoride in water is food grade, so as I said be careful. Less than £300 new. https://www.directwatertanks.co.uk/1000-litre-new-un-approved-black-ibc-with-plastic-pallet?gclid=Cj0KCQjwnNyUBhCZARIsAI9AYlEJj9TG6haSFftXA4wExh_JOY5CM0uRwn0k6HJFNFolXVhtWMZq6WQaAtK-EALw_wcB
Biggest trouble is no-one installs it per the manufacturer instructions, with air spaces either side of the insulation. By the time you have the correct airspaces it's no better than much cheaper glass wool on a depth by depth basis.
Also hope you are buying them brand new never used. Many get used for all sorts of bad for your health stuff.
Read the manufacturers install manual that will give you the clearances and surfaces required. I would only have a HETAS qualified install, that way you get no questions from BC at sign off and your insurance if anything goes wrong later.
The 1m elevation will give you 0.1 bar uplift in pressure, which is nothing and really not worth any effort or expense. If you need pressure, you need to pump to an accumulator with a ranged pressure switch to tell pump when to start and stop, you need filters to take out particulate and a UV filter to kill and bugs.
Our non load bearing partition; 45x70mm w/w/reg treated timbers faced with 12.5mm plasterboard. Did noggins (if that's the right word) every 1200mm, walls are up to 3.6m high. Filled with 50mm dense Rockwool. Seem well solid.
That's what I will do with mine is there are any complaints. My duct actually terminates 400mm below DPC level but about 200mm above outside ground level, I will have decking above it. It is an L shaped duct the horizontal flows slightly downwards to the outside.
Got all mine from Outsourced Energy. Go to there web shop. No issues at all.
Best ASHP manufacturer/model for new passive house
JohnMo replied to markharro's topic in Air Source Heat Pumps (ASHP)
My sap EPC said 5kWh for 2.9 people for DHW. But two of us are using nearer an average of 7kWh. Looks like you only need a 2kW heat source for heating. Have you thought about UFH with Willis heater and direct electric water heating through E7. 2x 3kW Willis heaters (1 duty one standby) some isolation valves, circa £200 in parts. Low capital spend compared to heat pump. Direct E7 heating with PV diverter contribution. -
Depending on size of house you may only need circa 3kW, the only ones I came across were LG and Vaillant -
Best Subfloor for UFH with Suspended Timber Floor?
JohnMo replied to hammerandnails's topic in Underfloor Heating
Not sure why you asked the question then about minimising screwing, if you are going to answer yourself. Some glue systems only require screws at the perimeter, where there should be no pipes anyway. -
A condensing boiler starts to condense at I think a 56 degC return temp, the more it condenses the more efficient it gets. Cut and paste from heat geek, it shows steady state efficiency, a stop start kills the efficiency. 76 more like 70% would be nearer.
They are only that efficient when running at really low temps, well below the condensing temp and running for a long time. Short running periods and high return temps possibly much lower efficiency.
ASHP with large thermal store (for load shifting)
JohnMo replied to apesort's topic in Air Source Heat Pumps (ASHP)
Water cylinder is why cheaper than a sunamp. £3k v £1k size for size, spend a little more get an A rated cylinder like OSO, the heat loss is low also. 300l, start temp 30 finish temp 56, circa 9 kW. Which takes back to big buffers/ thermal stores. -
Why not replace the whole things will slim line led fittings they are about 10mm thick. Possibly a bead of sealant to stop drafts. Example of light fittings, I mean https://www.toolstation.com/led-slim-round-panel-light/p71575?store=LJ&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=_dm&pcrid=558038224734&pkw=&pmt=&gclid=Cj0KCQjw1tGUBhDXARIsAIJx01kit9HU4Z30HFIGvtfHDQNDi6WQvOSsinvm_jkeYgKNOTkA2ocQ7ZQaAjvaEALw_wcB&gclsrc=aw.ds
Small section with the same cross section should be ok. If you worried about noise, insulate around the changes in cross section shape. If it's the same cross section the velocity will not change. Noise is generally flow induced by velocity. You should look up the pressure drop caused by the transition pieces to ensure they are low pressure drop.
