JohnMo
    200
Everything posted by JohnMo
  1. How deep are your rafters and how much room below do you have?
  2. Isn't the 4000W just for overcooking. So the inverter is rated at 3.6kW, but you can add more panels (in your case an extra 600W), so in low sunshine periods you get better performance up to 3.6kW. The inverter has Max AC Power: 3.680 W Max DC Power: 4.200 W
  3. No-one likes to hear criticism, but you need to set ground rules for your guests and enforce them. Sounds like your a pain live next door too; if their complaint is to be believed, I would just keep calling the police to complain.
  4. Just been on the site and the simulation tools. To get a u value of 0.1 you need HCONTROL HYBRID 45mm HYBRIS 210mm thickness BOOST'R HYBRID 35mm So even without any air gaps you are at 290mm, without the air gaps you get no where near 0.1 So even their simulation says it's not possible.
  5. But does that include all the air spaces you have add between each layer? Most of these systems when you take into account full build up depth, do not give any improvement on a basic glass wool. I think we would all like to get great levels of u value without thickness, but it's not realistic.
  6. When we were getting quotes for turnkey the builders were saying they had their own insurance and because of the liability they would not allow us on site, unless invited at key stage inspections. So really depends on what way you are doing things. We ended up doing most the build ourselves and were self insured. Only real issue is liability if someone injuries themselves, so you may want to cover yourself with third party liability insurance. Didn't see much benefit to in theft insurance as the excess nearly covered the replacement cost of anything left on site. We ended having a wheel barrow stolen, that was it, and someone writing on a project plan on the wall. Other thing to consider is rebuilding cost if a storm rips through the place at the worst time.
  7. Difficult to hear the when on. Low energy motors so don't cost any more to run than high output normal extractor. Plenty can go in ceiling. Quick search https://www.extractorfanworld.co.uk/envirovent-eco-dmev-ht17v-zone-1-selv-continuous-ventilation-unit--humidistat--timer-4123-p.asp
  8. No surprise you have mould issues, if it not windy your ventilation rates will be next to zero. If you put a CO2 meter in your bedrooms you would also most likely have a unhealthy level of CO2 during the night. If you don't have vents above the windows, I would crack open the window, there should a way to open very slightly and close the latch/ handle. But in the medium term look at what you could retrofit. Here is good write up, their fans can be picked up a very good prices if you shop about, look for the model number as they are sold under different vendor name in the UK. https://www.zehnder.co.uk/blogarticles/evolution-dmev-technology
  9. dMEV. Almost silent in normal mode, quiet in boost mode. Low and slow continuous ventilation. You need a window vents be open in dry room (bedrooms etc) to be effective as they use cross ventilation to sweep out CO2 in bedrooms and damp air in wet rooms. But more expensive than a normal extractor. Normal fan, makes a racket only on for a short time, not really sure how effective they are if you have a damp issue. Cheaper than dMEV. What ever you choose, don't position near a window or doorway, as it will not be effective.
  10. Some systems allow you use both. Generally I believe load compensation is a active in one room and applies a shift in temperature to the whole house. So if you use the load compensation in your living room and it hotter than your setting, it will cool the CH flow temp to all rooms. Weather compensation is a low and slow, long boiler run times at very load loads. So possibly suits people that are home slot of the time. Load compensation is run it hot and for short periods with some modulation. Possibly suit people out most the time.
  11. Think others on here are using UVC as buffers, Joe90 I believe is, I am using a vented thermal store as my buffer, just converted it to use a 2 pipe layout.
  12. So the boiler is slightly oversized for the coldest day, so anything warmer outside will make the boiler feel more oversized. You will probably need a buffer. If you look at my other posts under heat pumps, there is the calculations for buffer sizing. If you are implementing weather compensation, whole system would be run 24/7 on a variable temp based on outside temp. The heat geek website tells you how the set up weather compensation and how to balance the system. The room thermostats will only be there to limit room temp, so the sun is out and warming the room, the thermostat/trv in that room will turn off the heating in that room only. For this type of system a simple dumb mechanical thermostat/trv is all you need one per radiator.
  13. I really wouldn't bother installing. Manage the room temperature by air temp. Manage water flow temp with a decent mixer at the manifold.
  14. I would run the whole downstairs, upstairs dressing room and upstairs wet rooms as a single zone from one thermostat, get a wireless thermostat and don't commit to its location until you start using the house, them find the best place for it. It is unlikely the bedroom UFH will be on if you are well insulated. Simple 0.25 deg (or better) hysteresis thermostat in each bedroom. It would be worth balancing flows so the bedrooms don't get enough heat to get the thermostat to operate. Turn loop flows down or spread the loops to 200mm spacing. I would delete the utility, hall and landing loops, and just spread out the other pipes routed through those areas across the floor. Based on loop spacing it is unlikely you will need a buffer, as long as you operate a large volume system. The last thing you want is just a bedroom calling for heat as that will lead to the heat pump short cycling. You will need a manifold that can accurately manage flow temps at or below 25 deg. Or use something like an ESBE CUA100 instead of manifold mixer.
  15. Do you have the option of weather compensation? Are you on a heat pump, gas boiler or something else? What sort of house are looking to fit the system too, such as insulation standard, one bedroom flat, 20 bedroom mansion etc as it makes a difference.
  16. Reference condition based dMEV you referred to. I am not in agreement with the comments made with respect MVHR. I have MVHR as our airtightness is less than 3, so had no option. But dMEV, operating based in air quality is a great way to go as ventilation is only done when needed and on a room by room basis, MVHR is all or nothing. I have attached a report on such a system which make interesting reading.Atamate_SDAR+Paper+2019+(1).pdf
  17. Not sure if MKM are in Inverness, but when I priced lots of timber up (Elgin) they were the best price I found. I didn't include a DPC under internal walls, didn't see see any need as you also reasoned.
  18. Flat roof looks fine, you would normally have a timber edge all round the edges of that roof. Sloped roof. You should have a breather membrane above the insulation, you will need to batten and counter batten. You will need a barge board 150mm thick at roof edge to stop the insulation sliding down. First Battens are screwed through insulation into rafters.
  19. Been modifying my heating system today (it been off for many weeks) and had to drain down my buffer cylinder (using a 160l thermal store). The next bit surprised me. Anyway refilled with water from my borehole, so water going in to cylinder circa 6 to 8 degC. Started the UFH circulation pump (boiler off), next thing I noticed (possibly 20mins later) the buffer cylinder temperature had jumped to 25 degC. So our floor must be circa 25 degC at the level of the UFH pipes. Floor make up gives a U value of 0.09. the concrete screed is 190m2 and 100mm deep, so circa 47Te
  20. It's just under 24kg a sheet, so density quoted as 650kg/M3 looks correct. So it must float, but not tried it.
  21. Photo, was the best I could find showing a roof light - I have 2 roof lights. They form a cover for the upstand and it all welded together.
  22. Not sure would like that, wife would definitely throw the teddy. We settled on french doors and fixed panel. Ours is 2.7m wide, but could easily be upscaled. We have a lock on the outside, for ease of use. Also just been air tested no leaks.
  23. Switching options are, may be others but not aware of any. Humidistat, but these are not great in the UK climate and humidity swings with seasons. PIR could be with a delay timer, in and out in a minute does nothing, anything longer for example a shower or a number 2 it comes on. Manual switch, our MVHR has humidistat, but is pretty rubbish, so use manual switch by light switch to make boost when showering etc. Light Switching, as you mention no light on, no fan on.
  24. Our roof is at a 12 degree angle, we used EPDM (Sarnafil) which has all seams hot air welded.
  25. Pretty unlikely, you normally don't here anything until or after that date, irrespective of the decision.
