Dave Jones
    11
Everything posted by Dave Jones
  1. they may still have access rights over it even if its not stated on the deeds if its been used over an extended period.
  2. you need proof the neighbour is parking on your land. Personally i would get an indemnity policy from the seller that you can claim against come the day you move the fence onto the neighbours space and it kicks off.
  3. check the original permission to see if PD rights were withdrawn.
  4. economy7 night storeage.
  5. this is correct, recipe for disaster if not done correctly.
  6. liquid metal is future
  7. read https://www.molevalley.gov.uk/CausewayDocList/DocServlet?ref=MO/2012/1612&docid=435467
  8. it wouldnt be too difficult. drop your side and maintain the ridge to keep next door watertight while you rebuild your side. Looks harder than it would be.
  9. ask the solicitor to see what the deeds say, unlikely you would own part of the car park i would have thought ?
  10. when you say all the way through, that wall should be 300mm cavity ? Mighty long screws! If you mean the outer face brick then they are not structural, the roof sits on the inside skin. So even if he had knocked down all of it the roof would still be fine. Did you tell the contractor where to put the gate?
  11. problem i have found doing horizonal batten fencing, anything under 10mm gap and when the wood moves it closes the gap too much and draws the eye to it. Next one I do im going to use 13mm gap as I think it draws the eye less the larger the gap? Could allways look at thermowood for cladding as this doesnt move.
  12. doesn't always help but i leave the packers/spacers wedged in for a week on wood that is likely to cause a problem. sometimes works sometimes doesn't. Worst parts pull out and replace.
  13. dont you have enough hassle with building a house without all that nonsense over some tiles ?
  14. let the supplier sell them and re-order when you are actually ready ?
  15. of no direct use to you but we had a similar asshole as a neighbour. We had a small paddock (remote to house) and the neighbour continually caused us hassle, he stored all sorts of machinery on his and was forever smashing fences, tearing up the road etc. In the end i sold it to gypsies who moved in with 3 vans. Sometimes you have to talk to these people in the only manner they understand.
  16. no. they are being lazy as person b cant be arsed to make a cad drawing himself so wants person A to email it. sack them both.
  17. problem with ordering services early as the quotes last for 90 days on some and you wont be ready for them by then so will have to pay for a re-quote.
  18. Peter, that just isn't realistic. The bargain basement installs are £10k compared to a £2k boiler.
  19. Peter, would you share what this system would cost Joe public to install to allow a fair comparison against a tanked system boiler ?
  20. what an awesome view you have their. Money cant really buy it.
  21. if by scalping's you mean road planning's, then they are very very good. Just watch out for occasional lumps of manhole or kerb mixed in.
  22. Ian, the 20 minutes was an example of how long it would take to exhaust your tank after which you have zero hot water. I guess depending on your tank size, pipe diameter and flow this could be quicker or slower. The end result however being them same. I know im a lone voice here on this issue and I accept that. Heat pumps are a step on the way but they are not the answer. Look up this thread in 20 years and I promise i wont say i told you so.
  23. Ian, turn on the hot tap for 20 mins full bore and both you and I know the heat pump will have no chance on keeping up. More so in the winter when there is less heat in the air when its needed most. Now that's not to say at all, that your system as used, could be an acceptable feature for your circumstance. It is however a retrograde step when compared to limitless, paid for on demand proper hot water.
  24. well, can the roof pitch be dropped ? You really need 150mm upstand on lead. That cill is going to need close attention to detail.
