Dave Jones
    11
Everything posted by Dave Jones
  1. fischer paykal cooler all day long. swanky sw1 pads cant be wrong.
  2. all the builders merchants stock an insulated hatch with a built in ladder for about £80. fits 600 centre trusses.
  3. i agree. Just takes a little thought though. wherever the flue is going o be placed put a 2m tray above to give leeway. It can only help cant it ?
  4. although the provision of a tray during the construction of the wall is considered good practice. The guidance is there for a purpose at the end of the day. To protect the building.
  5. they do, warranty providers though are more demanding.....
  6. no problem. https://www.nhbc.co.uk/binaries/content/assets/nhbc/tech-zone/nhbc-standards/tech-guidance/6.1/ducts-flues-through-core-drilled-holes-.pdf
  7. metal ones on top, try and position it so the tile cuts work at the top. bottom is the stickable flashing so have more leeway. I ran a length of 450mm damp under the top and bottom flashing to belt and braces.
  8. to meet current NHBC regs it needs a tray above it.
  9. what is it your trying to achieve ?
  10. if you have the ceiling height upstairs then underfloor for sure. I'd also have wet rads in all the bathrooms for the times when you dont want heating to the whole house but do want it to the bathrooms.
  11. one of these and quite a few chains... https://www.toolstoday.co.uk/stihl-gs461-76-5cc-petrol-16-400mm-diamond-blade-concrete-chain-saw
  12. wouldn't put my life on the single screw into batten holding that ridge tile down
  13. much less hassle take the room off and get new trusses.
  14. looks great, do you mind sharing the cost ?
  15. any pics of your roof, the 'infinty' type roofs do look good. How may kw did you end up with ?
  16. can you not continue the wall/cladding up higher to make a gable out of it so you can use the same size soffetts ?
  17. again it doesn't matter if they don't own it. Highways would need to allow them to use it (which they may if its a council house). Ask the planner when you have the conversation later.
  18. The architect 'should' know the law on this unless they are just taking your money! Find out who the planning officer is dealing with the application, send him the drawing and have a conversation. Don't mention any of the house value, don't like it, they don't need a bath etc as none of that matters. If you get the run around find your local councillor and have them do the chasing, they are quite good sometimes.
  19. The required fall depends on your roof construction to an extent. NHBC covers it in detail: https://nhbc-standards.co.uk/7-roofs/7-1-flat-roofs-and-balconies/7-1-5-drainage/
  20. in that case they couldn't apply for planning permission to use it as they don't own it.
  21. not necessarily, a lot of planning permissions specially exclude future PD rights. I'd fit them anyway and take it to appeal if they are stupid enough to enforce against you. Cretins do seem to be drawn to public sector jobs.
  22. shame your builder 'friend' cant help you buy letting you book mats them to him to a get a better price and then paying him cash!
  23. There is the prob. depending on how much space you are williong to lose could batten, insulate and board or use celotex backed plasterboard.
  24. ok, doesn't matter if they are disabled, have a bath on the plans or from mars. Planning laws are same. Ask the planning officer about the 45 degree rule, he will maybe ask the applicant to provide a drawing showing where it lies. If he doesn't use your local councillor. If they own the land in front of your house then it seems reasonable to use it as parking ? Don't object to 'makes my house worth less' it irrelevant and will be ignored by the planners. Your ability/disability is also irrelevant to planning.
