Mr Punter
In roof panels leaking or condensation?
Mr Punter replied to CH_18's topic in Roofing, Tiling & Slating
A very good point. There is often a very vague spec when it comes to this. You can get intumescent fire barriers that you attach to the panel and in the event of fire it will swell and stop the flame. I expect they get purchased and correctly detailed and installed about 2% of the time. Make sure you close the cavity around window openings (with timber or Rockwool) as this is an obvious place for fire to get from the cavity to the inside or vice versa.
Possibility for a bedroom?
Mr Punter replied to flanagaj's topic in Lofts, Dormers & Loft Conversions
Based on the scale, a 2400 room height and 300mm floor zone as per @Russell griffiths, this is how it would be: -
Am I right in understanding that this house in Donegal is built using Porotherm blocks, with no cavity, rendered externally and plastered internally? If that is the case it is not surprising it has damp issues. Porotherm is a real Emperor's New Clothes product. Almost no "therm" at all to the stuff and very difficult to cut or fix to. It does have quite high compressive strength and lower density due to the voids.
- 31 replies
- concrete slab
- lime render
The Wedi board XPS type boards are nice to use. Much easier to work with than the cement based likes of Hardi Backer.
I can see that the roof opening was made smaller since it was originally framed but it is not unusual. It looks like the far end trimmer was positioned so that it rested on the nib of wall rather than being a point load on the lintel over the opening and the numpty surveyor did not measure correctly when they came back to measure the completed structural opening with upstands. If you do not get satisfaction from the meeting, issue a letter before action, including the total money amount you seek, which can include additional costs for overheads, administration, prelims, finance costs and profit. Get quotes and lead times from at least 2 firms for the replacement cost. Give them 14 days for receipt of a satisfactory response. If the firm do not agree to pay your claim or make a reasonable offer, issue proceedings. You can do this online.
I am pleased you removed that. I think they are awful and quickly grow much too large for the average garden. Best left to the Aussies.
I would run your proposals past the Building Inspector. You need to be able to rod all the pipe without disconnecting the WCs etc.
You can run the bath and basin in normal waste pipe. You could have a waste manifold near the WC to connect everything to. https://www.screwfix.com/p/floplast-push-fit-4-boss-single-socket-waste-manifold-black-110mm/40832 Plus a stub stack and AAV. This should mean just 1 pipe run out.
Continuous ducting, mains supply, Southern Water
Mr Punter replied to Del-inquent's topic in General Plumbing
I like that they insist on you pointlessly installing insulated ducting under your insulated slab but they gleefully dump untreated sewage into our rivers and seas. -
I have only used ducting when I have needed to feed the pipe through later. -
Constructional hearth on beam and block
Mr Punter replied to Dave Anderson's topic in Stoves, Fires & Fireplaces
You could use Rockwool floor insulation. Not great insulation values but non combustible. -
I don't like the ground floor rooms being open to the stairs. Upstairs habitable rooms will all need escape windows. Heat, noise and cooking smells will all go up the stairs.
For some acoustic applications they put a strip of compressible material under the soleplate to help prevent sound transmission.
size of excavator for baseworks?
Mr Punter replied to sunflower's topic in General Construction Issues
Get a large excavator if you have the space. 8 tonne would mean you could load the muck lorries and not need grabs. It will also be good for materials handling. Hire it with an operator. -
I have just had some Velfac windows supplied and fitted. I noticed there was an obscured glass window in a kitchen area which I wanted clear. Looking at the signed order it did specify obscure so I thought I would be on the hook for the cost of a replacement. I contacted Velfac who apologised and said it was their error and they will send a replacement sash FOC.
Yes it is wrong. If this is supply and fit, get them back to sort it. It needs a cill set to overhang the brickwork. They may need to scrap this one and start again. Water will be pissing into the cavity.
Timber Frame Soleplate overhanging cavity
Mr Punter replied to john0wingnut's topic in General Structural Issues
The OP is now proposing a 240mm I beam type frame so I guess it will span the inner and outer masonry. -
I have done quite a few small infill plots. You may be able to go down to 3 boards wide, so 750mm.
