Mr Punter
How much technical detail should a construction drawing show?
Mr Punter replied to Adsibob's topic in Damp & DPCs
I have used Guttercrest for copings and they seem pretty good and reliable. You can probably drape some DPC under the copings for belt and braces. -
Collapsing small wall - can it be saved?
Mr Punter replied to johnannik's topic in Landscaping, Decking & Patios
No it will need rebuilding. -
Drying and re-insulating a 2.5 year old damp cavity wall
Mr Punter replied to Adsibob's topic in Heat Insulation
Some mineral wool types, like DriTherm cavity slab, claim to be water repellent. Maybe get the leaks properly sealed, then do a test hole or 2 to see if it is actually saturated.- 44 replies
- damp
- cavity wall
If it is any consolation I think the brickwork does look good. I have used aluminium coping for parapet walls in the past and it performs well but may not suit the minimalist aesthetic. -
If you have decent ground conditions and you want it to be fully habitable space you could budget costs of 1.5 x the going rate per m2. The finished value is likely to be about 75% of the above ground value per m2.
A friend of mine is looking at these. It looks a clever system and saves getting heavy steels in. Not sure how expensive though. Can you update this post with the price when you get it?
- 10 replies
- loft conversion
- ridge board
Have you tried contacting TeleBeam? They should be able to provide you with a quote and the design and calcs will be included in the price.
- 10 replies
- loft conversion
- ridge board
Render will help. Make good around all holes inside and out.
How can we make the front elevation look more interesting?
Mr Punter replied to LnP's topic in New House & Self Build Design
Because there will be a fair amount of PV, try to avoid lots of hips, valleys and rooflights on the main sun facing slope. The PV may look better if it is in a single block. I note it is not included at all in the current plans and elevations. -
Can you get it galv at reasonable cost? If they are hinged be aware that a strong wind will be an issue so timber infill is not ideal. If they are automatic you obvs need power and cabling. A friend does these and likes FAAC. Videx for the intercom. Be very aware of safety requirements so nobody can get crushed between or behind them.
Can you have a parapet roof verge on a timber frame house?
Mr Punter replied to LnP's topic in Roofing, Tiling & Slating
electric boilers are cheaper than heatpumps to run
Mr Punter replied to dpmiller's topic in Environmental Building Politics
A few years ago I converted a Victorian building (150 years old?) back into 2 cottages. It was a heap of rubbish, built from whatever come to hand. The only reason it survived was that it was shielded by surrounding taller buildings. -
Yes, 100%. There is a new(ish) timber frame Premier Inn near me with this detail. I can see it from my office. -
Where I am a typical house is a Victorian terrace in a conservation area. In nearby Brighton a typical dwelling is a converted flat. -
Have a look at some: https://www.cupapizarras.com/uk/news/slate-cladding/
That camera looks like it is to track anyone trying to leave...
Yes, you could do it in natural slate. Won't fade or warp and will last longer than most of us.
Wet weather, BC, SE, Drawings, cost and more wet weather
Mr Punter commented on LSB's blog entry in Little Stud Barn
Mistakes like this are easily done. From the drawing it looks like the top of the cellcore needs to be level with the top of the foundations, so there may be a fair bit of infill to make up. -
Justifying the cost of stupidly expensive toasters
Mr Punter replied to Adsibob's topic in Kitchen & Household Appliances
I guess B&Bs may. The only safety issue I have had is when the timer clockwork spring lost its mojo and the toaster got very hot before I realised. -
I have a Dualit 3 slice (2+1) and it is about 30 years old. If you must put it under a wall cupboard, bring it towards the front and if you are doing a massive toasting session, relocate it. -
Conditions to be satisfied prior to start
Mr Punter replied to Post and beam's topic in Planning Permission
You can't always satisfy all the conditions in one hit. Things such as archaeology and contamination are often in several stages, so will need to be discharged in stages. -
You are doing the right thing going around with a foam gun and perhaps some decent tape. Look out for boiler and extract holes, overflows, condense drains etc. Trades very rarely make good around these. Bear in mind that not every day will be cold and windy, so you may find it performs OK for much of the year.
