Mr Punter
I would recommend FAAC for the automation kit. Most of the kit knows when there is an obstruction and will stop. I wouldn't get a builder to fit it unless they have done them before. Will you have a keypad and intercom as well?
Joining roof construction
Mr Punter replied to DIY_ME_UP's topic in Lofts, Dormers & Loft Conversions
No, you should not have cold air coming in under your warm roof. Your cold roof has internal and between rafter insulation and outside airflow above. The outer layers will be open to outside air but inside will be nice and warm. Your warm roof will have insulation on the roof deck, so the whole thing is warm. It needs no ventilation. Again, no outside air should get in at all. On the interface you will need continuous insulation, while still allowing the airflow over the outside of the cold roof. Perhaps post a drawing. -
I have had Kalzip -type standing seam in the past. I think ours was Rigidal. It is ali sheets and they fix tall halters to the deck, mineral wool then the sheets go on and they use a machine to zip them together and to the halters. It is a bit like walking a dog along the roof. You can use the machine to unzip as well should it be required.
At a guess I think about £60,000 plus fees, so budget £70,000, which would include everything assuming it is carried out by a main contractor with the rest of the build. I have sometimes found proper well finished balconies are more expensive per m2 than internal space.
A "mini french drain" for a cable, into a tile?
Mr Punter replied to puntloos's topic in Floor Tiles & Tiling
No to all. Why do you want to do this? -
From the photo it doesn't look too bad. Is it all over, or just where scaffold poles were close? It will be expensive, messy and time consuming to do much about it.
Screeds tend to be a) traditional - sand:cement either site mixed or dumped in a heap, laid damp to about 75mm b) liquid gypsum based, mixed in a machine and pumped in normally about 50mm. Not great if it get wet and can form a laitance coat that needs removing before tiling. c) liquid cement based, again mixed in a machine or at a batching plant and pumped in. Normally 40-60mm. I don't think the drying times vary all that much between them. I have seen some stuff that is a leveling screed and claims no time needed to dry as the water is locked in.
I have a full shower a couple of times a week. The rest of the time it is groin and armpits plus face and handwashing.
I guess about 130kg
Tile first. If the tiles + adhesive are thick just cut down the skirting to suit. If the chippy has a table saw it is very quick to do. Even a circ saw and fence is OK.
Doing the whole thing will be easier. Bear in mind the depth specified is from ground level, not the depth of concrete. You may be able to just put in concrete 300 deep and build up with blockwork.
- 4 replies
- concrete
- foundation
Use of lead for hidden gutter, maximum length
Mr Punter replied to Rodge's topic in Rainwater, Guttering & SuDS
Unless you have a skilled leadworker on side you would be better with ali, grp, zinc or steel -
Yes you can run it through the insulation. Best not to have pipework joints apart from when you are coming up for the rads, so you may do the main runs in plastic and the tails in copper.
+1 Less than £1,000 and very accurate. They will record all the features, heights etc. Architect will like it too.
It looks fairly simple. You should not need an architect. You are right that the kitchen will need a door to the hallway. You engineer will need to take a look and see which way joists run, floor type etc. Who is doing the work? You could do this on a building notice rather than full plans.
They will sometimes just want pictures but if you request a quick visit they should agree to it. I assume they inspected the foundation trenches?
I would arrange to meet with Building Control on site. Let them break the news to the "builder".
If the beam is supported along its length you will be fine, if it only supported at the ends you are not at all fine.
If you clad a house in unpainted treated softwood it will last about 10-15 years. Clad it in untreated imported Western Red Cedar and it will be good for 50+.
I have done a feature brickwork fireplace directly off beam and block. The floor designer specified multiple beams for that section - something like 10 together. We could have done extra footings for similar cost.
