Mr Punter
    27
  1. I am interested that you chose CLT. What are the benefits / your motivations behind this?
  2. There is a lot of glazing and exposed wall perimeter for a passivhaus. It does not look like it has been designed to the standard and it will be very difficult to try to make it work later. The rooms look OK but overall I am not that keen on the design. A lot of work is needed on the elevations.
  3. I have used Fermacell in the past and I would never use it again. It is a nightmare to work with.
  4. Hello @MiriPiri and welcome. Feel free to ask questions. Do already have a site with planning consent?
  5. Your lintels are only supporting the inner leaf so just go for whatever is cheapest and easy to fit. It is concrete block so I would go concrete lintel.
  6. We spent £73,000 with IC on sliding doors and windows for 7 houses. We used their approved installers. They subbed Compriband for no-name crap, we had 2 doors fall out, loads of leaks, inward tilt turns that shat themselves and several sliders that graunch to a halt. They were fairly cheap but fairly crap. Lots apparent from day 1.
  7. Regarding the money side of things, £1,000 a metre is very ambitious as a build cost. Unless you do most yourself and have very good industry contacts you may find that could be doubled. In your area you may achieve £5,000 a metre for the resale. Out of the 364 detached houses sold in the SL3 postcode in the past 5 years, only 5 fetched more than £1,300,000. I suggest you could look at this as a ceiling figure and work backwards to find the optimum property size, being about 260m2. If you could get a second house on the plot then all the better.
  8. The sliders that are crappy are 2570w x 2400h. They ground when opening. IdealCombi have been pretty hopeless at any remedy. I may have to have them removed and replaced which is no fun as they are on the second floor. I have some that are 2100w x 2300h and they are OK. We also had two sets where the opening door fell out. If it were not for the scaffold they would have fallen 2 storeys to the ground.
  9. I have some IdealCombi sliding doors with low threshold, as well as lots of windows. They are OK in smaller sizes but the larger ones do not operate correctly. Make sure yours are nowhere near the max sizes and you should be fine. They do not install but use their approved installers. I rate the whole thing 3 out of 5.
  10. I seem to remember flagging up issues with removing adhesive and the levelling things...
  11. It looks huge. At the moment there is not that much the I really love about it. Does it look good from the outside? Perhaps look at some front elevations you like for this house size around the location you are going to build in. Check out Rightmove and see what you find excites you.
  12. Mr Punter
    Celotex
    It is really landfill hungry. I don't think there would be any way to recycle or reuse the materials or even dispose of them in an environmentally friendly way.
  13. This is not ground rent it is maintenance which will be part of service charges. All costs are normally passed on to leaseholders
  14. Don't get 3 bags! Don't breathe it in! It is dustier than cement.
  15. A house near us had this fitted as the architect is into eco stuff. Although the sheeps wool was treated, it suffered from moths, which were very difficult to eradicate.
  16. You would need the roof membrane or sarking on before there is any wind uplift risk. Mortar will not prevent uplift, you need mechanical fixing, like straps down the wall. The SE should spec this.
  17. I find it quite concerning that most of these membranes burn very readily. Cut a bit off, light it at the bottom and you often need to drop it quickly before your hand get burnt. They are normally classed E fire resistance which means almost nothing.
  18. About 4 months ago I read a long document that had criteria from many lenders. I can't remember if it was aimed at valuers or brokers, but with timber frame lots wanted brick / block outer leaf. It was not the main thing I was looking at. Flood risk, above commercial, multi storey, tenant type were more of interest. Grenfell has put everyone off non brick or block. I think Trada etc did no favours by not emphasising fire risk. Once you cannot easily gain insurance, you cannot get funding and your asset is worth sod all.
  19. With the water pump you need to lie it sideways with the power cord upwards , similar to how you are holding it in the last picture.
  20. With the fridge freezers I like to have a socket on flex under the adjacent plinth and the water supply at the back under the same adjacent unit. It means you can handle the pipe and wires, knowing they won't get snagged. I also run a "dam" of mastic on the floor around the back and towards the front so that any leak will become visible at the front of the appliance. Not pretty but not visible when the fridge is in.
  21. Ask the neighbour if it is OK to fix the end of a panel to his workshop. Are the adjacent pieces of land secure? You really should secure the site with fencing - Heras type is simplest - to prevent unauthorised access. It will help to prevent theft, trespass and vandalism.
  22. Yes to the packers and it may be worth running flooring under washing machine, dishwasher and other floor standing appliances so you do not get a 12mm lip when removing them. We always floor throughout and have never had an issue. Mainly use engineered wood glued down. I have seen a floating floor lift where it is fitted without a perimeter expansion gap.
  23. He would have drawn it up in CAD and marked each tile on the wall. Are you employing the technique of bathing in tile adhesive and throwing yourself at the wall? It does look good but maybe try to keep stuff cleaner if possible. Are those levelling things reusable? Anyway, pull your finger out and get the rest of that wall on, leaving the rips for later. Chop Chop!
  24. That is looking really good. It is worth removing the surplus adhesive from the tiles before it goes off.
