Mr Punter
    27
  1. Our posts crossed above. The main info now is how much input / how hands on your are likely to be?
  2. (a) Calculate how much you can borrow. For a rough figure assume you can borrow three times your joint income. (b) Calculate how much cash you can put in. Add your savings and your equity in your current property. If this figure is less than 25% of (a) you may need to save more or borrow less. (c) is your maximum all inclusive budget from (a) + (b) . Let us know (c), where in the country you are and how much work you would be able to do yourself and we can have a stab at what you could build.
  3. I am also keen on hook fixing. It stops any rattle and makes sense to have the tail of the slate held down. Even if the slate were to crack (which is less likely than with nails) it will not slide down off the roof on onto who or whatever is below.
  4. Use CT1 to stick the profile to the wall, but you could use silicone as it is screwed on anyway. Use silicone on the outside of the profiles.
  5. 25 x 50 with trusses at 600 ctrs is standard here.
  6. I bought a plot a few years ago with outline pp. The plans consisted of 1:1250 identifying the site and a 1:500 (I think) that just showed the outlines of 3 detached dwellings on the plot. Elsewhere we have wanted to gain outline PP and have been told by the LPA that a full application is required.
  7. Mr Punter
    September 16th
    My brain or fingers confused this. Cut back, wait for new growth, then spray. If you need to clear a site, spray a couple of weeks before you remove the weeds, so the roots will die and no new growth will regenerate.
  8. This has al the makings of a crime thriller plot. Did the buzzard have a Russian accent?
  9. It looks like the plan was done with an etch a sketch (not a simple rectangle, but well worth seeing what @Rmawdsley has to say.
  10. I would agree with @SteamyTea here, as he knows a good deal about this, and I know very little!
  11. Are you near neighbouring structures?
  12. It really looks like the BT was livened up. Is the BT near the pole outside where the buzzard bought it, or must it have happened in the router?
  13. Given the square areas there will be almost no difference on performance.
  14. Mr Punter
    September 16th
    Ivy has a waxy finish on the leaves that stops the glyphosate sticking. You can add other chemical to the glyphosate - I have read washing up liquid can work. Also better (but a bit late now) if you cut back old stuff and wait for new leaves, which have less wax.
  15. This really should be his problem, not yours.
  16. I am not sure where you are in the country but that is a very large house and the fees look very very low.
  17. You can shutter the verandah bit off completely with 6 x 2. Concrete either side, with one side 40mm lower then remove the 6x2 before the concrete completely goes off and infill the gap. Threshold would be easier to just scape off when it has set a bit. This is not that hard to do.
  18. Just phone or email a couple of structural engineers for a quote to size the steel and spec the bearings. You will need drawings, including the roof makeup. The cost is v. low. They will spec something that will work without being heavier than needed, which will be far better when it comes to installing it.
  19. I understand that in the current version of SAP the score improves if you use mains gas. It is also cheap to buy, install and maintain a gas combi and you get unlimited hot water.
  20. It would be normal to use shuttering to stop the concrete flowing into the area where you don't want it. 40mm is not very much. If you post the drawing and a picture of the excavation someone may suggest the simplest way.
  21. I thought the @pocster just blackmailed them with the CCTV footage he saves for such occasions?
  22. I have often topped up the sale prices for new build warranties to the actual sold value. Have done this with NHBC and Premier Guarantee. I imagine they all do similar. I will be pessimistic about the resales when I get the cover so it saves up front costs, then pay the extra as sales are agreed. You are better off getting the developer to up the value with Buildzone than getting a 3rd party top up.
  23. Mr Punter
    September 16th
    I like to spray unwanted vegetation with Glyphosate a couple of weeks before cutting it back. Buy Gallup 360 or similar if you have a large area and follow the dosage and instructions. That picture looks like it was taken in February.
  24. End bearings for steels are also important. Normally concrete padstones but sometimes steel posts are required.
  25. If it is exposed it would be best galvanised. A Universal Beam (UB) would be most common. You will need advice from someone on the section size.
