Mr Punter
    27
  1. Mr Punter
    Roof
    The existing slates may be worth a few quid as reclaims.
  2. None of the the guidance makes any mention of "wraparound", so it is not a relevant definition or description. This is a rear extension. If the extension is 6m or less from the rear wall it is OK. He may need to create a slight dog leg on the kitchen side (if the pantry is currently the outside wall an the distance to the proposed new rear wall is >6.0m) but it looks to otherwise comply.
  3. You don't see that down here but we don't get the weather you do. I like local vernacular building methods. He didn't scrimp on the slate and a halves / doubles either.
  4. Mr Punter
    Roof
    You normally get the name of the manufacturer printed on the membrane. Has it been replaced? The battens look a bit puny and are not to BS. You are replacing natural slate with interlocking concrete tiles.
  5. Mixed reviews on Trustpilot https://uk.trustpilot.com/review/www.duration.co.uk
  6. Looking much better. Pocket doors are good if you don't need to open or close them often. They are a hassle to fit and operate and they limit what you can do with the walls either side.
  7. Amazing product. They carry such a wide variety of quality products, all currently on special offer. I like some of the photo compositions in their adverts:
  8. Round here closeboard fencing is 3m bays, panel is 2.4m.
  9. I disagree. The proposal more closely resembles that at the bottom of page 19 and would comply as long as it does not project more than 6.0m from the rear wall. Not sure if the pantry wall is currently the outside wall? It is shown as single leaf.
  10. It looks like a rear extension. I understand it can be 6.0m with a prior approval application.
  11. I don't think the 45 degree rule applies to you as your extension looks like it is Permitted Development.
  12. It is normally just under the soleplate. Is that going to be a cavity tray at the bottom?
  13. I think is is Hardie Plank Cedar texture in Light Mist.
  14. Is that Light Mist colour on the cladding? I have it on my house but with non-textured boards.
  15. Could you do 50mm Xtratherm / Celotex with joins foil taped, held in place by 25 x 50 battens then 15mm plasterboard? You could even staple a VCL to the battens before you board.
  16. Nice. Tell more. Did you make them? Are they automated? They look like sliding but I can't work out which way. Pics during construction may be good.
  17. I like to use CT1 for the joins in the substrate boards - Hardie Backer or whatever. Not as good as proper tanking but for a shower it seems fine. Then just tile, grout and then go over the internals with silicone.
  18. No, silicone. CT1 does not finish well and discolours.
  19. We apply CT1 to the joins in the cement boards. Tile and grout as per (2). Silicone to internal corners.
  20. It is going to be so much harder to coax people into that shower with a paint finish like that.
  21. Then it is beyond reproach.
  22. Why did you have it before the PRV? It would have looked neater the other side and no pipes crossing and no hosepipe issues.
  23. You could have pendants with long cords, so the light is closer to the area being lit. Any spot lights may be so high up as to have little effect. Have the lights at about 2200mm from the floor. Means you can safely access for cleaning / changing lamps. Look at wall lights / table lights / standard lamps as well. Make sure they are easy to switch, so you don't have to spend time groping about to operate them.
  24. You will need proper plans and elevations. You may need planning consent / Prior Approval / Certificate of lawfulness. You will need building regs. Why do you think you need a Party Wall Agreement?
  25. Run over the stuff with a wacker until it stops compacting. For future reference Type 1 properly wacked makes better blinding than sand.
