Mr Punter
A picture paints a thousand words...
It still seems strange that there has been so much cracking. I like the look of the place but it has caused a surprising number of issues. Hacking off that render looks like a nightmare job but it will look crap otherwise. Hopefully now the building has been up a while, with the remedial work there should be no more issues on the render front. Who is paying for this?
Yes, so you may be able to get them to take off 2 metres. Have a chat and see what they say. What is at either end of the bay? Double yellows? Disabled? Driveway? Whatever, it should not be insurmountable but it may cost a few quid for road markings etc.
It is how they assess parking availability and take up. This is how the Lambeth Methodology works for parking stress surveys.
Perhaps a change of diet or put away the porn.
I think a 50mm strip of plasterboard may be best, with a stop bead at the top. You can fix it with a timber batten. Maybe the join would be better around the side than around the bottom face. It will need either plastering or filling.
Like Gillette and their razors!
Where we are they have an allowance for bay sizes of 5.5m per vehicle, so a single bay is 5.5m, double 11m and so on. Sometimes they are an extra metre or so. They are not demarcated per car, so bad parking and big cars can stuff things up but residents on busy streets tend to want to keep things neighbourly and are fairly careful not to park badly.
Yes that looks fine. I have been caught out by too big a gap left by the tilers and had to get MagicMan to do their thing.
You don't need the zig zag, just an L-shape. Don't leave too much space at the top!
You need to measure it. The council should have a standard size for a space. Where we are it is 5.5m, so if the whole bay length were 20m it may only be able to accommodate 3 cars and so could be reduced to 16.5m without loss of spaces.
Are you laying these brick bond? The one around the WC looks a challenge. You may need a couple of spare tiles. I would just carefully cut a rectangle so the fixings and the flush pipe remain exposed. Do the horizontal first, with a plunge cut.
I have just looked these up as I have not come across them. No powder caps which is a bonus. It looks like you still need the big boy one for fixing timber to steel beam webs?
If there is room in the attic it may be worth working from there instead of from underneath.
If you have a lot to do the multi shot type are a lot quicker to use than having to reload every time.
The most important cut on these wall hung WCs is the one above the flush pipe, which must be close to the pipe or it will be visible after the loo is mounted. The rest you can just go round with straight cuts or l-shaped as you have done. If you have a loo you could do a template around it and offer it up. And yes, you can turn the tile over and do the last bit from the other side.
It is looking really good! Have you worked out where the windows are going - front- to back in the reveals? I looks tricky with the outside walls leaning a bit. Doing the blockwork off a small scaffold tower is quite a feat. Maybe and extra change of underwear will be needed when it goes higher. Will it bond at the corner after the next course or so?
I have used masonry paint. No undercoat but watered down first coat. You could just use emulsion if you want.
You should have some drawings for this. If you are new to the business it is a mistake to take on design responsibility. You then just price and build something designed and specified by others.
