Mr Punter
I think these are I joists, so a no-no.
How Long Should Structural Calcs Take
Mr Punter replied to SteveMack's topic in General Structural Issues
In my limited experience the SE does the connection details. The fabricator produces fabrication drawings with more detail and you can get them OKed by the SE. Never seen an architect showing anything other than suggested steel locations. -
What is the daily rate for a roof slater?
Mr Punter replied to epsilonGreedy's topic in Roofing, Tiling & Slating
I know it is just a simple case of measuring and setting the battens to the measurement but I would not want to batten a roof for others to slate, unless they confirmed that it was OK as I went. -
Where we are, if you submit the application online it is validated within a couple of days but normally the application received date. Once validated it cannot be undone.
Probably. About in the middle of the concrete is good so if the slab is 100-150mm thick it is fine. Why did you put mesh in the foundations? Not normally needed (but it won't hurt). Good luck with the pour. Much concrete?
You just leave SWMBO to @Nickfromwales (when he has finished helping your mother).
Caveat Emptor springs to mind but that does not help you from where you are now. Persist with WPower. Take photos and send them. Establish that is is dangerous as is and they have no right to run the power lines through your property.
I am struggling to visualise how you access the land? Again, a plan would be useful.
There are a few masonry support system suppliers out there like https://acsstainless.co.uk/product/type-1-fixed-back-to-concrete/ I think they are expensive though!
Dark grey or charcoal grout may look OK.
If they thought there were inaccuracies they could ask for updated information, issue a refusal or ask you to withdraw the application. They should not just remove it after it is validated.
I think they can easily skim walls on a 4m x 3m room in a day, so at 2.4 high that is 33.6m. At rate quoted that is £395, so double day rate.
Firstly, a drawing would be useful. I have had a reinforced slab with a stainless steel angle cast into the edge to build brickwork off. Would that work for you? It was done by Abbey Pynford. I am not sure if they would supply the brick support separately.
I bet the guys working for @nod would be keen to skim the walls at £11.77 per metre! They included bathrooms but not kitchen. You can see that in some areas such as plastering / boarding, tiling and decorating there is a great deal of labour cost and this is how the more hands on people can build at lower cost. Unless you are keen to put in a lot of work I think you need to budget £400k all in.
Comparing heavy duty breathable underlay.
Why not get the roof slated straight away? I would rather the roofers did the battens as well. You could just fit some temporary battens, so they don't need to fit the membrane. -
What wood grade for wall plate timber?
But the wall plate sits on the masonry. I would def make sure it is treated. -
With my hand apparently stuck in the ceiling space, I ...
Mr Punter replied to ToughButterCup's topic in Electrics - Other
You will need a soil survey. With ICF you cannot see the concrete so you will not know if it has faults or voids. Type C internal drained cavity membrane with sump and pumps is considered the lowest risk for basement waterproofing.
You get loads of credit for reduced thermal bridging. You can get proven lower psi values with Keystone Hi-Therm+ lintels and apparently the best value way towards your SAP targets. If you go ahead with them, order them well in advance as they are not a stock item.
This is a standard condition. Look at other planning applications for Sutton and see how they have discharged the condition. PV is an easy way to comply but your energy assessor should know that. Biomass gains almost nothing so maybe your assessor is not so good.
Advice required please!
Mr Punter replied to ZacP's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Option 4. It will be cheaper and simpler to start again. Your access issues will be at an end. You could set up a mini tower crane. -
For me it looks far too complicated and the aesthetic does not impress, especially not the exterior. The workmanship and execution are excellent but he has gone to a lot of trouble for no real purpose other than achieving something difficult.
I would tap around the crappy looking bits with the corner of a bolster and see what falls out, then fill in with a matching mortar. Unless you get driving rain against this wall it is unlikely to cause issues. The bricks do not look porous.
Where they are this would see them get blackballed from the Rotary Club. The very thought!
Self-Build first steps – advice sought
Mr Punter replied to bpk101's topic in General Self Build & DIY Discussion
OK thanks for the figures. For your income, this will need to be reflected on your tax returns for the last 3 years. For the sake of this, assume you have a total of £1M. You could look at sites on the market at between £300k and £600k. Rightmove has these withing 40 miles of Greater London: https://www.rightmove.co.uk/property-for-sale/find.html?locationIdentifier=REGION^87490&maxPrice=600000&minPrice=300000&radius=40.0&propertyTypes=land&primaryDisplayPropertyType=land&includeSSTC=false&mustHave=&dontShow=sharedOwnership&furnishTypes=&keywords= You could refine the search with keywords, but it will give you and idea of what is available. I doubt you will find any bargains on Rightmove but is is worth looking at what looks OK, just to get your eye in. Existing houses to replace are also an option. You can often double the size with the replacement. As you have the income and the energy, you may be better off doing this now rather than waiting five years. Life is short.
